Question about Williams 1403622 Gas Compact Heater
Were would i buy a thermocouple for model 5018732 wall furnace in Ontario.
    Problem Solver:
  • 13 Answers
Usually thermocouples are universal, the main difference is the length of the lead which doesn't really matter as long as it is long enough. You can pick them up at a hardware store usually located in the plumbing department close to the gas water heaters.
Posted on Nov 02, 2010
Chimney type wall furnace. The furnace won't start However after switch was off for a couple hours and turn on the switch it started. What is a possible problem?
The problem sounds like the thermocouple is not working correctly. After being off for a couple hours allowed it to cool down and reset. Sometimes you can clean the soot build up from it and it will work again. Sometimes they just need replacing. the thermocouple is what the pilot light flame heats up when you turn on the heater. when the thermocouple gets hot it sends a 20 to 60 millivolt signal to the gas valve to activate the gas flow to the main burner.
Feb 16, 2015 | Williams Wall Heaters: 50,000 BTU/Hr...
I AM WORKING ON A COZY W501E WALL FURNACE AND CANT GET THE PILOT TO STAY LIT. i HAVE CHANGED THE GAS VALVE, THERMOCOUPLE,AND THE SENSOR FOR THE HIGH LIMIT. THE PILOT WONT STAY LIT.
Pretty much the only thing that will do that is the thermocouple not generating enough voltage for the valve to say it's OK.
Usually you need to hold the button for pilot lighting for 60 seconds. You can use a meter to check that it's generating enough power. The thermocouple has to be in the pilot flame properly.
Check this video:
https://www.youtube.com/watch?v=suen7QlJl4o
Gas furnace will not light Thermocouple test with the multimeter
Or see this site:
How to Test Thermocouple with Multi Meter Heating and Cooling
Feb 11, 2015 | Cozy Heating & Cooling
Furnace thermocouple
older standard efficiency furnaces have a thermocouple. mid and high efficency models do not. they are electronic ignition with a hot surface igniter
Apr 16, 2014 | Goodman Heating & Cooling
I have a William Furnace model #1403622 and the pilot won't stay lit. I keep reading it may need a new thermocouple but where do I buy it and how much does it cost.
Hello, you can buy a thermocouple at any heating and cooling store, they cost between 7 and 15 dollars depending on the length of it.
Mar 25, 2011 | Williams 1403622 Gas Compact Heater
Williams wall furnace 5009622 the pilot light will not stay on
The thermocouple is bad and needs to be replaced...
The thermocouple is the copper rod that sticks up into the pilot flame and then screws into the gas valve...
they are sold by lentgh so you need to measure the old one when you go to buy a replacement...
heatman101
Jan 06, 2011 | Williams (5009622) Ceramic Gas Wall...
I need a gas valve for a Dayton model 3E473A wall furnace
you can look for a gas that we go in place of the one you have, try national energy they sell gas valves and should have one to fit your heater , i would change the thermocouple as well .
hope this helps
Dec 08, 2008 | Dayton 511 Utility Heater
Wall furnace troubleshooting
A thermocouple is inexpensive.  Replace if in doubt.  Get a professional in to do safety checks.  You may also want that individual to replace the thermocouple.
Nov 26, 2008 | Heating & Cooling
Williams 1403622 Gas Compact Heater Logo
Top Williams Heating & Cooling Experts
Paul Carew
vance jones
Superior Maintenance
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
