Question about Celestron NexStar 11 Telescope
GPS not working
Hi guys.
I just bought one of these (last in stock!). Turned it on, pressed 'enter' and the screen went straight to alignment options. Unfortunately none of those options were "GPS align", all I got was 'Sky align, two star, etc....
I went to the 'Utilities' menu to check that the GPS as 'on'. It was.
I tried the old trick of switching the telescope off and on again. Same problem. I switched the GPS off, then on again. Same problem.
Have I got a dud!?
Help please!!!! :-)
  • 1,027 Answers
Nope! Sounds normal. The GPS is used as the surface point and time refrence, but it still needs the star fixes to orient the axis. 2 star alignment is generally for Alt-Az mounting, while you can use 1 star for rapid setup on a permanent equatorial mount.
Posted on Jun 13, 2008
Hi all, Straight to business, My daughter got Stung with an iphone 5c, activation locked, can't get hold of the seller and it's locked to icloud and password etc.. any help would be greatly appreciated,...
Best option is to flash the stock ROM firmware on the phone. Issues with IiCloud, password, activation locked are nutty/naughty ones.
Ok, make flashing stock ROM firmware a last resort.
Attempt a hard reset and see if this helps first.
Oct 13, 2017 | Apple Cell Phones
Hp all in one printer - printer head alignment problem
Try pressing the reset or off button for a few seconds. Failing that, unplug the printer for 15 min. Let me know if it works, if not, then I will guide you through other steps.
Nov 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
How do I reset my hp officejet 6110 all-in-one printer? It keeps asking me to align cartridges.
Press menu and then press the Right Arrow key until you get to maintenance screen then press enter.
Option 2 is you align print cartridges.
Automatic cartridge alignment
Perform the following steps to align the ink cartridges:
1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
1. Press Setup or Menu on the front panel (depending on the model).
2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
If there are no other printing problems and you wish to continue, use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. The information from last successful alignment will be used.
If the message keeps reappearing or other print quality problems occur, service the product.
Mar 30, 2011 | HP OfficeJet 6110 All-In-One InkJet...
The printer prints an allignment sheet every time its turned on.
Bypassing the print cartridge alignment It is possible to bypass the alignment page and use the information from the last successful alignment. Print quality may not be as good, but the product will operate. The table below describes how to bypass the cartridge alignment. Try either one of these: Press and hold the Enter button, and then press Setup or Press and hold the Setup button, and then press Options (or Copy Options ).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 11, 2011 | HP PSC 1350 All-In-One Thermal Printer
How do I align the cartridge after I replace it. The fax printed out a sheet and the lines are not straight. I went to align cartridge and then I am not sure how to adjust the lines
Follow below steps to complete alignment.
  • With the Cartridge compartment cover open, insert the print cartridge into the print cartridge cradle with the contacts facing into the unit. When the cartridge is seated in the print cartridge cradle, push the top of the cartridge towards the back of the unit until the print cartridge clicks into place.
  • Close the cartridge compartment cover and control panel.
  • Press the Start/Enter button.
  • On the keypad, press 1 if the replacement print cartridge is new or 2 if the replacement print cartridge is old
NOTE: When you put in a new cartridge, you must choose 1: New .When you put in a used cartridge, choose 2: Used . This helps you to check the correct amount of ink you have left.
  • An alignment page will print and 06 [01-11] will show on the display
  • Look at the alignment page and select the number under the straightest line, and then press that number on the keypad and then press Start/Enter .
Oct 17, 2010 | HP 1040 Plain Paper Inkjet Fax
Problem web cam aspire 4530
Format is the last solution. We can try few steps !!
I can help you here.Tell me what happens if you restart your PC !!
If it does nothing, try this :-
1.Restart PC and keep tapping F8 to get advanced menu options - use up and down arrow key and choose last known good configuration, select this and press enter.Wait and see if it boots to the desktop.
If it doesnt restart PC and keep tapping F8, choose safe mode from the list of options, press Enter and see what happens !
Awaiting response.
Hope it helps !!
Thanks !
Awaiting response.
Sep 10, 2009 | Acer Aspire 4520-5582 Notebook
Press enter to align cartridges message comes into the window of my HP combo machine and won't change. I reset the cartridges in their holders, turned machine off/on, no go. The machine still prints out...
You should load paper and press enter to align, The message will keep coming back until you let it do alignment or press enter and option buttons at the same time.
Jul 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Put in a new cartridge
i don't have driver
i want to load driver printer hp psc2210
Apr 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Celestron NexStar 11 Telescope Logo
138 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
