Question about Epson POS TMT88IV Thermal Receipt Printer
My epson tm t88iv is printing too much paper, it prints the recipt info on it but then gives me 6 to 7 inchs of un needed paper
SOURCE: Epson TM-T88IV causing small margins when printing to Lexmark 250dn
PRINTER WORKS BUT prints the moment I scan a item,WHICH I DONT WANT. I WANT IT TO PRINT ONLY IF I NEED TO
Posted on Feb 03, 2008
SOURCE: EPSON TM T88IV
The TM-T88IV printer is a thermal printer and does not have ink or a ribbon.
If the printer is not printing you may have the wrong type of paper in the printer. You must have thermal paper in order for the printer to work. Paper for a dot matrix printer will not work in this printer.
The printer has a self-test that you can perform by turning the printer off, holding down the Feed button and turning the printer on. A test strip will print. Press the Feed button again to print a longer test strip.
Posted on May 16, 2008
ohms
  • 1879 Answers
SOURCE: tm-t88iv epson made prnter driver for win 2003 server r2 std
Epson POS driver will not install on a Win2K3 machine due to the InstallShield Wizard w/c checks if your running XP/2K or not.
Download the driver from EPSON POS site & extract the contents first on an XP machine.(Installing the driver will create a C:\Epson folder where ACTUAL driver is extracted).
Posted on Mar 06, 2009
  • 233 Answers
SOURCE: paper advances only 1 inch, cuts, no printing
I have problems with USB docket printers with certain packages how I get around it is I share the usb printer as a network share then I issue this command on the command line
NET USE \\COMPUTER_NAME\SHARE_NAME COMX:
where X is an unused comport. I then install the printer as a standard serial printer in the software package. I have had particular trouble with that model of printer and its solved for me in the past. Another note is if the computer is not on a network you can install a 1394 dummy connection that way the network is still accessible. Comment if you need help on that.
Dont forget to rate me!
Cheers!
Posted on May 06, 2009
  • 71 Answers
SOURCE: tm t88iv print slow
This is definitly a driver problem. Change the driver to one that is compatible with Win XP.
Posted on Jun 03, 2009
How to repair no print of pos printer epson tm t88iv?
did you try the basics cleaning heads , running test setup for the dot matrix printout out , changing ink sometimes ne packages sold are garbage.
Sep 05, 2014 | Epson Tm-t88iv Black Thermal Receipt...
What can i do to enable my printer's beep in windows 7
Have you installed the windows 7 driver obtained feom epson comany?
support.epson.com
Jun 30, 2014 | Epson TM-T88IV Thermal Printer -...
What should I do, to not have much paper loss?
can u try printer with standalone pc
or with another single pc
Print is blank on middel side
check the margins of what you print..then check when you click print it will show the dialog box prompting you that you will print the blah blah blah...then click properties,,another dialog box will appear check if the page layout of your printing document and your printer settings are the same...hope it can help you..
Feb 06, 2010 | Epson TM-T88IV Thermal Printer -...
My epson TM-T88IV printer is not working... I printed a self test which says "buffer is full"...?what does that means and what should i do now
it sounds like the ram on the epson has gone bad... contact epson support tell them about the buffer and ask if you need to change the internal ram on the epson...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 24, 2009 | Epson TM-T88IV Thermal Printer -...
Epson t88iv error codes 32
Did you set it up using Epson's receipt printer drivers? If so, right click on it and choose properties. Under the PORT tab, check and make sure it is set for proper port (LPT1, COM1, USB, etc). If you make changes, click APPLY, then OK. Then Right click, PROPERTIES, Print test Page. If you can't get test page to print, your wasting your time sending codes to printer.
Let me know if you need more assistance.
Aug 31, 2009 | Epson TM-T88IV Thermal Printer -...
Tm t88iv print slow
Jun 03, 2009 | Epson TM-T88III Printer
EPSON TM T88IV
May 14, 2008 | Epson Stylus C66 Photo InkJet Printer
Aug 03, 2007 | Epson TM-T88IV Label Printer
Epson POS TMT88IV Thermal Receipt Printer Logo
1,488 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
