Question about Lexmark X2250 All-In-One InkJet Printer
Suddenly has stopped working-sometimes says that a cartridge is missing and shows image of black cartridge. Both cartridges are quite new and the printer has been working well. When I moved the unit however I found a small pool of black ink on the surface it was sitting on. Both cartridges were properly installed and the colours mark a tissue when cartridges wiped which seems to indicate they have enuogh ink as the printer has not been used very much since they were installed.
  • 10,319 Answers
The rubber nozzles that the ink goes through are crack letting the ink to run out. Replacing them will help bring it back the way it was before. The cost to repair probably outweighs the cost or a new replacement printer
Posted on Nov 02, 2010
Lexmark S405 : printer will not print until the black ink cartridge is replaced
Smash printer with axe or sledgehammer. Grin maniacally. After researching on internet,go out & buy new printer that allows you to print till empty & refill again! Obviously not a Lexmark...
Jul 21, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Cartridge not detected or missing message.
did you remove the tape from the new cartridge ?
Dec 23, 2008 | HP PhotoSmart C4280 Laser Printer
Same as some other complaints at your site about this printer/aio
Your printer does indeed have cartridges...4 in fact, along with 2 printheads. 1 printhead is for Magenta/cyan. The other for Black/yellow.
You know where the printheads are. The ink cartridges are below them. There is a door that pulls down to expose all four.
Here is a link to HP Support for changing your ink cartridges: L7580 Ink Cartridge
Consider XL cartridges...they last much longer.
Also, for reference, here is a link to the User Guide for your printer: L7580 User Guide
Nov 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP 5610 - printing fades down the page
the printer carriage might be wearing out, it happens on the 5610's, may be time for a new printer. The fading issue sounds like a cartridge issue. Try a oem?
Nov 14, 2008 | HP Officejet 5610 All-In-One InkJet...
Problem with new ink cartridge
More that likely the refilled ink cartridges are faulty and should be replaced. While some folks have pretty good luck with refilled cartridges, it is generally better to stick with the new ones.
As to the problem with old cartridges, keep in mind that the estimated ink levels are just that - estimates. However, if your printer has an option for cleaning the cartridges, try that before chunking them. Take them out, put them back in, and run the cleaning process. Sometimes the nozzles can get clogged up and running the cleaning process will clear them up. ( DO NOT TRY TO CLEAN THE CARTRIDGES MANUALLY!)
If none of this helps, you will more than likely just need to get some new cartridges. - Graye
Oct 29, 2008 | HP PSC 1410 All-In-One InkJet Printer
Color cartridge
that is most proberly a defective cartridge packermary you need to try another cartridge if it works then return the defective cartridge or else try cleaning the head on the cartridge by using alcohol or spirits and wiping the pins on the cartridge head & the coper part of the cartridge.
Apr 18, 2008 | Dell Inkjet 720 Printer
Lexmark x4720 ink cartridge installation
Stop buying lexMark products, They are not worth the plastic they are made from.
Jan 08, 2008 | Lexmark X4270 All-In-One InkJet Printer
Colour printing
Check the following thread, it might apply to your problem. and just as a printer can be fooled to show a low level ink, I guess it can happen the other way around. http://www.fixya.com/problems-solutions/t103191,p342983/Epson-Stylus-Photo-R300-InkJet-Printer.aspx Good luck
May 19, 2006 | Epson Stylus C64 InkJet Printer
Lexmark X2250 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
