Hotpoint 1100 Aquarius washing machine. all cycles work and drum empties ok. Only problem? - spin cycle is so slow. lost the high speed spin. Can anyone advise me please
Have you checked to see if the brushes on the motor need changing these wear down after alot of use over time.
Posted on Jun 12, 2008
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
I have got a Hotpoint Aquarius + WF740 1400 spin speed. When the drum is moving slow inbetween cycles there is a wereing noise, In the wash cycle it clunks but it's ok in spin mode. When I move the drum...
there could be something stuck between the inner and outer drum, eg. a bra wire a common culprit.
inside the drum you have 3 lifters ( blue pillars). remove one of these by pulling it towards you.this will allow you to see into the inner drum. get a flash lamp and have a good look rotating the inner drum around.
if you see anything get a pair of pliers to pull in out as you cant get a nasty cut.
replace lifter as u removed it.
if bearings were gone would sound like a tractor while spinning.
Mar 18, 2011 | Hotpoint Aquarius WF000 Front Load Washer
I have a Hotpoint WF540 washing machine. When it goes into fast spin, the spin cycle is quite noisy....on slow spin it is fine......could this be a bearing problem? If so how easy are they to replace?
Sounds like drum bearings most cases you need to buy half drum with bearings fitted if your very good at diy no problem if not call engineer.1st check concrete weights are not loose top and bottom.............you can buy parts @ espares.co.uk this will give you idea of cost which maybe quite high.
Apr 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Machine will not final spin
I was given wrong info. the machine did go through the cycle and drain. However, the drum DID NOT revolve at all. Main motor Brushes replaced. Now OK. Thanks.
Feb 15, 2010 | Hotpoint Washing Machines
Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Feb 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Drum will not empty water
sounds like its not going thru the complete spin cycle and empty could the timer control switch its all intergrated in one all the the different application s the cycles goes thru all report back to the timer control switch and when the cycle is complete the timer goes to the next cycle i f the timer is defective it well keep on going reguardless and go to the next cycle unfortunately the cost will run around 250.00 for the part good luck
Aug 10, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius
What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Apr 10, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
171 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
