Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Power supply adapter
Need to identify adapter jack center pin polarity for RCA DCM 325
  • 3 more comments
  • Professor S Jun 12, 2008
    OK -- there 's only one "spec". The problem arose because the polarity was not identified on the case at the jack on the back of the unit where the adapter power plug gets inserted.
    Yes the adapter is labeled clearly, but my problem is I don't know if the adapter came with the modem. And now I can tell you I just now stumbled on the answer athttp://www.thecableshoppe.com/ps.asp where it tells which cable modems are compatible with which adapters -- and gives the center pin polarity. And -- it's positive. thanks for your help.
  • Professor S Jun 13, 2008
    Thank you, this is very helpful. It's good to have independent confirmation and I appreciate the trouble you took.
  • Tim Babcock
    Tim Babcock May 11, 2010
    It isn't on the adaptor itself?
    I got the same model at home and I'm on Pacific time. I can find out by 6 pst.
  • Tim Babcock
    I can get you all the specs on that in a few hours
  • RCA Master
  • 2,794 Answers
12VDC 750MA tip positive.
Posted on Jun 13, 2008
Adapter polarity
Boss ME-25, use polarity like boss stompbox.
+ voltage at the ring, and - voltage at the center pin, of the adapter
connector.
At ME-25 DC socket:
Sep 12, 2013 | Boss ME25 Guitar MultiEffects Pedal with...
Cable modem 315
Have a look at the link below for basic troubleshooting techniques for RCA modem
Troubleshooting DCM 315
Oct 13, 2008 | Computers & Internet
I have a very old Maxtor external 200 GB hard drive. I can not find the power adapter for it. On the label, a part of it rads 12V 2A - does that's mean I need to look for a 12 volt, 2 amp power adapter?
Depending on the power adapter, you might be able to pickup one at Radio Shack..
If it is a single pin plug, check near the power adapter jack to see if it shows you polarity of the
center pin, which will either be "+" or "-" Take this information to your local Radio Shack along
with the voltage and amperage requirements
Feb 06, 2011 | Computers & Internet
What voltage and polarity do the ACS-5 speakers require?
Computers always use DC voltage. Computer speakers receive DC voltage from the computer.
DC voltage has a Positive and Negative polarity.
In the power jack of the speaker, the Center pin is the Positive connection. The outer shell is the Negative connection.
Center hole of the DC adapter plug - Positive.
Outer shell of the DC adapter plug - Negative
Voltage 5 Volts DC.
In case you need it,
http://support.dell.com/support/edocs/dta/acs5/
Nov 29, 2010 | Computers & Internet
I NEED A POWER SUPPLY FOR RCA WHP150C HEADPHONES
See this solution:
http://www.fixya.com/support/t558556-input_voltage_lost_power_supply_whp
If you're looking for a generic ac adapter, the specs of mine are: 19vdc @ 200mA, NEGATIVE polarity.
Important...the center pin is NEGATIVE (most center pins are positive).
Jun 11, 2009 | RCA WHP150C Consumer Headphones
Voltage/polarity of power supply for NEC pcmcia 4 port USB2 card
If you KNOW it is 5 volts then you only need to make sure that the amp is higher and never lower. Higher amp only means it can work without getting too hot. But the VOLTS MUST BE precise. For polarity it is MOST common to have the center pin PLUS and outer NEG/GND. When I fix laptops and put the powercord wrong nothing happens. When I get it right then lights go on on PC.
Oct 31, 2017 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
Want to know polarity of Zip 100 DC power supply.
I just connected a new power supply to my zip 250MB, with the center pin as positive - and it worked out well :-)
Dec 18, 2008 | Iomega U.S. Power Supply Drive
Adapter plug size
Wal-Mart ectronics dept. has an "Universal DC Adapter Kit" it will have various size adapter plugs and a variable setting to adjust DC Voltage. It also should have a switch to set the polarity. I used mine to power several different devices. It was well worth the money I spent as opposed to buying a actual DC Adapter. Subsequently, the kit from Wal-Mart was far cheaper than the real deal.
-marshall.
Albuquerque, NM
Aug 28, 2007 | RCA DRC620N Portable DVD Player
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
869 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
David Payne
David Payne
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
