Question about Kenmore Dishwashers
Dishwasher will not drain
The water does not drain out of the dishwasher. Checked filter, checked drain line.
The dishwasher is a Kenmore Elite 630.1630
  • 1 more comment
  • circustrain Nov 01, 2008
    got the same problem. Can hear air move through drain tube, but still won't drain.
    Model 630.1630
  • Anonymous Mar 13, 2014
    dishwasher will not drain
  • Anonymous Mar 25, 2014
    how do you check to see if drain is clogged in dishwasher
    Problem Solver:
  • 6 Answers
If you have a garbage disposal make sure to take the plug out.
or the motor sylinoid is burn out.
Posted on Jun 13, 2008
Kenmore elite dishwasher is leaking water from diverter
I think you are talking about the air gap on the sink. If so, the drain line to the disposal or drain is plugged or pinched .clean it out and problem solved.
Jan 05, 2014 | Kenmore 24" Built-In Dishwasher with...
Dishwasher won't run. Worked yesterday, checked curcuit breaker, ok. water is in the bottem of washer but below the float level.
First, check the dishwasher filter and make sure it isn't clogged. Your owner's manual will have simple instructions on how to access and clean your dishwasher's filter.
Next, check the drain hose. Does it look flattened or kinked? Do you see any sharp bends? If so, straighten out the hose with your hands and manipulate it so that it regains its rounded shape.
If your dishwasher drains through the garbage disposal, try running the garbage disposal for a bit to process and clear any food. If that does not get the machine draining, you may have a deeper clog. However, most drain hoses clog either at the main household sink drain line connection or the garbage disposal connection.
Does your dishwasher spray your dishes, but it does not advance to the next stage and drain the dirty water? The timer controls the start of the draining process, so you may need an entirely new timer or a new motor for the timer. Repair service is recommended.
In some dishwashers, standing water is caused by a valve that fails to open and allow the water to drain out. This valve is controlled a solenoid that the timer controls. A malfunctioning solenoid could be the problem.
For more troubleshooting tips and solutions, see Dishwasher not draining. I hope this helps!
Sep 27, 2012 | Kenmore 665
Kenmore Dishwasher is not draining... checked drain line at disposal..not it. Have diassembled much of the housing at bottom of tub but still can't get to drain. Any suggestions?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 31, 2011 | Kenmore Dishwashers
Will not drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
Mar 18, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Clogged dishwasher, water remain , doesn't flow,
Please check the drain pump., check the voltage while the program is on drain. If there is no voltage the program controller must be checked. If there is voltage then the drain pump is clogged or defective. Open clean or replace.
Jan 29, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Dishwasher will not drain water
Drain out is done via the pump out motor. Is the pump out motor working? Check by deternining with a AC voltmeter to see if supply voltage is across the terminals in pump out mode. If voltage is present and motor does not spin - the motor is open circuit and must be replaced. Remove the 2 clamps and the 2 electrical push on terminals with the MAINS voltage disconnected. Is the outlet pipe not blocked or obstructed ?
Jan 19, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My kenmore ultra wash plus is not draining
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Won't drain water out?
Regardless of the brand, all dishwashers operate on the same principles.. in this case you said you checked for clogs and there are none..however.. have you checked the fileter screen for the drain, the hoses to the pump, the pump itself, the exit hose off the pump, the drain hose coming from the dishawasher to your house drain and is your house drain restricting water flow? Also.. is the pump actually operating at any time? These are the funadamental items to check..any one of them can cause your dishawasher to not drain properly. Hope this helps..
Sep 21, 2008 | Kenmore 24 in. 17594 Built-in Dishwasher
Dishwashers Logo
194 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
D. E. Hev
Raisin Brann
Level 1 Expert
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
