Question about Yahoo Mail
On a laptop that has a small screen, when replying, how do I adjust the view area to type in (it's showing 2 line spaces only)
  • 2,386 Answers
You must enhance the display resolution of your computer, it will give you wider space...
Posted on Nov 02, 2010
My phillips 2006 hd tv has a black line across the screen with a snowy freeze
If you have parallel horizontal black lines on a white background, you can see the separation between the lines when it is viewed at close range (Figure 1). As you view the lines from further and further away,the image gets smaller, you eventually get to the point where you can no longer see the separation between the lines, and it looks like one line. Losing the ability to see separation in the lines is exactly what happens when you sit too far back from an HDTV set. If we apply the same principle to an HDTV, a 1080p resolution HDTV has to fit 1920 vertical and 1080 and horizontal black lines separated by the white space on the screen, (that is the pixel grid of a 1080p HDTV display). Furthermore the spaces between each cell of the grid need to be very small in relation to the area each cell occupies, or you will get a screen door type effect. A bigger HDTV can increase the size of the cells and the separation between the cells, so everything doesn't run together when you sit further back.
Performance chip
May 22, 2012 | Philips Televison & Video
Not showing entire image on screen
It's possible that your projector doesn't natively support your display resolution, but to know more it would be best if you could provide the following details:
Projector Model
PC Model
Windows Version
Windows Resolution/Refresh Rate
Display type (if laptop) cloned/extended, etc
Thanks!
Feb 18, 2008 | Sharp XR-10X Multimedia Projector
Cracked screen on lg lcd tv small crack 6in up an 8in from right can still see picture ok but have a 1in white line running down from small impact area and a light grey 1in line across from impact area...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 22, 2017 | LG 32LD450 32 In. LCD HDTV
Small message window on reply page
Grab the bottom line of the Box, and drag with mouse.
Mar 27, 2010 | Computers & Internet
Is there any way to adjust the screen image size? I recently connected a computer to the DVI input, and at 1280x720 there is quite a bit of overscan. Is it possible to reduce the image size?
Change the display settings on the computer desktop, try various sizes.
If using programs like word or firefox change display size with shift/mousewheel. Also change font sizes for best view. Don''t worry about resolution numbers, adjust for good picture.
Mar 02, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Why is my Dell Latitude D620 laptop screen turning white?
You'll have to live with it. It's taken damage, it's not repairable, it's only replaceable. My Latitude screen was replaced after only 2 1/2 years.
Nov 02, 2009 | Dell Latitude D620 Notebook
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Screen adjustment
Adjust the screen area of the computer’s display settings to match the projector’s native resolution. Refer to your projector documentation for the optimum or native-resolution setting for your projector model. If you can't find this information or are uncertain, most projectors support a maximum of 800 x 600 pixels.
• With certain laptops, you might need to disable the laptop display to obtain the best image, especially when the native resolution of the laptop exceeds the native resolution of the projector.
• Font smoothing will automatically generate a cleaner font outline, both on your laptop and on the projector. To apply font smoothing, do the following:
1.
In Control Panel, open Display.
2.
On the Appearance tab, click the Effects button.
3.
In the Effects dialog box, select the Use the following method to smooth edges of screen fonts check box, and then select Standard or ClearType in the list.
If the projected image is dimmer than it was on the laptop, check your projector documentation for information regarding lamp timers. If the lamp life has expired, replace the lamp for maximum brightness.
If the projected image is not rectangular, try one or both of the following:
• Make sure that the projector is perpendicular to the viewing screen.
• Raise or lower the projector.
If the projected image displays vertical lines, "bleeding," or spots, try one or more of the following:
• Adjust the brightness of the image.
• Check the projector lens to see whether it needs cleaning.
• Adjust the sync and tracking on the projector.
Sep 09, 2008 | Panasonic Videoprojector PT-LM1E...
Laptop shows excellent connection but pc doesnt show any connection
you don't need any software to configure your wireless, the manual will show you how, located on line at this address: http://download.microsoft.com/downlo...tion_guide.pdf
good luck and please rate this answer, thanks.
May 22, 2008 | Microsoft MN-700 Wireless Router
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Yahoo Mail Logo
Top Yahoo Computers & Internet Experts
micky dee
Mike
Sunday Ojelabi
Sunday Ojelabi
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
