Microtek ScanMaker i320 Flatbed Scanner Logo
Posted on Nov 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Good afternoon, When I scan the image on my scanner and try to open it on my program called Irfranview it comes up as two pages. I do not know if that is because of the scanner or the program. Can you please send me some information on it. Thank you very much.
Anonymous
Level 2:
Sergeant:
  • Expert 139 Answers
  • Posted on Nov 02, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
139
Questions
0
Helped
35434
Points
516
Open with Windwos Fax and Picture viewer and see if the image is displayed in 2 pages.
Anonymous
Level 3:
  • Master 613 Answers
Anonymous
Master
Level 3:
Answers
613
Questions
0
Helped
124655
Points
1918
Look into the setting for the program and the computer. Make sure you do not have it set way high in Megabits. Look for a page break in settings. Look for a view to see a preview and reset.
3answers
Document is scanning upside down
Easiest way to confront this problem is to rotate the material being scanned.
If you find the image of the item is being inverted then simply rotate the material being scanned by 180 degrees.
Additionally most scanning software will have a ROTATE function where you can rotate the image of the scanned material, usually in 90 degree increments which can be useful for editing purposes. You may find this function under Edit or Image in your scanning software.
Good luck! William
2answers
Scanning problem with Epson/Perfection 4490. Husband scanned something at 3600 dpi and can't reset size. Think pixel levels are too high now to scan and submit pix on ebay and also image that shows up on...
It sounds like your husband chose full scan mode in Epson Scan, the software that comes with the scanner.
To change this:
1. In the top right corner, change the mode to Professional Mode.
2. In the dialog box you will see a resolution selection area.
3. Change the resolution to 300 dpi for Web/Ebay pictures.
Another solution is to change the pictures using a program called Irfanview. It is free. You can open a picture and under the menu item Image, slect Resize. The pixel size of 640 width is good for Ebay.is program.
http://www.irfanview.com/
Here is the link for th
3answers
I want to scan text from a page.help me
Actually, there is an OCR tool that can help to scan the image and convert to text form which is Bitwar Text Scanner. It utilizes the Text Recognition and allows users to copy text from a screenshot or photo to word easily.
So first, all you need is to take a picture of the page and then continue with the steps below to copy text from image easily.
How to Copy Text from Image with OCR Text Scanner
Not many users know that OCR is a very reliable and useful tool that can help users when it comes to extracting word from a screenshot.
Step 1: Open the Screenshot file and Bitwar Text Scanner at the same time.
Step 2: Choose Screenshot OCR tool and Draw the textbox to capture the text from the screenshot image.
Step 3: After finish drawing the textbox, the OCR tool will Convert the screenshot to text format.
Step 4: Choose Copy to extract the text or Compare to compare the OCR results with the screenshot.
Start OCR Now!
OCR Text Scanner is an essential tool in our daily life as many industries are using OCR technology to enhance their industry efficiency. Besides, Bitwar Text Scanner also supports many operating systems such as Windows, iOS, and Android.
3helpful
2answers
Scanned image is blank, although the page inside the scanner has text &/or picture.
Scanner contains Unlock botton below it, just unlock it it will scan fine.
Vikrant
5helpful
Scan multiple pages to email
Do you have Microsoft Office?? If you do try this:
First, gather the paper you want to scan. If your scanner has anADF, you can load a stack of pages at a time. The first time you scan,Document Imaging detects the ADF for you.For more information about the ADF and whether your scanner has one,see the documentation that came with your scanner.
You will also want to sort your paper; if you have color pages thatyou want scanned in color, sort these in a separate stack from theblack and white pages. Load your first page, or first stack of pages(with an ADF) in your scanner.
Then, start Microsoft Office Document Scanning (the scanning component of the Microsoft Office Document Imaging program.)
  • On the Windows Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Scanning.
Tip If Microsoft Office Document Imaging is already running, you can start the scanning component by clicking Scan New Document on the File menu.
Set up your scanning optionsIn the Scan New Document dialog box, do one or more of the following:
  • To view your scanned file(s) in Document Imaging after they have been scanned (recommended), select the View file after scanning check box.
  • If your scanner is equipped with an ADF, click Scanner, and then select the Use automatic document feeder check box.
  • If your scanner is equipped with an ADF and you have double-sided originals, select the Original is double sidedcheck box to scan both the front and back of multiple pages. Place thepages in the feeder so that the page fronts are scanned first.The Microsoft Office Document Scanningdialog box will appear after each scan, allowing you to turn the pagesover and scan the page backs. Document Imaging automatically collatesthe pages in the correct order after scanning is complete.
  • If you have a true duplex ADF (one that automatically scans both sides of the page), do not select the Original is double sided check box. Instead, in the Scan New Document dialog box, click Scanner, and then select the Show scanner driver dialog before scanning check box. When your scanner driver dialog box appears during scanning, select the proper duplex settings.
  • If you want to scan pages manually, select the Prompt for additional pages check box. Office Document Imaging will pause after each page is scanned, allowing you to place the next page in your scanner.
  • By default, optical character recognition (OCR) is performed onyour document during the scanning process. Although performing OCR addstime to the scanning process, it also has the following benefits:
    • When you open the scanned document in Microsoft Office DocumentImaging, you can search for recognized text in the document, copyrecognized text in the document to another document or program, andsend recognized text in the document to Microsoft Word, withoutperforming OCR manually.
    • You can have your scanned files saved with an automatic filename based on the first words on the page (this is the default.)
    To turn off OCR during the scanning process (you can perform OCRmanually in the document in Document Imaging after scanning), do thefollowing:
    1. In the Scan New Document dialog box, select the preset you want to use, such as Black and white.
    2. Click Preset options, and then click either Create new preset (and then type a name for the preset), or click Edit selected preset.
    3. On the Processing tab in the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned image check box.
Select location, name, or file type for the scanned filesPart of the scanning process is to save a scanned page to a file. Bydefault, when you scan multiple pages, the pages are saved in one file.If you want to save each scanned page as a separate file, select thenaming convention for the scanned files, or change the location or fileformat of the scanned files, do any of the following:
  3. Do one or more of the following:
    • To save each scanned page as a separate file, select the Save each page as a separate document check box on the Page tab.
    • To change the location for the saved files, click the Change button on the Output tab, and select a location.
    • To select the way the individual files will be automatically named, click one of the File Name options on the Output tab. (If you have turned off OCR during scanning, you will be unable to use the Auto name based on first words on page option.)
    • To select the file format the scanned pages will be saved in, click the Advanced button on the General tab, and select the options you want.
  4. Click OK.
Scan your pages
  1. In the Scan New Document dialog box, make sure the preset you want to use is selected, and then click Scan. If you selected the Original is double sided check box or the Prompt for additional pages check box, the Microsoft Office Document Scanningdialog box appears periodically to let you know that the scanner hasfinished. You then have the option to continue scanning (place anotherpage in a scanner that doesn't have an ADF) or turn your page or pagesover to scan the other side. Arrange your page or pages as desired, andselect the option you want to continue scanning.
  2. When all pages, all sides have been scanned, click Done in the Microsoft Office Document Scanning dialog box.
  3. To scan additional pages, review the Get started section above, and then repeat the instructions in this section (Scan your pages.)
Organize pages in the saved file(s)Now that you've finished scanning, it's time to take a look at theresults. If your scanned pages are not open in Document Imaging, do thefollowing:
  1. On the Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Imaging to start Document Imaging.
  2. In Document Imaging, click Open on the File menu.
  3. Locate the file you want to open (by default, the scanned page(s)is saved to the My Documents folder with an auto filename based on thefirst words on the page, such as Page1of.tif) and then click Open.
  4. Repeat steps 2-3 until all of the files you need are open.
You now have an online version of your stack of paper. Here are a few tips to get you started organizing pages.
  • Rearrange pages within a document In the thumbnail pane (thumbnail pane: Presents the current scanned document as one or more small images.), select one or more pages to move. Click any selected thumbnail and drag the selection to the new location in the thumbnail pane.
  • Copy a page to a new document In the thumbnail pane, select the page you want to copy. On the Page menu, click Copy Page. Switch to the Document Imaging document into which you want to insert the copied page. In the thumbnail pane, select the page that precedes the location where you want to paste the copied page. On the Page menu, click Paste Page.
  • Delete a page In the page pane or the thumbnail pane, click the page you want to delete. On the Page menu, click Delete Page.
For more information about scanning or organizing pages, see Microsoft Office Document Imaging Help.
The papers that were once cluttering your desk have now beentransformed into electronic documents. Within these documents, you canarrange pages, move pages to different documents, delete pages, printpages, add annotations, copy text to other Office programs, or send apage to someone in email. And still have room on your desk for yourcoffee.
My scanning files are to big
Since there's not much information, I'm going to have to make a lot of assumptions with this solution.
The basic issue you have is not the scanning, it's the scaling after the scanning. Since you do not indicate what software you are using to scan the image, I can't be certain without knowing what you're using, but most of these scanning packages allow you to 'resize' or 'scale' the image. How much to scale depends on how large the original is, and how small you need the final version, so some experimentation may be in order. As an example, with my scanner, I typically resize to about 50% of the original.
If you don't have that option, most graphics programs allow this fairly easily (you simply save, then open the scanned image in the image editor and perform the scaling there). Or, some programs even let you resize without opening the file, such as Microsoft's free Image Resizer tool (http://download.microsoft.com/download/whistler/Install/2/WXP/EN-US/ImageResizerPowertoySetup.exe) which allows resizing by right clicking on the file name.
2helpful
How to scan from dell926 printer
Hi here is the user guide for your printer
Download it here
http://support.dell.com/support/edocs/systems/prn926/en/ug_en.zip
How to Scan
Scanning Single-page Documents or Photos
  1. Turn on your computer and printer, and make sure they are connected.
  2. Load your original document or photo.
  3. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 926.
  4. Select Dell All-In-One Center.
    The Dell All-In-One Center opens.
  5. From the Send scanned image to: drop-down menu, select the program you want to use.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add the program to the list.
  6. Click See More Scan Settings to customize your scan.
  7. When you finish customizing your settings, click Scan Now.
Scanning Multiple Photos or Multiple-Page Documents note-dell.gif NOTE: Some programs do not support multiple-page scanning.
  2. Load your original document. For more information, see Loading Original Documents on the Scanner Glass.
    note-dell.gif NOTE: You can also open the Dell All-In-One Center from the operator panel on your printer. For more information, see Using the Dell All-In-One Center.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add your program to the list.
  7. Click the Advanced button.
    The Advanced Scan Settings dialog box opens.
  8. On the Scan tab, select the Scan multiple items before output check box.
  9. Click OK.
  10. When you finish customizing your settings, click Scan Now.
    After you scan the first page, a prompt appears requesting the next page.
  11. Place the next sheet on the scanner glass, and click Yes. Repeat until you finish scanning all pages.
  12. Click No when asked for another page.
    The program opens with the multiple pages scanned.
2answers
OCR
To scan a document for editing purposes, you will need OCR (Optical Character Recognition) software. OCR software is not included with your model.
OCR software interprets the scanned document for editing purposes. The Epson driver alone only scans documents as image files and is not capable of this interpretation.
Some reputable OCR software programs on the market are:
Omni Page Pro
ABBYY FineReader Pro
Presto! OCR 4.0
Please understand that Epson has NOT tested our products with these programs. They do not know if these programs are TWAIN compliant and will import directly from our scanners. I recommend that you contact these companies for full compatibility information if you are interested.
1helpful
2answers
Error 4 ... Konica Minolta Dimage Scan Dual IV
Use VueScan. A free trial is available so you can test it before you commit to buying it. Available for Windows and Mac.
http://www.hamrick.com
19helpful
7answers
Scanning with Canon Pixma MP450
I just did it then! With help from solution posted Feb 08 leave the acual scanner alone can be done from the computer. Steps:
1. Go to - start - control panel - printers & hardware - scanners.
2. Once inside the scanners folder just click once on the scanner icon (mine is called WIA Canon) so it is highlighted.
3. Then click on the toolbar 'File' > 'scan', then select the correct program from the list (mine was MP Navigator 2).
4. Use the MP Navigator program to select "scan photo/document", follow the instructions. At the bottom if the window that is open you can change the document type to PHOTO or DOCUMENT!
This is where the problem lies it is scanning the document as a photo which is why it is coming out as multiple documents.
Top Microtek Office Equipment & Supplies Experts
Alexander
Grand Canyon Tech
Grand Canyon Tech
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
