Question about Cameras
When i put in my memory stick it says reinsert then i do that then it says reinsert again!
    Guru:
  • 2,178 Answers
Check the memory stick on a computer capable of reading it. If it reads ok, then the camera socket is bad.
Posted on Nov 02, 2010
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
How to fix "reinsert memory
Welcome to FixYa.
There 3 possible causes why do you received an error message " reinsert memory card"
Cause
1 The inserted Memory Stick media is not supported for use with the camera.
2 The terminals on the Memory Stick media are dirty.
3 The Memory Stick media is damaged
Resolution
1 Ensure you are using the supported type and capacity of Memory Stick media for use with the camera
2 Use a clean pencil eraser and lightly rub the Memory Stick terminals to remove any oxidation or dirt build-up
3 Use different Memory Stick media
I hope this steps wil help you to resolve your isuues.
Thank you for using FixYa.
Apr 04, 2011 | Sony Cybershot DSCW310 Digital Camera
I have a memory card that still has memory an my camera is telling me to reinsert the memory stick
Wasn't quite sure what you question was, lemekaralph. Is there nothing said about why the stick should be reinserted? The best idea, based on what I think you're asking, may be to either use a USB card reader or a laptop or PC that has a card reader to load any photos off to a computer and then right click on the stick in the Computer/My Computer Window and click on format. It will clear the card completely and then allow you to put the card into the camera normally.
Make sure you've copied the photos onto the PC if you want to keep them before formatting and, after the stick is accpeted by the camera, reformat it again IN the camera - do that because Sony suggest formatting for best results should be done in the camera.
Good Luck!
Oct 09, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Reinsert memory stick
Are the contacts on the card clean? Is the slide switch on unlocked?
Sep 13, 2009 | Nikon Coolpix 990 Digital Camera
My sandisk memory stick pro duo wont work anymore
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
Sep 11, 2009 | Sony Cyber-Shot DSC-P92 Digital Camera
Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
I have a satellite P20 that does not start up. Power comes on but there is nothing on the screen. Everyonce in awhile it will go on and works great. But 9 out of 10 times I power it up and there is...
Had a similar problem with a Satellite P105. I flipped it over, took out one of the memory sticks (one screw to open the little memory door) and turned it on again and it worked. Then I took out the other one and put the first one in its place. Worked again. Then I moved that stick back into the first slot. And that's when I found that one memory slot was bad.
Jun 28, 2009 | Toshiba (K000006570) Satellite P20 Series...
SanDisk Memory Stick Pro Duo problem
it may be lost, safely remove your hardware befor you get off from the computer
Nov 02, 2008 | SanDisk 2GB Memory Stick Micro M2 Memory...
Reinsert the memory stick...
you will need to re formatt the card and this problem should be solved
Jun 16, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Cameras Logo
56 people viewed this question
Top Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
