Question about Acer Aspire 5100 Notebook
I have Acer Aspire 5101 Laptop, not boot, This error pops up when starting up: System BIOS Version: V3.0513 Bus: 06, Device: 01, Function: 00 Error Resource Conflict - PCI in slot 03 Bus:06, Device:04, Function:00 Error Resource Conflict - PCI in slot 03 Bus:06, Device:04, Function:01 Error Resource Conflict - PCI in slot 03 Bus:06, Device:04, Function:02 Error Resource Conflict - PCI in slot 03 Bus:06, Device:04, Function:03
    Sergeant:
  • 281 Answers
You need to flash your bios with a new version try the laptop manufacture's site.
Posted on Nov 02, 2010
5 Suggested Answers
SOURCE: Resource Conflict - PCI Network Controller in Slot 02
check for an update of bios on acer.com it will fix your laptop problem....
Posted on Apr 24, 2008
junk9
  • 150 Answers
SOURCE: when starting the laptop acer
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Posted on Sep 08, 2010
I was on this forum because I was having the same issue with a Toshiba A75 "Laptop", and I tried everything on here and on other forums and no luck. I actually just accessed the integrated wireless card panel from the bottom and removed it from its slot and disconnected the wireless wires connected and put it back on. So this has worked for me and my machine post perfectly now. Good luck to all and I hopefully this will be helpful too you.
Posted on Aug 29, 2008
  • 8909 Answers
SOURCE: Bus: 06, Device: 01, Function:
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
Posted on May 02, 2011
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
Sep 08, 2010 | Acer Aspire 5100 Notebook
Al encender mi ACER Aspire 5100 suenan 2 pitidos y en la pantalla me pone: Sistem BIOS Version:V3.13 Bus:06, Device:01, Function:00 ERROR Resource Conflict - PCI in slot 03 Bus 06, Device:04, Function...
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
Aug 16, 2010 | Computers & Internet
I have an Acer Aspire 5100 with Vista Home Premium on it...when starting the laptop acer 5100 it tries to start beeps...and it shows the following page of errors Bus 06, device 02 ,function 00 error...
It might be possible some kinda a BIOS corruption. Let us try this first. ASA computer starts keep on tapping F2, it will enter the BIOS setup utility, then press F9 and then F10, save the seeting and restart the computer. It should resolve the issue. But if the issue still persists, then update the BIOS. Visit the webiste mentioned below:
http://support.acer.com/drivers_download.aspx
Select the model and update the BIOS.
May 07, 2010 | Acer Aspire 5100 Notebook
My laptop wil not boot. Not even in safemode . It has wndows xp that i had recently put on there.. its been doing this for a min but it would come on after a few tries.. This is exactly what happens when i...
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Jul 22, 2009 | Acer Aspire 5100 Notebook
Aspire 5100 resource conflict - pci slot 3
Yuor RAM memory conflicts with each other check RAM memory fix same frequency memory into laptop.
Thanks for using fixya.
Jul 20, 2009 | Acer Aspire 5100 Notebook
Acer aspire laptop wont boot
y dont u dispose it off if it is a problem computer, i guess it is a generic problem of laptop need to replace motherboard or so. avail warrent if it has...
Nov 25, 2008 | Acer Aspire 5100-5033 Notebook
Laptop will not fully start
This could be a device failure. However, try flashing the bios. Do this by going to Acer's support site and creating a bootable disc with the bios or updated bios, if there is any, on it. Then run this in your machine. You will have to use a different computer to do this, apparently. If this doesn't fix the problem, then you will need to take it in and have a tech run down the device that failed.
Jun 26, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 3100 Boot errors and intermittent lock
Try flashing the BIOS to the latest version.
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=1078534&CFTOKEN=55079713
Also, take a can of compressed air and blow out the dust and debris from the CPU air intake and exhaust vents (Go back and forth several time to try and dislodge compacted dust in the heatsink vents)
If the BIOS flash doesn't resolve then you most likely have a NIC failure. Since the NIC is integrated you can either replace the motherboard or get a PCMCIA or USB NIC to use and disable the integrated one in the BIOS (If possible)
Jun 05, 2008 | Acer Aspire 3680 Laptop
Apr 24, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5100 Notebook Logo
2,431 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
