Question about Zoeller E282 Nonautomatic Waste-Mate
We have found water on the basement floor 2 of the last three days. when I checked the pump and the float mechanism it seems to be working fine. Last night our iron filter regenerated and the water mixed with permangenate got all over. Again I checked the pump operationally by running the washer and when the pit filled with water the float on the pump activated and started the pump and when the water level went down the pump stopped running. We can't figure out what's going on and why water is ending up all over the basement floor. the home is 2 years old and we've never had a problem before in the basement.
    Top Expert:
  • Zoeller Master
  • 44,971 Answers
The float is sticking when you are not observing its action. I have had the same experience.
Posted on Apr 15, 2017
4 Suggested Answers
  • 63 Answers
SOURCE: water backing up into my basement ejector pump during heavy rain
I have seen this problem several times before. The ejector pump should be in a separate crock in the ground by itself. Someone has installed it in the crock that is meant to pump out drain water. Probably the result of adding a bathroom in the basement. You need to bust another hole in the floor and install a separate crock to solve this problem correctly. If it just started happening go outside and look at he gutters to make sure water is running away from the house and not up against the foundation.
Please rate if this helps-
Posted on Mar 24, 2009
Healeyman
  • 1198 Answers
SOURCE: Ejector pumps started to go off frequently
The ejector pumps probably pump to the same sewer pipe you had rooted. Rooting can do damage. Trees can break into your sewer pipe, jam them up with roots, and let ground water in. The ground water may be following your sewer pipes on the outside back to your house. It costs a lot, but you can have your pipes examined with a tv camera, the rooter people can do that. Make sure your ejectors have check valves, and they are working right. It's easy for something to get stuck in the check, and then water will come back.
Posted on May 01, 2009
SOURCE: sump pump float adjustment
This really depends entirely on you. the higher the water level the less frequently it will run. most motors use more power to start than they do to run so starting less should save you money.
Posted on Nov 21, 2009
Sump pump pumps fine but won't kick on when water in hole. I've installed new float switch to no avail.
what size is the sump? Is it for waste or seepage? What is the make and model of the unit and the float switch?
Feb 24, 2017 | Water Electrical Supplies
I have an Intex 18x48 easy set pool and pump is shutting off/tripping circuit breaker after running for 1 minute for last 2-3 days. I called Intex (after reading questions posted here) and they are...
Pour some bleach (about 2 gallons) around the perimeter and give it a good brushing. May have to repeat in a few days. That should hold fine.
Jun 26, 2013 | Pool & Spa
My DDR7009REE HAS WORKED GREAT FOR A MONTH. BUT NOW IT LEAKES ON THE BASEMENT FLOOR. I SHUT IT OFF FOR 2 DAYS THINKING IT MAY HAVE FROZE UP. TURNED IT BACK ON AND IT LEAKS ON THE BASEMENT FLOOR INTEAD OF...
dehums remove humidity from air inside unit the evaporator sits in drain pan , drain pan has some sort of line or tube witch leeds to the internal collection or bucket thats what you slide out and empty when its full , ther is some sort of sensor or float switch that lets you know wen full make sure unit is draining properly inernaly and full system is working properly
Jul 03, 2011 | Danby DDR7009REE Dehumidifier
Just purchased a home with water ace sump pump.
That's the idea; if you lift the float the water starts pumping because it works off of that float. That type of pump is usually meant for water that is in a tub or bucket, so that when the water reaches a certain height and causes the float to rise allowing the pump to kick on. I use a pump like that to pump our the drained water from my washing machine in my basement, i let the water go into a big 50 gallon drum and then once the drum is half full i have it set so the float rises and pumps out the water. That being said, if you are putting this in your basement at floor level, you would need to get a 10 gallon bucket meant for sump pumps (you can get one at your local home store) and rent a jackhammer if your basement is concrete and put the bucket in the floor and the sump pump in the bucket, this is called a sump pit. Another option is to get whats often called a "floor ******" pump. Its a pump that sucks the water out when it reaches around a half inch of depth and it can be used in several feet of water (I've used these as well, there is no float involved), and it can be set on level ground there is no sump pit needed. The one thing with my pump you may not want, is that it's constantly running because its constantly monitoring for water so that a lot of water will not build up (especially if water can damage some thing in the surrounding area) . You can check out all the types at your local home store.
May 27, 2010 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
My pump won't turn off
If the sump (where you catch the water) was dry, your pump might be air bound.
You say it will not shut off but you dont say if it is pumping. My guess it is is not. You have a local switch, i.e. integral to the pump, right? Not a float switch.
Do this, fill the sump, make sure the switch opening is clear (it works on water pressure) and make sure there is no air trapped inthe pump housing.
I hope this helps.
In my bar situation, I use a float switch and I pump up about 2 feet where the water goes into a stand pipe equipped with a vent. The stand pipe feeds into a hose and leads to a sump elsewhere in the basement where the water is pumped over the side (sorry, that was the sailor in me coming out).
Feb 21, 2010 | Lincoln Lubrication 917 Heavy Duty...
Leaking central a/c unit
All central A/C units have a condensate drain line that comes from just under the evaporator in the Main air supply plenum.
You may have a blockage in that drain line and will have to remove the pipe to clear the obstruction. Try flushing the drain pipe with warm water until it flows easily from the top to the end.
You might have a gravity drain that goes into a floor drain or a french drain along the basement walls. The other typical drain installation is a condensate pump that the water drains into and when the float in the tank is lifted, a small pump turns on and pumps the water (condensate) out of the house either thru a drain hose thru the wall, or into a drain in the basement, etc.
Check the entire drain line and anything connected to it for any possible obstructions and/or blockage.
If you have any other questions once you take a look at your installation, just add a comment and I'll check back within a day to provide more info, based on your input.
I hope you found this very helpful and best regards!
Aug 06, 2009 | Whirlwind FH-778 Air Conditioner
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Water backing up into my basement ejector pump during heavy rain
Mar 24, 2009 | Zoeller E282 Nonautomatic Waste-Mate
Water on basement floor
The song "knock three times , on the ceiling if you need meeeee! This sounds like a slow drain or plugged drain line, just reverse the water flow with a water hose or preassure! (last if its an old system over 20 yrs old you could have a rusted drain pan. try introducing bleach into the system (clorox)!............Thank-you very much!
Aug 25, 2008 | Heating & Cooling
Zoeller E282 Nonautomatic  Waste-Mate Logo
43 people viewed this question
Top Zoeller Electrical Supplies Experts
Craig Butler
Craig Butler
TEKUSER
TEKUSER
Are you a Zoeller Electrical Supply Expert? Answer questions, earn points and help others
