Question about Nokia N72 Cellular Phone
My phone screen does not display anything anymore. It's blank, but the phone is working.
  • 943 Answers
NB:read to the end before trying any of this and remove your memory card first
the flex of your phone is bad and cannot be fixed by just anybody. it is advised that you send it to a repairer to help you check it and then see if it's just the flex or both the flex and screen. Although this is quite common to some nokia phones but try
(1)switching it off, then back on
if that doesn't work, try,
(2)you can switch it off, wait for some time and see
if it still doesn't work,try
(3)hard resetting(you would lose all data so try using pc suite to back up first).hold down *#7370# or *#7780#. in both cases, you lose all your data and default lock code is 12345(unless if you changed it)
lastly,try this combination.....switch off your phone,hold down the green or call button,the *(asterisk)button,and number 3 button,then switch on your phone.(hold it down while switching it on and don't release until it is fully on and asks you to do some setup. if it's still the same contact nokia or send it for repairs because i dont think a software update can help but feel free to try that out too.hope this was helpful?
Posted on Nov 02, 2010
  • Swamisaranam Nov 19, 2010
    * Just give two to three taps on the front upper left of the screen while it is on.If something is vaguely displayed,problem is ;the data cable to the screen is loose.
    Remove the outermost case of the phone and then look at the left down side of the board with LCD panel.There is a flexible wire with connector there which would have gone off.It is the one which passes data to the screen.
    (Take due care not to short any exposed points with any metal while the phone is open)
    *using some flat thin tool,try to push the header to sit properly on the connector.
    *If you have been using the phone for quite a long time, it's bettr to clean the connector and put it.Remove the 4 screws that you can see around the keyboard and slightly lift the board with LCD panel.The connector will be disconnected and snaps off.
    * Spray some perfume into the female connector(attached to the board below screen)and clean it with a clean pointed painting brush .
    *Put back the male connector (header ) by pushing
Nokia e71 blank screen
If the phone is working good without showing any display on the screen , the first step is change another LCD and if the problem still persist contact mobile repairing shop to change the display IC or check it out all the display related components.Good luck
Feb 01, 2012 | Nokia E71 Smartphone
Nokia 2626 mobile display is not working
the only solution to this problem is changing the screen.
The screen is faulty that's why its blank and cannot display anything.
So go ahead and change the screen and your phone will be back to normal.
Take care.
Mar 18, 2010 | Nokia 2626 Mobile Phone
Display problem
If formatting your phone doesnt help there are three possible problems in order of priority (1) your screen is gone and needs replaced (2) your ribbon cable is gone and needs replaced (3) phone needs flashed, I have repaired the first two above on many samsungs with this fault! Not an easy job! Hope this helps.
Jul 09, 2009 | Samsung SGH-D500 Cellular Phone
Blank lcd screen only lights work,
software update would not do anything to restore the LCD's display, you need to have the phone repaired, it needs a replacement LCD.
Jul 04, 2009 | Samsung SGH-E251 Mobile Phone - Black
My phone is a samsung u700. its screen is blank and its not displaying anything. backlight on . what could the problem be.only light from the
first remove the battery just 5minites .................then display is out try change dis play .......
May 30, 2009 | Samsung Cell Phones
please cntact to your samsung care and its lcd screen goes to destroy or you can format your phone by pressing *2767*3855#
May 27, 2009 | Samsung SGH-U700 Cellular Phone
Samsung G600 mobile phone blank screen
sgh d880 screen is totally blank & everything is ok widout screen. everything is ok when connected to tv output, the screen is displayed on tv bt it is white on phone plz solve my problem.
Apr 10, 2009 | Samsung SGH-G600 Cellular Phone
Phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Mar 09, 2009 | LG VOYAGER VX10000 Cellular Phone
Nextel i880
my phone does not display menue anymore
Jan 15, 2009 | Motorola Mobility i880 Cellular Phone
Internal screen is white
NO YOUR DISPLAY IS DAMAGED YOU HAVE TO CHANGE UR PHONS DISPLAY AND IT WILL WORK EVEN CHANGING THE DISPLAY IF IT DONT WORK CHECK THE DISPLAY CONNECTOR.
Nov 23, 2007 | Motorola Mobility E815
Nokia N72 Cellular Phone Logo
77 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
270rexton
270rexton
