Question about HP J4680 Office Jet All-In-One Printer
My HP J4680 printer is saying that there is a problem with at least one cartridge and it refuses to print. I change the ink catriages. Waht else can I do
  • HP Master
  • 7,733 Answers
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
My printer is printing blank pages.
Either:
* empty ink cartridges
* clogged ink-jets, such that no ink can be sprayed onto the paper
Use the HP software to check the ink-levels in the cartridges.
Run a few "print-head-cleaning" cycles. If still no output, then replace the ink-cartridge(s).
Feb 22, 2011 | HP J4680 Office Jet All-In-One Printer
My J4680 only prints color, no black. Printer is
Your black cartridge is most definitely clogged. You can easily check that by removing the cartridge and press the print head on some tissue. If there is no mark, the print head on your black cartridge is clogged. Now, HP has some kind of software head cleaning. It doesn't always work, but you can try. Here is a link to HP site, referring to your problem: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01361894&cc=bg&lc=en&dlc=en&product=3692888
Read carefully and follow the instructions.
If that doesn't solve your problem, you should buy a new black cartridge.
Also, bear in mind that with ink-jet printers, you need to print something at least once in 10-15 days, otherwise the print head will again get clogged and you will be facing the same issue over and over again. If you do not print on a regular basis, make some kind of test page, that contains black, yellow, magenta and cyan. Print that page once in 2 weeks and your printer will always work fine.
Apr 04, 2010 | HP J4680 Office Jet All-In-One Printer
J4680 printer cartridge problem with color will not print color
Is this cartridge an HP factory new cartridge?
Most companies build logic into the printer to prevent refilled cartridges or third party cartridges from being used.
They do this because they have protect both the print quality and the printer from damage by poor quality ink.
Don
Oct 22, 2009 | HP J4680 Office Jet All-In-One Printer
In the middle of a print job, my cartridge refill stops feeding ink. Printer MN J4680. Does this printer hold the cartridge # in memory in order to stop one from refilling?
HP printers do not remember the cartridge serial number to reject refills (certain Canon printers do though). It sounds like you have an air bubble in the sponge that is inhibiting ink from reaching the print head. I would guess that either you or the store/internet seller that refilled this cartridge hand filled it. These cartridges should be filled under a vacuum to remove air bubbles from the sponge and allow you to fully fill the cartridge (an air bubble takes up space that your ink could be occupying). I recommend Cartridge World or Office Depot for refills. Avoid internet sellers and refill shops that have one giant all-in-one machine that does the filling for them.
Oct 09, 2009 | HP J4680 Office Jet All-In-One Printer
Hp officejet j4680, incompatible cartridge
It is not necessary to buy another cartridge my friend, you can repair it. let me show you how... just take a towel paper, pour some water on and slide the cartridge slowly on, repeat this action 3 times and then slide the cartridge on another towel paper without water slowly and get the cartridge back in the printer.
good luck
Jul 02, 2009 | HP Officejet J4680 InkJet Printer
My printer won't print in color and the color cartridge is brand new?
ok first u check u install the black catriage. with out black catriage they can not colour print..if u have not install the black catriage and only u install the colour catriage they can not print,,that's why u check catriage. it is complusery to both catriage is install in the printer...
Apr 01, 2009 | HP Deskjet D1420 InkJet Photo Printer
After changing the ink cartridge, my printer wouldn't print.
change cartridge from 60 to 60l and printer wouldn't recognize cartridges
Dec 21, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP J4680 Office Jet All-In-One Printer Logo
174 people viewed this question
Clive
Clive
