Question about Cameras
New laptop with windows vista installed. Model compatable with windows 2000/XP. Can this be resolved and allow me to transfer files from my camera to my laptop. Make Technika Model SH-A366
    Problem Solver:
  • 13 Answers
My fuji S700 said to NOT format the memory card and it worked either through the cable download, or by loading the card into the cardreader in the computer. It worked flawlessly under XP, but upon switching to Vista (also on a Gateway), the card must be formatted (before taking pictures) instead of like before. I think it is a Vista thing.
Now I just plug it (the camera) into a DVD burner and burn to disk, and then load the images to the computer, and have a hard copy before Vista has the chance to screw it up and loose anything.
Posted on Jun 13, 2008
Just got a new laptop. Tried to install HP Photosmart C 6280. Installation failed because new laptop has Windows7 and v.9.0.2 uses 2000, xp or Vista. Is there a fix?
Try using the compatability tool that is integrated with Windows 7. Do a right click on the Setup.exe file of Photosmart and select Troubleshoot Compatability. Then select, This program worked with an earlier version of Windows, and then select Windows XP SP2. Run the program and if it works choose the option that tells the system the program installed properly. Hope this helps
Aug 18, 2011 | HP Photosmart C6280 Printer
Panasonic PV-DV402 with Windows Vista
hi there
you can try and check panasonics home site for compatibility issues regard there products to windows vista.
hope this would resolved your problem.
Jan 29, 2008 | Panasonic PV-DV402 Mini DV Digital...
Need software for web camera. I updated windows from vista home to win 7 home 32 bit
HI
Install the same installation file for your web cam in xp or vista
in windows 7 too...
its a trick
in which we are installing this driver in windows 7
in compatibility mode
compatibility mode allows any file on previous versions of windows to be installed in windows 7
For that
>>right click on the file
select properties
check the compatiblity tab
select windows vista
and dont forget to check"Run as administrator"
and apply
Hope this will solve your problem
Mar 02, 2010 | Sony VAIO VGN-NS140E/S Notebook PC
I am looking for a monitor driver for Windows Vista for LT1919
Windows XP and Vista should "auto-detect" the capabilities of this LCD screen.
If not, access http://WindowsUpdate.Microsoft.com
and scan for updates.
When the scan is done, look for "optional hardware" updates.
If Microsoft has a driver, it will be offered for download.
Nov 20, 2009 | Mag Innovision Computers & Internet
I have used Quickverse VErsion 7 Deluxe for years on previous laptops using Windows 98 and Windows XP. However, I have installed it on my new laptop using Vista 32 bit and if I right click on the desk
From their website
Question 1:
Can QuickVerse 2007 run on Windows Vista?
Answer: Configure QuickVerse 2007 for Microsoft Vista Compatibility Mode
  1. Download and install the latest Maintenance Release
    Browse to the Program Files folder for QuickVerse 2007
  2. Configure Compatibility Mode for these 2 files:
    C:\Program Files\QuickVerse 2007\qv11.exe
    C:\Program Files\QuickVerse 2007\QVBookManager.exe
  3. Right-click each file listed above and select Properties on the Menu
  4. Click on the Compatibility tab and make the following selections for both files listed above:
http://www.quickverse.com/Shopfiles/Faq.asp?ID=QV2007WIN
Apr 23, 2009 | Computers & Internet
Windows Vista doesn't recognize cable
XP & Vista require different drivers to run hardware devices.
Visit the Vista compatibility site to determine if your hardware is compatible, by clicking here,
or visit the manufacturer's website to see if there are updated drivers and firmware available for Vista that you can download and install.
Another possibility is to visit Windows Update and run a custom scan with the cable attached and see if you are offered a hardware update for your system that would make it work, but this seems unlikely in the case of a cable...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 16, 2009 | Computers & Internet
TRANSFER TO PC
Hook up camera let windows say find new hardware. FOllow the prompts. Acording to Sony Xp has the driver already unless it is a 64 bit. See Below:
  • The drivers needed to connect most Sony® cameras and camcorders to a computer are already included in the Windows Vista and Windows XP operating systems. With these drivers, you should be able to connect and transfer files to a computer.
    Note: If the your camera or camcorder is not recognized by the computer when connected, you may need an updated driver.
  • Detailed Windows Vista compatibility information is available for Sony Cameras and Camcorders.
  • The Windows Vista Starter edition and Windows XP 64-bit operating systems are not supported.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRHC21&SelectOS=31
Dec 21, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Unable to transfer files from Vista To XP
I know how to do it all you got to do is go to start click on network and copy ur files from vista pc name to the xp name and your done i wish i could make a video but i don't have a camera. if u have any questions email me xbox_chap@yahoo.com
Jun 16, 2008 | Western Digital My Book Essential Edition...
My laptop contains windows vista and i want to install Windows XP
i am using toshiba satellite l300model laptop. My laptop also contains windows vista. i want to install Windows XP as well. Some of my music software does not support Vista. Can you
please help me on how can i install Windows XP and how can i download the
XP drivers. I... Read more
May 20, 2008 | Computers & Internet
Windows Vista?
Have you tried compatibility mode? When installing the drivers, install it manually by right-clicking the setup program and clicking properties and then choose the compatibility tab. After that you can set to Compatibility to Windows XP or 98 and try installing it once again. Usually it is resolved by doing this.
If you want to just transfer photos, your camera comes with a memory card right? For example you have an SD memory card, you just need a memory card reader and you wont need to install anything to transfer your photos to the PC, you just simply plug the card reader to the usb port and insert your cameras memory card and it's as easy as dragging and dropping.
If all else fails, try calling the customer support of your camera and ask for a driver for vista...
Feb 08, 2008 | Lands Phones
Cameras Logo
85 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
