Question about Kenmore Oasis HE 27082 Top Load Washer
Keep getting oL on the error code, load got off balance opened the top to re-balance load. has not worked since doing this. what do we need to do to fix this the repair man was just here, replaced main board, did not fix the problem. HELP!!!
    Genius:
  • 1,417 Answers
Top loading washing machines can emit loud noises and vibrations if they are not properly balanced. Imbalanced machines are the result of large loads of clothing that rock the machine causing one or more of the feet to rise off of the floor. Front loading washing machines do not have this problem because there is no side-to-side motion. Kenmore top loading washing machines have self-leveling feet on the rear of the machine and adjustable feet on the front of the machine.
Instructions Things You'll Need:
  • Level,Another person,Wooden block or brick,14 mm wrench.
  1. Unplug the washing machine's power cord from the electrical socket. Pull the washer away from the wall, or out of the laundry closet, so that it is easily accessible.
  2. Grasp the top back of the washer on both sides and tilt it forward until the back feet are off of the ground by 4 inches. Lower the washer gently back to the ground. This maneuver, adjusts the self-leveling rear washer feet so that they are fully extended. You may need the assistance of another person to do this.
  3. Place a level on top of the washer near the front edge. Look for the air bubble in the level to determine which side of the washer is out of balance. The side that the bubble leans toward is the side the needs to be raised.
  4. Move the level so that it is positioned along the side edge of the washer and check to see if it is level from front to back. If it is level, move it to the other side of the washer and see if it is level.
  5. Lift up on the front of the washer and insert a wooden block or brick under the front bottom edge.
  6. Crouch down on the floor near the front foot that needs to be raised. Use your fingers to twist the threaded foot clockwise to retract the foot and counterclockwise to extend the foot further. If necessary, adjust the other front foot as well using the same method.
  7. Lift up on the top of the washer and slide the block out from under it. Place the level on top of the washer to check that it is level. If the washer is not level, replace the block and continue adjusting the feet until the air bubble is centered in the level.
  8. Crouch down on the floor near the front of the washer and use a 14 mm wrench to twist the metal nut on each front foot counterclockwise. Twist each nut until each is tight against the washer and will no longer move.
  9. Plug the washer's electrical cord back into the wall.
Good luck!.
Thank you and thanks for using fixya.
Posted on Nov 02, 2010
When machine goes into final spin cycle it gives me a OL code
OL means the washer is overloaded or there is excessive drive load. Go to the link for a full explanation of the OL code and its repair. What might be causing the OL error code on my Whirlpool Cabrio washer...
Oct 12, 2016 | Whirlpool Washing Machines
Will not balance
Make sure the inner basket "floats" up and down freely. Reach in and pull up on the rim of the basket. little force should be used to lift the basket off the hub. If not an overhaul might be needed. This is a common problem with earlier versions of these machines
Mar 10, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
OL code and fixing it?
The machine may have a defective overload sensor.
Jul 21, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Getting oL code even after diagnostic check
OL, usually means Over Loaded. It is an error code thrown up by the on board computericon1.png.. generally when TOO much wet weight is in the bowl.
This condition is could be caused by faulty solenoid or solenoids at the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity will indicate a faulty solenoid and the inlet valve assy will need to be replaced.
Try unplugging for 12 hrs before reconnecting
If the problem continues then the controller board is damaged and will need to be replaced.
Jan 13, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Tub does not move during wash cycle;just keeps filling;timer jumps from 25 to 4:then drains;flashes OL(small loads)
First, OL/UL stands for "Overload", so in other words, the washer things the tub is too hard to move because it's overloaded and the motor is struggling or the unit is way out of balance causing the washer to struggle. The most common problem is a nut below the inner tub that needs to "float". Floating is when the tub fills up with water to a certain level the inner basket will rise about 1 inch from the center agitator. What this does is disengage the basket from the motor so that the agitator can rotate independently from the basket. If the basket does not float then when it tries to agitate the whole basket will turn back and forth at the same speed as the agitator and this will cause the OL/UL error code.
Nov 21, 2012 | Maytag Bravos MTW6600T Top Load Washer
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
The machine constantly displays the oL code when it r
Hi Randall:
If your the error reads OL, it's "overloaded" and you need to remove some items to delete this problem.
Definitivelly, this flashes when the machine or motor control detects a load size that exceeds the washer's capacity. To clear the error open the door lid and restart the cycle by removing excess laundry. If error doesn't clears then unplug the washer for 5 at 10 minutes and check.
Jan 30, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Why does my washer keep saying OL?
Hi
Error OL means that the washer has sensed an overload (OL) condition. It can also be a false error code appearing due to faulty lid switch. Sometimes this error code appears when lid is not closed/opened properly. You can check the lid switch for any disconnections, if the connection to lid switch is fine then use a multimeter to check the continuity of the lid switch. If the lid switch is fine then there is a piece of clothing stuck between inner basket and the outer tub. Disconnect the washer from the power outlet and then try moving the drum with your hand and check if it turns freely or is offering any resistance. If it is not moving freely then it is due to rusted drive shaft or motor. Hope this helps... Please post back if you need more assistance.
Daniel
Feb 10, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Code ol
Hi
Error OL means overload. oL flashes when the machine/motor control detects a load size that exceeds the washer's capacity. To clear the error open the door lid and restart the cycle by removing excess laundry. If error doesn't clears then unplug the washer for 5-10 minutes and check. Hope this helps... Please post back if you need more information.
Daniel
Nov 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I GOT ERROR CODES F32(LD),F70(OL).HOW I CAN FIX IT?
Kenmore Elite Top load washer machine. Error "OL" does not spin fast enough. Clothes are still very wet. I have checked the machine is sitting on even surface and well balanced from all sides. Any idea(s) ???
Jun 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
