Question about Epson Stylus Photo R300 InkJet Printer
Stylus Photo R280
My printer is not recognizing the ink cartridges. This is just brand new out of the box yet when I turn on or off the printer the same thing happens. As what I see on my computer when I try to print, the ink cartridges are all empty!!! I see a solid red ink light on my printer, I have been using epson products these past years ago but this is the first time I had this problem!
  • yohyoh716 Jun 17, 2008
    Thanks, just called Epson and they replaced the ink cartridges for me and now it is working!
  • 54 Answers
Ink carts being not recognized and you say its a brand new printer?
Heres what you may want to try.
1. Turn off the printer and disconnect the usb cable from the printer
2. Press and release the ink button once you see a solid green light and solid red ink light
3. Open up the printer cover and check out where is the ink cart holder positioned
4. It should stop in the middle part of the printer, you should see an arrow or a ink out marker (ink icon with a / with it( indicating which ink cart is out or not recognized or expended. (This is a usual process on all the epson stylus photo series I had)
5. Press and release the ink button again, it should stop to the next ink cart which you are having a problem and if it doesnt then your ready to reclamp the ink carts.
Just follow your manual usually theres an on screen instructions how to manually replace or reseat the ink cartridges. If the issue persist, you may want to contact epson, ask for a warranty procedure or what you can do next for this. (Either a bad set of ink cart or a bad print head) Good luck!
Posted on Jun 12, 2008
Epson stylus sx 435w does not recognise ink cartridge
my epson stylus photo sx 435 w doesn' t recognize the cartriges of a second brand so that I can't working .How can I reset, if possible, the software of the printer in order to bring it back to the initial conditions.
Feb 17, 2013 | Epson Stylus Sx435w
My Epson stylus Photo R280 prints like its printing double and is very unclear..how do I correct this problem
You need to align/clean your ink cartridge. Look under the Printers, select your printer and go to Properties. There should be a tab for maintenance.
Feb 16, 2013 | Epson Stylus Photo R280 Series
Epson stylus photo R280 won't print due to false low on ink
Try using a soft cloth saturated with rubbing alcohol over the metal contacts. Make certain all residue to include spent ink or oil from your fingers have been removed. Let air dry. If your printers Print Head can be removed separately, that is the way to go when cleaning components. It has been known that Print Heads fail also and need replacement.
Feb 07, 2018 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R280 Inkjet Printer. Parts in
try unplugging your printer for about 5-10 minutes it should reset. and unistall and reinstall the software.
Apr 26, 2009 | Office Equipment & Supplies
Ink not compatiable
Hi. When I fitted the second set of cartridges to my Epson Stylus Photo 1400, the printer failed to recognize any of them, even though they were genuine Epson! I repeatedly installed and un-installed them without success. After giving it a bit of thought, I had a hunch that the contacts on the cartridges might not be making good contact with the contacts on the printer as the cartridges seemed a little loose. I removed each cartridge in turn and after putting some adhesive tape on the opposite end to the contacts, (there are grooves cut into this end, but the tape drops nicely into them when you install the cart) replaced them all. (This had the effect of pushing the cartridges harder against the contacts). Switched on again and all carts worked fine. So it seems that even Epson can't make the cartridges to fit their own printer properly! Having said that it's a great printer otherwise. I hope this is helpful to you.
Dec 05, 2008 | Epson Stylus 1400 InkJet Photo Printer
Epson R280
Don't try to fix it. Put the machine back in the box and return it Epson for a new one. Do it before the machine is 28 days old or they will give you a graded machine.
The error can be caused by the cartridges themselves but best to get the whole lot exchanged.
Sep 08, 2008 | Epson Stylus Photo R260 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
743 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
