Is this the right unit? Can it be used with a sleeve?
I just bought an
LG LWHD1006R Wall/Window Air Conditioner 10,000BTU thru the wall/window air conditioner. I am not sure I understand what this means. can you mount it in the window or do you put it in a sleeve. I live in an apartment the sleeve measures 26x22 not sure of depth. I don't know if I purchased what I need. I guess I need to know if this model can be used with a sleeve.
lbr
  • 40 Answers
If a sleeve came with it then it should be used unless you are replacing a unit and the existing sleeve is properly mounted. Then sleeve should have a slight backward angle so that condensation does not drain into the living space.
Posted on Jun 12, 2008
My exist. unit is a very old sears coldspot through the wall mounted in a 12x18 in.exact sleeve. Can i remove unit and replace with FRA052XT7 ?. Exist sleve is vented on both sides & back.This is...
Get rid of the old stuff,too big to be used
Newer unit can't be inside the old sleeve as you call it
Just install the new unit how you see fit, to seal
it up
5000BTU is too small
A 7,200,8,000 or 10,000 BTU is the same size & about
the same price.
Jul 18, 2011 | Frigidaire FRA052XT7 Thru-Wall/Window Air...
Finding a suitable thru the wall air conditioner
Not exactly....if you can half or more of the side vent exsposed then you will be okay...I like the side vent models because they are less prone to recycling the air...they either pull in the side and expell out the back or visa versa...
On the total back models all the air is just pulling and pushed out the back and they are prone to overheating in some wind conditions...the air just recycles...
Of course the main problem is that most people fail to keep their unit cleaned properly and that causes the overheating...
Window Air Conditioners - Clean them every year
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
heatman101
Jul 20, 2010 | Kenmore Heating & Cooling
AF-S80MX Thru-Wall/Window Air Conditioner: What kind of refrigerant does this unit uses? ...
Most new window units are using R-22 or it's most common alternative R-410A - but you will need to check the 'data tag' on the AC to be sure. All AC units have a data tag (either metal or paper label) - somewhere on the AC - which gives you model number, size, voltage, and type of Refrigerant, as well as other info.
good luck!
May 08, 2010 | Sharp AF-S80MX Thru-Wall/Window Air...
I have a lot of water splashing out on the left side of my LG LWHD1800R, and am not seeing any drain from the drain pipe. How can I stop so much water splash from the side vent?
There isn't a drain persay the drain is the holes under the a/c in the window sleeve. There could be a blockage in the drain pain on the a/c itself. This is the pan the coil at the front of the a/c issitting in. The best way to clean this is to remover the unit from the wall sleeve and take it where you can rinse the bottom of the a/c out make sure to clean the area where the coil sits. Do not wet the entire unit only the area where the steyrene at the base of the coil. Also it the wall sleeve is a complete wrap around make sure you clean it also.
Good luck on your repairs
Dave
Dec 03, 2009 | LG LWHD1800R Wall/Window Air Conditioner
Can the LG Electronis LWHD1500ER air conditioner be installed through the wall, what wall thickness max., and is there a sleeve to assist in doing so.
I don't believe that this unit can be mounted in a through the wall application. My database does not show a wall sleeve for this unit. The biggest reason will be the side vents for the condenser heat exhaust. I would stick to the manufacturer suggested window application.
Jun 30, 2008 | LG Heating & Cooling
Trru the Wall Oversized
Drop in a Frigidaire 25,000 btu, 230-volt Electronic Control Air Conditioner (Model #FAS256R2A). It is Way More Cooling than you need, but it is a very efficient unit and will provide quiet, nearly instantaneous room temprature reduction! Width 26-1/2... Height 18-5/8... Wall Sleeve Included... about $450.
Jun 23, 2008 | Frigidaire FAC124 wall/Window Air...
Putting a window air conditioner in the wall
I dont see a problem with these working in the wall, however you will probably need to install a condensate line to drain away the water that will be left from condensation. These items may be purchased from any hardware store.
Hope this helps Ya please rate me
Jun 22, 2008 | Heating & Cooling
Through the wall vs. window installation
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Jun 12, 2008 | Heating & Cooling
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
191 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
