Question about Spidem Trevi Automatic Espresso Machine
No power Have power at the plug but machine won't switch on. Is there an accessible fuse?
  • 515 Answers
Yes there are a fuse inside the machine, you have to take of the top to get it.
Posted on Jul 11, 2008
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
No power on lg washer model wm2032hw
see the causes and fix it. Use the common sense. God bless you
If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch the part testing video at the bottom of this page. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Sep 22, 2012 | LG WM-2032H Front Load Washer
I have no brake lights in my '97 dodge caravan le but i have taillights
Have yoiu changed/checled the lightbulbs? (In other words,do your turn signal lights work? If the front turn signal lights work, but the rear don't, then turn on your four (4) way flashers. If the rear lights still don't work, then all the bulbs are bad. It is rare for all the bulbs to be burnt out at the same time, but it does happen.
If the turn signal/four way flasher lights work, then you probably have a bad brake light switch. However, first check your owner's manual to make certain there is not a separate fuse for these lights. If there is, then swap the fuse for the brake lights for another fuse (or relay) of the same size/amperage. (Facing the hood, the power relay box is located on the right side (usually) under the hood.)
The fuse box is located under the dash, on the driver's side of the car. Usually there is a plastic cover that has to be removed to access the underside of the dash, and then there is a plastic cover that has to be removed to access the fuse box. If you don't have an owner's manual, nprmally the fuses and power relays are normally marked on the plastic covers your remove ot access the fuses and power relays.
If the fuses/relays are good, then you have a bad brake light switch. This is located on a bracket just above the brake pedal. When you push the pedal down, the switch makes contact. Disconnect the plug to the switch, and jump across the plug contacts (not the switch) with a small piece of wire, or if a piece of insulated wire is unavailable, you can use a paperclip, you won't get schocked, just make certain that the paperclip does not come in contact with a ground while you have it plugged in to the plug for the brake light switch.
If the lights stil dont work, check for power to the plug for the brake light switch. If you have power to the plug, the turn signals and four-way flashers work, then my guess would be that you have a broken power wire (probably iside the steering column, or a bad turn signal switch. If the brake lights work whe nyou jump out the brake light switch, then the brake light switch is defective.
Oct 16, 2011 | 1997 Dodge Caravan
I have a washer kemore 600 series, it pumps water in but will not do anything else. Is there a reset button on the motor or pump?
Hello there and welcome to fixya
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? try to unplug for 15 min then reset the home breakeer than plug in the machine again and try Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch the part testing video . at repair clinic.com Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse. or it will fill but will stop after that
Sep 12, 2011 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
My door won't open on my daewoo airpower washing machine. My clothes are trapped!
unplug the machine for about ten minutes and then try to open the door after you plug it in. If the plug is not easily accessable, locate the fuse in the fuse panel for it. i may add after you have interupted power to the machine, you may want to try opening the door then.
Jun 12, 2011 | Washing Machines
How do I gain access to the on/off switch pcb etc? Power to machine but no action at on/off switch. Thanks.
depends on the make/model..If no power then could well be door interlock switch @fault ..Check power outlet 1st then plug fuse ....
Apr 05, 2010 | Washing Machines
Spidem Trevi Automatic Espresso Machine Logo
610 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
ray gallant
nikolay nikolov
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
