Have you got a boiler manual for a Vokera compact 24. I am requiring the heat exchanger replacement procedure. Thankyou. Mr Robert Atkin
2 Suggested Answers
PSITECHNICAL
  • 71 Answers
SOURCE: No heating and no hot water, my boiler won't fire up
If there is a hi-limit switch, maybe it's open, reset the switch, and monitor the temperature, if the temp. increases over the set temp. replace stat, and clean lime off from the tank, if does not have a filtering system
Posted on Apr 21, 2009
I got vokera excell 80 sp boiler ,after above tamprature 70 its turn off then i have to turn off after 20min i turn on then it work but again after som e time it cut off pls help
It could be the boiler is overheating and has to cool down before it can come back on. Look at the pump and make sure it is on speed 3, also drain some water and make sure it isnt dirty if it is you could have a blocked system that requires powerflushing.
Dec 13, 2014 | Water Heaters
Vokera aav leaking
Robert, i'm sorry to say but the AAV's are machined parts and the seal should not have been broken by removing the cap. The floats are set perfectly and you would have been easier replacing the whole vent. You could have isolated all the pipes under the boiler and just drained the boiler down by releasing any pressure by the pressure release valve. You may need to buy another AAV and start again.
Apr 06, 2014 | Water Heaters
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
MY VOKERA BOILER IS NOT WORKING I HAVE NO HOT WATER AND NO HEATING
try check in the water pressure on the boiler should be on 1.5 bar
Jun 01, 2010 | Heating & Cooling
Apr 21, 2009 | Heating & Cooling
Loss of hot water
usually with a loss of hot water on a boiler and the heating still works ok means the heat exchanger is blocked and needs replacing or cleaning. it could also be a faulty sensor.
Jan 25, 2009 | Heating & Cooling
Heating & Cooling Logo
279 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
