Question about Microsoft Windows XP Home Edition
I have microsoft windows XP and hP laptop. I recently had to reformat my hard drive which I have done. Now when I go to my computer, C drive and click on Program Files it says access denied. It never denied me access before. Any suggestions? Thanks, Glenn
  • nancie1186 Nov 02, 2010
    Can you open any files?
  • Microsoft Master
  • 2,386 Answers
You must log on as system administrator, if you made new user it must be administrator to access the c drive
Posted on Nov 02, 2010
  • Glenn Newhart Nov 02, 2010
    How do I sign in as a system administrator?
    Thanks,
  • Computer Links Nov 02, 2010
    go to control panel, the in users, it will give u the users accounts detail or just log off and again log on as administrator
How to install winxp to laptop dell inspiron 910. dell inspiron 910 no hdd but 8gb flash drive
A clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base:
313348 (http://support.microsoft.com/kb/313348/ ) How to partition and format a hard disk by using Windows XP Setup program To perform a clean installation of Windows XP, follow these steps:
  1. Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
  2. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  3. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  4. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  5. Read the Microsoft Software License Terms, and then press F8.
  6. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  7. Follow the instructions on the screen to complete the Windows XP Setup.
Post back if it is not working we will be happy to help you.
Thank you.
Cheers!!!
Jan 09, 2011 | Dell Inspiron Mini 10 Notebook
How to reformat a computer?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 19, 2010 | Microsoft Windows XP Professional
I recently reformatted my computer with windows xp and after everything was done I rebooted my computer but it always gets stuck on the HP screen where I can press ESC to go to boot menu and F8 for...
I am assuming you have already backed up all of your data before doing this. But, it probably hit a bad sector on the drive. To get around this just insert the CD again and boot from the CD. When prompted on the screen, you will want to delete your partitions and do one large partition. That should help.
Oct 26, 2009 | Microsoft Windows XP Home Edition
Installallation of xp
the xp does not recognize the SATA hard disk of your computer, you must install SATA drivers during the installtion of XP.
Sep 16, 2009 | Microsoft Windows XP Professional With...
I need to reformat a dead harddrive
Hi there !!
Method 1: Perform a clean install of Windows XP loadTOCNode(2, 'resolution'); A clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base: 313348 (http://support.microsoft.com/kb/313348/ ) How to partition and format a hard disk in Windows XP To perform a clean installation of Windows XP, follow these steps:
If you have successfully installed Windows XP, you are finished. If these steps did not help you install Windows XP, go to the "Next Steps" section.
Here's the link that contains the screen shots as well:
http://www.buildeasypc.com/sw/windows_xp.htm
Try these steps & hopefully you will be able to format the Harddrive.
Regard's
Anurag Shukla
Sep 03, 2009 | Microsoft Windows XP Professional With...
I cant reformat my hard drive. (Windows XP)
Hi. There are several causes for this type of error. Either your Windows CD is corrupted, hardware is faulty (Motherboard, RAM, hard disk, video card, etc.). You may want to try to reformat your hard drive using another computer first just to isolate if your hard drive is faulty. If you can format it using another computer, try installing windows on that computer.
Aug 27, 2009 | Microsoft Windows XP Professional for PC
HP Pavilion laptop freezes daily and i force manual shutdown
It sound's like there could be a compatibility problem, maybe corrupt file's, or missing start up file's, have you tried doing a window's update, or doing a disc check on the hard drive, go to my computer right click the drive then go to propertie's, click on tool's then click check now for drive error's. if that do'es not work you may need to reformat back to the original xp os.
Apr 16, 2009 | HP Pavilion dv1000 Notebook
How can I reformat my A20m IBM Thinkpad..
Doing a Format on your PC Should Be A Last Resort! Reformatting your Windows computer is usually the absolute last resort and is often done unnecessarily. Before you go through the process of doing a reformat of your hard drive please take a few moments to read through the rest of our website. If you are reformatting to fix problems with your Windows computer it's possible that by using some of the tips on our site, or by downloading or purchasing some of the tools or products that we link to, you might be able to avoid the need to reformat your computer. Because doing a complete reformat of your computer will erase the contents of the hard drive and require you to reinstall all software, reformatting is usually a last resort. Some Computer Manufacturers Make Reformatting Easy Many name-brand PC manufacturers include a restore-disk which makes it easy to reformat your PC and return it to the state it was in on the day you purchased it. Some manufactures supply only a standard Microsoft Windows CD, and some (usually lower-end PC manufacturers) supply neither! If your PC did not come with a restore or reformatting CD, then you will need to take extra steps to format your hard drive and get Windows re-installed. Back Up Your Files Before You Reformat your Windows PC!Because the reformat or restore process erases everything on your computer, it is critical to have a backup of any important files on your computer. You will also need your original software install disks to reinstall any software you have purchased.
Things to do before you reformat your PC hard drive
  • Write down or print out all notes and internet pages because once the format process begins, you will no longer have access to them (or anything else in the PC)
  • As already stated, BACKUP all important files and data! When you reformat your computer everything will be erased!
  • Make sure you have all the CDs and other software. All programs will have to be reinstalled after you format the hard drive. Don't forget about software that came with hardware such as printers, scanners, etc.
  • Write down the brand and information for all the hardware on your computer. Look in the Device Manager and make note of the brand and model of network adaptors, video cards, sound cards, printers, modems, and displays. After reformatting you might need this information to reinstall drivers.
How To Reformat your Windows XP PC If you're ready to take the plunge and format your computer Click here for step by step instructions to reformat your PC.
Security tips: How to prevent viruses
Guide From:
http://grownupgeek.com/reformat
Apr 13, 2009 | IBM ThinkPad T30 2366 Notebook
REFORMATTING HARD DRIVE
can u expalin your problem
Jul 09, 2008 | Compaq Computers & Internet
Microsoft Windows XP Home Edition Logo
63 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
