Question about Sharp AR-M207 All-In-One Laser Printer
Sharp AR-M207 error code F2-04 - Sharp AR-M207 All-In-One Laser Printer
tehnik_bdg
  • 91 Answers
SOURCE: Sharp AR-M207 Error Message
H4-00 means heat roller low temperature detection. It usuallly caused by 3 things :
1. The machine hang : You simply reset the error code by pressing : # * C * then input 14 then start.
2. If the error still displayed, open the side cover, feel the fusing unit ( don't touch, it is hot ), if the
fusing unit feels cold then the problem is the heater lamp ( inside the upper heater roller,
connected with anti heat cable and big connector ), you should replace it.
3. If the fusing unit feels warm or hot then the problem is the thermistor ( connected with small cable
and connector ), replace it.
Posted on Mar 04, 2009
SOURCE: Error Call for Service H4-00
# - intrrup key - clear - interrup key 14 print
this all
check fuser lamp, thermost
just
Posted on Oct 26, 2008
vegakitten20
  • 685 Answers
SOURCE: Hooking up my Sharp AR-M207 Printer to my computer
yes you can put in the serial # of the printer and there site will tell u what u have to do
Posted on Nov 10, 2008
SOURCE: Sharp AR-M207 with a F9-00 message
f9-00 means the ar-nb3 and or eb9 print control boards failed to recive all packets involved in a perticular print job. weither its 1 page or 100 pdf tiff raw etc does not matter.
as a printer service technician i can ashure you there is no known all inclusive fix at this time. cycling the machine's power will clear the code.
Posted on Mar 09, 2010
hamzaskilltd
  • 316 Answers
SOURCE: SHARP AR--M207 Error L4-11
1. Main motor lock detection
2. shifter motor trouble
Posted on Jun 01, 2010
MY SHARP AR-M207 DISPLAY ERROR CODE L4-00 KINDLY GIVE ME A SOLUTION
Hi Alafin,
An error code of L4 suggests a motor error. It could be something as simple as a loose cable but it could be a bad motor. I would suggest you call on a local dealer to repair this as you will probably need new parts.
Jun 14, 2016 | Sharp Used AR-M207 Copier Printer Scanner
My sharp AR-M207 is showing error H4.00 call for service i need solution
Enter simulation mode by pushing # * C * then type 14 and the copy button. The machine will restart and the error code will be gone.
Sep 26, 2011 | Sharp AR-M207 All-In-One Laser Printer
My copier is sharp AR-M207 all in one printer is problem E1-00
Communitcation error between the MCU PWB and the IMC PWB. Check connections.
Aug 24, 2010 | Sharp AR-M207 All-In-One Laser Printer
U2-40 error on sharp AR-M207 displayed on the digital display... what do i do
U2 04 EEPROM serial communication error
11 Counter check sum error
12 Adjustment value check sum error (EEPROM)
40 CRUM communication error
this the U2 Code Error
Jun 09, 2010 | Sharp AR-M207 All-In-One Laser Printer
Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Jan 24, 2009 | Sharp AR-M237 Copier
Jan 06, 2009 | Sharp AR-M207 All-In-One Laser Printer
Sharp AR-M207 All-In-One Laser Printer Logo
926 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
