Question about Lightwave Tech (200.0074)
How to install my super mini rf wireless optical mouse
How do I turn the mouse off/on?
Hi Charles,
According to:
Product Description Color: Brown
The Maxell 2.4 GHz Wireless Safari Mini Optical Mice have more than cool looks. Since they are 2.4 GHz wireless optical you'll notice less signal loss. They also have 3 key buttons and a scroll wheel so you can speed through your computer programs. The Maxell mice are wireless so you don't need to worry about wires getting in the way. They can detect a computer up to 32 feet away. These are compatible with Windows 7, Vista, XP, 2000, ME, Mac OS 10.0 or above. Requires one AAA battery.
- So i do believe there is no on an off button on that mouse as I read on this site that says: "This one doesn't have an on/of switch, so in order to turn it off you have to disconnect the USB every time and store it underneath the mouse (annoying) . also, if it's idle for a minute (maybe less) the mouse goes in sleep mode and you have to disconnect the USB to wake it back up (super annoying) . The mouse works fine, it just gets old having to take it in and out all the time".
Amazon com Maxell 2 4 GHz Wireless Safari Mini Optical Mouse Brown...
May 03, 2014 | Maxell 2.4 GHz Wireless Safari Mini...
How do I turn the Safari Mouse off?
Hi Charles,
According to:
How do I setup a wireless mouse on a desktop
To setup a wireless mouse regardless of its type, do the following:
1. Insert the USB transmitter (this could look like a mini plug or a stick) and wait for windows to complete installation.
2. Once this is successful, turn on the mouse by holding down the power button. Or insert the disc that came with the mouse and run the installer. The installer will install the device drivers and setup your mouse's configuration panel which will reside in your system tray.
Make sure that the mouse has batteries and that it is switched on for it to work. It will glow red when it is switched on.
Jul 06, 2011 | Gigabyte Wireless Optical USB Mouse GMW7C
Can't get the verbatim super mini RF wireless optical to work
There should either be a paring button on each device or at least one of the. According to the website there is no need for 3rd party drivers so technically yes it is plug and play. As for the disk - I think it is a DVD disk and you have only got a CD rom - otherwise spray the disk with window cleaner like Windex. I have tried this and it works -makes the disk easier to read. Also don't discount good old saliva [ I know - who knew] - making the disk readable mean you must have a DVD player if that is what the install disk is.
May 03, 2010 | Computers & Internet
My mini wireless optical mouse will not pair
I think you are facing pairing problem, solution is here, First of all please understand ‘what is pairing’ Pairing is theprocess of coordinating your mouse's transmitter with your mouse's receiver. Itrequires both parts to operate on the same frequencies, usually by using thesame identification code. Pairing takes place to try to eliminate interference.Some devices automatically pair both devices at start up; others need to bemanually paired. Step 1. Plug in RF DONGLE into USB port, Step 2. Put the batteriesin mouse (in right direction, see batteries. Direction symbols in the battery compartment +/- signs) andplace the batteries. Cover, Now you can see thered light glowing on the bottom of the mouse, now your mouse is ready topairing There is two buttons for pairing the mouse BUTTON 1 – this on the RF DONGLE, top/up side BUTTON 2 - this is at the bottom of the wireless mouse, NOTE- after pressing button-1, one time, your RF DONGLE willbe ON SERCH MODE for 7 seconds, Step 3, now press BUTTON 1, one time, and move the mouse, ifmouse curser is not moving then press BUTTON 2 one time – now defiantly yourmouse will work, If you need any other technical support for GMAX, products please contact satish kumar (countryhead gmax technologies)
Mar 08, 2010 | BenQ M310 Wireless Mini Optical Mouse
Difficulty getting my mouse to communicate
Normal 0 Turn the mouse over and find the small rest/connect buttonon the bottom of the mouse and press it. This should connect the mouse tothe receiver and work properly. If not, try pressing the receiver buttonand then press the button on the mouse. This should be done whenever youchange batteries or glitch. Hope this helps you. Bud
Nov 21, 2008 | FMI Mini Wireless Optical Mouse with Slim...
Usb connector
yes you require.and install the drivers of the wire less optical mouse to make use of the mouse.without installing drivers it will not support.
Nov 20, 2008 | GE Wireless Optical Mouse
Mouse pinter is partially moving
I would restart the computer, and if that does not solve the issue, I would replace the mouse.
May 12, 2007 | GE Wireless Optical Mouse
DS2068 - wireless wheel/Optical mouse
its usually for most wireless equipment, press and hold the reciever button for a few seconds then press the button underneath the mouse, for it to kick in, but have windows loaded to desktop when you try it.. All the best John
Mar 11, 2007 | DPI nSpire AXM-105 Mini Rechargeable...
Computers & Internet Logo
1,087 people viewed this question
Top Lightwave Tech Computers & Internet Experts
David Payne
David Payne
Are you a Lightwave Tech Computer and Internet Expert? Answer questions, earn points and help others
