Question about Philips SA4010 MP3 Player
Why is my mp3
Keeps freezing when I turn it on it didn't start meesing up until I plugged it in the apple computer
  • Jesse Roberson
    Jesse Roberson Jun 12, 2008
    why dose my mp3 freeze up when I first turn it on it didn't start messin up until I plugged it in the apple computer
    what do I do jus let it die or what
  • Anonymous Jun 19, 2008
    it does not get start .when i switch on i see a blank cylinder like figure
  • 8,596 Answers
This player is not Mac compatible - plugging it into the Mac caused a reformatting to take place. Upgrade the firmware and see if you have better luck, but this player might eb toast.
Posted on Jul 06, 2008
Iphone 3GS- only get the apple loading screen.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 29, 2009 | Apple iPhone 3G
Ipod touch freezes at the apple logo
mine did the same thing. plug it into the computer. when it's open in iTunes, set the iPod to manual. sometimes when it's automatic, it'll clear itself out/freeze up until you plug it in again. this worked for me. it could be a glich, or their way of getting us to go onto iTunes more often.
Sep 10, 2009 | Apple iPod touch
IPhone 3G keeps saying 'bluetooth unavailable' and 'No Wi-Fi'
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Jul 24, 2009 | Apple iPhone Smartphone
Keeps freezing on me, especially when I forward to
Your best bet would be to do a soft reset of the ipod:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) ipodg1-2.gif ipodg3.gif
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If this does not work then you may have to re-format the ipod in itunes. If you click on the ipod in itunes you should see a RESTORE option on the main page.
Jun 24, 2009 | Apple iPod Photo MP3 Player
My mini ipod freezing, showing charger sign i could not turn it to menu
I would attempt putting the ipod into disc mode and see if your ipod is recognized by the computer after you reconnect it. I have researched this issue and found a knowledge base article on apples web site that may help you out with this.
Here are the steps to do it...
Putting iPods with a Click Wheel into disk mode
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
If it won't go into disc mode while not connected to your computer, try doing the above steps with it already connected to you computer.
If none of these steps work, it is sadly probably time to get a new ipod. I hope that it does help you out though. Good luck :)
Apr 22, 2009 | Apple iPod mini M9160LL/A MP3 Player
Ipod touch games keep freezing
all i can say about this is there is nothing you can do except contact apple inc and ask them about it but if you want to play games you may have to buy a new one
Feb 10, 2009 | Apple iPod touch
Ipod freezing
Reset: hold center button and menu until apple logo appears.
Jul 05, 2008 | Apple iPod classic MP3 Player
Hey my name is jesse
Sounds like a firmware problem.
Run the Philips Device Manager to repair the device. This will format the player and re-load the corrupt firmware.
The player is not Apple compatible so don't plug it in to one.
Jun 16, 2008 | Philips SA4010 MP3 Player
Ipod nano keeps freezing
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
www.apple.com/support/ipod/five_rs/
let me know if you need more assistance.
Apr 24, 2008 | Apple iPod 4th Generation MP3 Player
IPod 30 GB stopped working
http://www.apple.com/support/ipod.five_rs/
If there is no effect, then you have to contact apple, or your dealer for repairs, becouse a part is most likely damaged.
If you need more assistance let me know. Good luck.
Jan 13, 2008 | Apple iPod MA446LL/A MP3 Player
Philips SA4010 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
