Question about Toshiba TLP450, TLP451, TLP650, TLP651, TLP670U, TLP671U Projector Lamp - TLP-L6 Projector Lamp
Toshiba TLP560 miscoloring pattern
Please help, I have a miscoloring fixed pattern on my projected picture (red on black, black replacing red in the area, etc). It's not only in corners, it's a semi-circular pattern almost all-over, very disturbing. I saw another piece of advice talking about the polarising filter possibly being tarnished because of over-heating. Replacing this one should fix the problem, it was said. I've disassembled my projector up to the point I have been wondering where the filter is, actually. I've attached for you a picture with the insides of my projector. Are those indicated by the red arrows, or the panels indicated by the green arrows, or which?
http://i28.tinypic.com/2gvimgg.jpg
Thank you!
P.S. I have replaced the lamp, nothing changed.
  • 1 more comment
  • je_accuse Jun 13, 2008
    I looked again and again and I think I can see the problem: one of the metallic frames (from the right, with a red arrow pointing in my picture) contains a damaged plastic thing. As I looked more carafully, I could see that it was, apparently, the RED color thing. So, unless I am terribly wrong, this should be the melted filter in question that I need to replace.
    Question remains: which would be the best solution to improvise a replacement for this filter?
    1. I guess they do not come as official spare parts, do they?
    2. A photographic filter will stand all that heat? Is that the only choice I'm having?
    Thanks for any hint.
  • je_accuse Jun 14, 2008
    THIS IS HOW ONE OF MY POLARIZIN FILTERS LOOK LIKE:
    http://i28.tinypic.com/291doag.jpg
    ANY SOLUTION TO IMPROVIZE A REPLACEMENT?
  • pradozurita Dec 25, 2008
    I have exactly the same problem (may be a manufacturing design weakness).
    I tried to replace that polarizing filter to another ones that I found in old cellphone LCD screens. It works, but the result wasn't so satisfactory. Although the good reproducing image (specially in shine regions) the black still a with a bit red background. The reason is because the polarizers I've found was not so good in terms of minimum transmittance.
    Now I'm also looking for a photographic polarizer to replace it. I guess that the best ones for us are the "Linear Polarizers" (LPL) instead of "Circular Polarizers" (CPL), the most common ones.
    Once we buy the LPL we need to take care to the right orientation before cut it. A good way to find the right orientation is using the original (half-burned) as reference: put it over any LCD screen (those monochromatic with silver background reflector) and turn-it to find the orientation where the transmittance ritches the minimum (intersection becomes all black) and try to do the same with the new LPL.
    Please, let me know if you do.
    Best regards,
    Zurita
tvtek
  • 1284 Answers
SOURCE: Red?Green picture
If you are connected to a HD cable box or sat. rcvr. using component cables, I would then suspect a loose or bad blue connection or cable. If you have Comcast and have their supplied flat component cable this is a common issue.
Posted on Feb 13, 2007
SOURCE: Screen remaining black after the TV is turned on
Some newer sets appear that way when there is NO signal to the set. That and my Sony looks like that when the bulb is burned out.
Posted on Dec 23, 2008
knotbeerdan
  • 413 Answers
SOURCE: Hi, I need some help (BIOS locked)...
ok i found a couple more things...apparently you dont have to remove the battery.. I found this site that tells you two "jumpers" (solder squares) C88 i believe under the network card. But if you follow this link and follow the directions it will get you going again.
I don't know exactly at what stage you are at and i hope i didn't cause any trouble but this normally is how we take care of this problem. Unless once in a blue moon we come across one like this.
http://www.paralaptop.com/toshiba/fixing-bios-password-locked-on-toshiba-satellite-a105-s4014.html
Posted on Jan 17, 2009
SOURCE: Bulb Replacement
the bulb hot indication has nothing to do with the lamp counter.u would have reset the counter as suggetsed by the manufacturer,
this problem is because of the following:
1) wrong bulb
2) cooling fans not working adequately
3) defective ballast
check the above for a solution
Posted on Feb 09, 2009
  • 4 Answers
SOURCE: I heard a pop and now the projector only shows black and white.
The color wheel has failed in youtr projector. There are 4 pieces of glass in the color wheel which fit togeter in a "pie" formation and they are red, blue, yellow & clear. This wheel is spun by a motor. The glass is glued to the motor's hub, and, when it fails the glass segments are thown off the hub. This gives you a B&W picture because all of the light is allowed to shine through the optics all of the time. Replace the color wheel with Toshiba part no: 23125963. It will be about $65. No soldering is involved, just use care with the ribbon cable to the motor. You will need a no. 2 phillips screwdriver and a set of jeweles screwdrivers to do this.
Posted on Jun 24, 2009
Reset the lamp timer TLP560
can anyone help me to reset my toshiba tlp 560 lamp
there must be a command or conbination of buttons to do this
best regards
Aug 04, 2014 | Toshiba TLP560 Projector Lamp 195Watt...
Have toshiba 2002 projection tv model 57h81 when plug in red light on front where power button is the tv has no sound and no picture please tell me what it means or is too expensive to fix not worth it...
9f2965aa-94e3-4244-a87e-5f0264d7f11c.jpgthe price of the parts depend on the problem I have done a problem part list on to this picture hope this help most of the parts if you type them into ebay the parts will come up check them to the one on the board. sorry had to change the size of the picture as it has to be under 500k. switches are in the red ring if they don't click when you try to turn on or just keep clicking then i would check them. you should be able to download the picture and enlarge the picture so you can see the problem areas i have put on it hope this helps there is a bit of soldering to do to replace them if you need more help please reply.
Oct 21, 2013 | Toshiba 57H81 57" Rear Projection...
I am repairing my sister TV {Toshiba TN61X81}. The original was no picture and with sound. Upon troubleshooting the vertical deflection, ihad move the screen control for all 3 crts to see the horinzontal...
The easiest way I have found to set the screen controls is to tune into an old black and white show, turn the green up until you see retrace then slowly turn it down until it just dissapears then adjust the blue and red for a true black and white picture.
Sep 08, 2009 | Toshiba TN61X81 61" Rear Projection...
Picture went off then Red light blinks all the time
Not an easy fix....requires chassis pull, careful soldering and
replacement of parts and fuses.....would you like step-by-step?
........................T.
Jan 12, 2008 | Toshiba 65HX81 65" Rear Projection...
Toshiba projection tv 50 inch
Need to test F470 and F850 for open.. Simple continuity to see if either fuse is open.. If F 470 is open replace it and C884 and if F850 is open you probably you may need to replace the two convergence amps STK392-110... Large black Ic's screwed on an aluminum heat sink...
Bill
Dec 16, 2007 | Toshiba 50H72 50" Rear Projection...
No picture, but power light and sound OK
The problem you have there was a loss of vertical deflection followed by a complete failure of Q301, the vertical Ic LA7833S.
It may have been in part due to the feed caps located in that circuit and there will likely be NO outward signs of the failure.
The Ic needs to be replaced and the electrolytics in that circuit need to be measured with and ESR meter and replaced if bad.
If it's starting to sound a bit beyond your ability I strongly suggest having a qualified shop do this because you can overheat the vert Ic easily just soldering it in...
If you have a shop do it you might ask what they charge to replace the vertical Ic and ESR the caps in that circuit. Explain to them what you have here with regards to how it went out, dropping to a horizontal line before going completely dead... The more detail you can give the easier it will be for the tech to troubleshoot the problem.
Good Luck!
Bill
Nov 24, 2007 | Toshiba 50H72 50" Rear Projection...
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 46HM84 DLP Black and white pattern..
contact your dealer for service flashfor this symptom.(light tunnel)
Aug 11, 2007 | Toshiba 46H84 46" Rear Projection...
283 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
