Question about ASUS P4S8X Motherboard
Pc problem with memory
Will only work with 1gb of memory
Bought 2 new strips of 1gb memory will only work with one strip in.
Posted on Jun 16, 2008
Que vergonha sem dryveres para P5PE-VM
Posted on Jun 14, 2008
I'm trying to upgrade memory in my PC. It uses a KV-80 motherboard but doesn't work if I insert two 1GB memory strips
It sounds like you've got a bad memory module, the second 1GB that you're trying to put in. Try replacing your good 1GB module with this new one and see if it reacts the same way.
I looked up your MB manual and it does say it's rated for 2 x 1GB modules.
A slight possibility is that you're trying to put 240 pin memory in the Dimm slot, instead of 184, but that's unlikely because the notch doesn't line up. Another one, also unlikely is that you're trying to put in DDR266 or 333 when your front side bus is running at DDR400 speed.
It's also extremely rare, but you may have to change your settings in the BIOS to get it to recognize the new module. Although that almost never sets off the "emergency siren".
When I updated to 2GB for my 754 motherboard, I bought 2 brand new modules that turned out to be both bad.
Jun 04, 2012 | Abit KV-80 Motherboard
I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
May 18, 2012 | Computers & Internet
I have Acer E500 with 1GB Memory the window did not show complete memory size.see what i got: installed memory (RAM): 1GB (767 MB Usable).
the windows uses 223 MB for the operating system to run smoothly. thats what it means. your ram is perfectly working. any further assistance please ask and rate me Kronoguy
Jul 07, 2011 | Acer Aspire E500 PC Desktop
Will not see the new memory
Try one slot at a time. Make sure a good working stick of memory works on either one of the slots.
Jun 01, 2010 | Acer TravelMate 240 Notebook
Whatis the maximum memory the medion rim2520 pc
Standard Memory : 512MB or 1GB Maximum Memory : 2GB ( 2 x 1GB) Total Memory Slots : 2 Memory Type : DDR2 533MHz (PC2-4200) 200-PIN SODIMM
Oct 08, 2009 | Computers & Internet
I have an acer power f5 which canot accept a 1GB
Try the 1gb chip on its own. (with no other chips)
If it still does not work check your motherboard manual
Make sure that your memory is supported by your motherboard.
You will need to know the type and speed of the memory chip you have.
If the memory is a match and it still does not work it may just be stuffed. Did the memory work in another machine?
Hope this helps
Sep 24, 2009 | Racer AcerPower F5 PC Desktop
I intend to install more 1 mega of memory, but motherboard not recognized it (one dimm 1gb pc3200 cl3 184-pin dimm). Of origin the PC it has been installing 2 dimms of 512 and I intend to add +1 dimm of...
The memory may not be compatible depending on the speed. Try taking out all the memory and just installing the 1Gig stick.. does it work?
If it does then the 1Gig stick is fine, but your PC probably doesn't like you mixing different types and speeds of memory.
If it doesn't work, the 1gig memory module might not be the correct speed your PC wants.
Sep 08, 2009 | Computers & Internet
New ram memory on dell dimension celeron trying to
You should check with the folks at Dell since whoever wrote their technical manuals for this machine can't do basic math. There are 2 memory slots and each can handle a maximum capacity of 512MB, yet they claim the maximum capacity for the machine is 2GB instead of 1GB. Using 512MB modules would probably work.
Jul 06, 2009 | Dell Computers & Internet
My PC won't work with 3Gb of RAM
THE RAM CAPACITY OF THIS BOARD IS
DDR266/200, Max. capacity of system memory: 3GB
- DDR333, Max. capacity of system memory: 2GB
- DDR400, Max. capacity of system memory: 1GB
Oct 03, 2008 | Asrock K7S8X-R3 Motherboard
P4M800P7MB RS2H Foxconn motherboard and 2G memory upgrade
the 1gb memory modules need to be low-density ie chips on both sides. the motherboard can only recognise 512mb on each side of the memory module.
Jun 01, 2008 | Computers & Internet
ASUS P4S8X Motherboard Logo
71 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
