Question about Sony KP-57WS510 57" Rear Projection HDTV
Can't adjust convergence and fishbowl effect to picture
I can't adjust the convergence on my TV either manually or with the flash focus. Here's the problem, in the center my guns are aligned perfect, but towards the edge of the screen the three colors get further and further away from each other, giving it a fish bowl look. I already replaced the IC's and still nothing. I was wondering what else it could be.
  • JAXMAN63 Jun 17, 2008
    VERY SIMILAR EXPECT THAT NONE OF MY CROSSES ARE ALIGNED & CAN'T BE ADJUSTED.
  • gatorgetter Jul 04, 2008
    i have the exact same problem and don't have a clue how to fix it ,i wonder how much a tv store would charge to fix it....
  • Sony Master
  • 8,617 Answers
Chances are the 4.7 ohm 1/2 watt resistors are open and the s.5 amp picos in line with the resistors may be open as well.
Posted on Jun 12, 2008
How do i fix a color alignment problem?
Tries push the button said FLASH FOCUS or manual + - convergence alignment adjustment?Yes,n o,used?The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?The tv have a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too on the convergence board,must replaced these parts to fix it.To solved tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 27, 2011 | Hitachi 46F500 46" Rear Projection...
The magic focus does'nt seem to reset the auto convergence on the tv. Do you have any sugestions
The Magic focus button,not in effective anymore.The tv is 100% have convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 07, 2010 | Hitachi 46F500 46" Rear Projection...
Colors are separated red, yellow and green so picture is blurred
lgray1010,
Try using the Flash Focus to/or manually try to dial in the convergence. If you are unable to focus the TV using its convergence adjustment it's time to call the TV repair guy. Figure on between $250.00 and $400.00 USD.
-Chris
Aug 24, 2010 | Sony KP-57WS500 57" Rear Projection...
Flash Focus does not correct convergence problem and i cannot manually adjust the red convergence to proper alignment. Red does not move laterally only vertically. Picture is offset to the right with red...
No,any colors lines mis alignments.The tv convergence board parts are dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts must be replace on the tv convergence board.To solveved convergence problems.The shop,will cost u $300-350 for parts and labors.
Aug 10, 2010 | Sony KP-51HW40 51" Rear Projection...
I have a sony 60 inc rear projection lcd. the tv turns on ok, however, the picture and sound goes off and then comes on again. this happens every 15 minutes or so.
hello do these checks first Adjust the Picture setting in the Video menu (see page 49).
❏ Adjust the Brightness setting in the Video menu (see page 49).
❏ Check antenna/cable connections.
❏ Adjust the convergence again using FLASH FOCUS (see “Adjusting the
Convergence Automatically – FLASH FOCUS™ –” on page 33). if this don't work get back to me and we'll try somethink else thanks
shaun
Oct 13, 2009 | Sony KP-57WS500 57" Rear Projection...
Focus issue after replacing convergence IC's
pull the fron grill off the set then remove the cardboard covering the hole that is in the front of the set you will find a square box that has 6 controls on it adjust the focus for the red, blue and green crts, do not adjust the three marked screen control.
Sep 10, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony TV losing focus
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 17, 2009 | Sony KP-65WV600 65" Rear Projection...
One half of picture is distorted
to create the total geometry in the tv is needed a system called Convergence.Convergence amplifiers are damaged in this unit, magic focus cannot work because magic focus works to level computer and controls the amplifiers damaged. this repair is for a technician because an adjustment is needed after the amplifier's replacement.
Oct 09, 2008 | Hitachi 61SBX59B 61" Rear Projection...
Fishbowl effect in my image
Consider moving the camera further from the document, and then using the zoom (with a tripod) to close in on the document. You may also need to use a "book holder" with this technique. The A710 also has many manual features that you can tweek. Consider using manual focus to ensure sharpness in the image of the document. Also try varying Shutter and Aperture priority (Tv and Av) settings. Recommend first doing this at home to find what works best before going to the library.
Jun 26, 2008 | Canon PowerShot A710 IS Digital Camera
Sony KP-57WS510 57" Rear Projection HDTV Logo
143 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
