Question about Refrigerators
Samsung rl33sbns1/xeu fridge frezzer - Refrigerators
4 Suggested Answers
  • 4793 Answers
SOURCE: My Samsung Freezer isnt working but the fridge is fine
without checking equipment you can only assume things that may go wrong...1st..try fully defrosting complete unit,clean all vent/drain holes then switch back on and let unit do its thing for 24 hours.then check temperatures are minus 18-20c for freezer and plus 2-5c for fridge (approx)unless you have electrical meters to check, this is just about all you can do..
Posted on Feb 19, 2010
beno8035
  • 4 Answers
SOURCE: i have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Posted on Sep 07, 2012
some1cares_m
  • 5360 Answers
Actually I disagree with that guy. u can check the cold control thermostat, the thermistors, and the air flow vent and knob, my best bet is with the thermistors or the air flow control vent
Posted on Mar 14, 2015
Hi I have a samsung fridge freezer. Sl39wj1/xeu. Doesn't seem to be doing anything no light but is continually flashing f5
not sure what you mean water in fridge and ur assuming? did it freeze everything or not freeze? is fan not running or compressor? any noise or sounds?
Mar 14, 2015 | Samsung Refrigerators
Rsh1nhmh manual
who made your fridge and why is it listed in the "TV Receivers & DVRs" section?
but seriously,
start here http://www.samsung.com/uk/support/model/RSH1NHMH1/XEU-downloads
Nov 18, 2013 | Refrigerators
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
We have a Samsung Fridge Model No: SL39WJ1/XEU - the door is alarmed but now the alarm keeps just going off - for 3 days now and now going off every few seconds. The temperature lights etc at top of...
Even though this video shows a different refrigerator model, I have seen this with Samsung refrigerators (mine for example). I hope this helps.
Nov 22, 2017 | Samsung Refrigerators
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
NO WATER COMING OUT OF WATER DISPENSER ON MY SAMSUNG RS21DCNS/XEU
you either have a kinked water line, or a frozen one. There is a possibility that the solenoid isn't working.
Nov 08, 2009 | Samsung Refrigerators
Hi i have a fridge freezer which is a samsung sl39wj1/ xeu and i need help coz it keeps coming up with f5
water in fridge on shelve from freezer.( I am assuming) Have defrosted and cleaned fridge and freezer removed all visable ice and water. Took off vent in fridge no ice. what else can I check out before calling repair man?
Dec 31, 2008 | Refrigerators
Samsung fridge freezer rsh1dtmh1/xeu
the only way is to remove the middle wheel right at the front this allows adjustment with the 2 feet at the front
Mar 20, 2008 | Refrigerators
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
