On my 997sd lcd the screen after about a second goes blk but the power light stays on also stays on on the power cord when unplug and plug back in again stays on for a second then goes blk
    Master:
  • 474 Answers
It may be going into power save mode or its not getting a signal from your comp.
Check this by using the monitor control menu on the monitor.
Does it give you a message at all?
Also, if you have a VGA video card and its a DVI monitor and you have a converter, you may need to switch it from DIGITAL signal to ANOLOGUE or vise versa depending on your setup.
Posted on Jun 13, 2008
Power light falshes on and off and tv will not power on. any advice on how to fix this
Unplug the tv for 5 minutes, then try this. Keep holding the VOL+ and CH- buttons down while you plug the tv cord back into the wall ac outlet till you get sound and picture for a second or two. You should be able to turn the tv on and off with the power button now. Next turn the power button off and unplug the tv for a few seconds and then plug it back in and turn the power button back on. Watch the screen and see if the sound and picture comes on, best to check in a dark room to see better, if sound stays on and picture comes on a few seconds and back off you have a bad CCFL backlight lamp in the LCD panel. This tv hads (10) CCFL lamps part # RLMPLA029WJN1 cost $15.93 at www.partstore.com or $19.49 at www.encompassparts.com in it and if one is burned out it will not let the tv picture be powered on till it is replaced. To check and replace the CCFL lamp you will have to unplug the ac cord from the tv back and remove 10 screws holding the back on. With back removed unplug the wire plug on the power button circuit at top left side of the black LCD screen trim, remove 4 screws holding the top of black trim, lay speakers off it, and release trim clips, (4) at top and (2) at bottom with a flat screw driver, and lower the trim to unclip the LED circuit board at bottom left side on the trim. With trim removed, at top of LCD panel remove the PC ribbon wire clip with thumb nail by lifting up on it to release the flat PC ribbon wire. Lay the tv back on a soft pillow with screen up, and look on the LCD panel front for and remove the (10) silver screws 1/2" long with an arrow mark beside them. Do not remove any gold colored screws or any without marks. The LCD panel screen can now be lifted off, lift the backlight plastic thin sheeting and thick sheet off to see the CCFL lamps. Plug the ac cord back into the power supply inverter circuit board and plug the power button plug wire back in its circuit board on the LCD black trim panel, and power the tv on while looking at the CCFL lamps. If the lamp is dim or burned out, take the (2) white plastic covers off the ends of the lamps with a flat screw driver and unclip the lamp to replace it, Check the lamp socket part # QSOCFA003WJZZ by putting a good lamp in it and if it lights up the sockets are good and the bad lamp was the problem. If all the CCFL lamps do not light up, unclip the top lamps and move them to differant sockets to the center and the center lamps to the top, if the lamps do not light up, then it is a bad power supply inverter circuit board the ac cord plugs into, part # RUNTKA448WJQZ , cost about $160.00 for new one or less if you buy a used one on www.ebay.com , replace it and the tv should work ok then.
Feb 12, 2011 | Sharp LC-32SB23U 32 in. LCD TV
Tip
How to fix Sharp LCD model # LC-32SB23U flashing green power light and check and...
If the green power light keeps flashing on and off every second and tv will not power on unplug the tv for 5 minutes, then try this. Keep holding the VOL+ and CH- buttons down while you plug the tv cord back into the wall ac outlet till you get sound and picture for a second or two. You should be able to turn the tv on and off with the power button now. Next turn the power button off and unplug the tv for a few seconds and then plug it back in and turn the power button back on. Watch the screen and see if the sound and picture comes on, best to check in a dark room to see better, if sound stays on and picture comes on a few seconds and back off you have a bad CCFL backlight lamp in the LCD panel. This tv hads (10) CCFL lamps part # RLMPLA029WJN1 cost $15.93 at www.partstore.com or $19.49 at www.encompassparts.com in it and if one is burned out it will not let the tv picture be powered on till it is replaced. To check and replace the CCFL lamp you will have to unplug the ac cord from the tv back and remove 10 screws holding the back on. With back removed unplug the wire plug on the power button circuit at top left side of the black LCD screen trim, remove 4 screws holding the top of black trim, lay speakers off it, and release trim clips, (4) at top and (2) at bottom with a flat screw driver, and lower the trim to unclip the LED circuit board at bottom left side on the trim, leave the wiring pluged into this LED circuit board . With trim removed, at top of LCD panel remove the (2) PC ribbon wire clips with thumb nail by lifting up on it to release the flat PC ribbon wire. Lay the tv back on a soft pillow with screen up, and look on the LCD panel front for and remove the (10) silver screws 1/2" long with an arrow mark beside them. Do not remove any gold colored screws or any without marks. The LCD panel screen can now be lifted off, lift the backlight plastic thin sheeting and thick sheet off to see the CCFL lamps. Stand tv up and plug the ac cord back into the power supply inverter circuit board and plug the power button plug wire back in its circuit board on the LCD black trim panel, and power the tv on while looking at the CCFL lamps. If the lamp is dim or burned out, take the (2) white plastic covers off the side ends of the lamps with a flat screw driver and unclip the lamp to replace it, Check the bad lamp sockets, part # QSOCFA003WJZZ, by putting a good lamp in it and if it lights up the sockets are good and the bad lamp was the problem. If all the CCFL lamps do not light up, unclip the top lamps and move them to differant sockets to the center and the center lamps to the top, if the lamps do not light up, then it is a bad power supply inverter circuit board the ac cord plugs into, part # RUNTKA448WJQZ , cost about $160.00 for new one or less if you buy a used one on www.ebay.com , replace it. If the power supply inverter circuit board is bad to replace it, unplug the (2) wire plugs at the top left side on the circuit board, take (3) screws marked with an arrow out, use a pair of sharp nose plyers and squeeze the plastic white tip holding the circuit board on the right side careful not to touch the high power circuit backlight plugs on the right side of the circuit board. Pull board straight out to unplug it. Replace with new board and tv should power on now.
on Sep 28, 2011 | Sharp Televison & Video
I have a Sony Bravia LCD, while cleaing the room water goes in the LCD and now when ever i turn on, its stay on for 5 second and then goes to Standby and red light blink on the panel.
Tries tv unplug,replug tv back like about an hour later.The tv now should be resetting back to the factory setting.The tv should work now.But,if the tv still have same problems,the power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The tv came on then the screen went black but there was still sound for a sec. Now the green light keeps blinking and the tv won't turn
Unplug the tv for 5 minutes, then try this. Keep holding the VOL+ and CH- buttons down while you plug the tv cord back into the wall ac outlet till you get sound and picture for a second or two. You should be able to turn the tv on and off with the power button now. Next turn the power button off and unplug the tv for a few seconds and then plug it back in and turn the power button back on. Watch the screen and see if the sound and picture comes on, best to check in a dark room to see better, if sound stays on and picture comes on a few seconds and back off you have a bad CCFL backlight lamp in the LCD panel. This tv hads (10) CCFL lamps part # RLMPLA029WJN1 cost $15.93 at www.partstore.com or $19.49 at www.encompassparts.com in it and if one is burned out it will not let the tv picture be powered on till it is replaced. To check and replace the CCFL lamp you will have to unplug the ac cord from the tv back and remove 10 screws holding the back on. With back removed unplug the wire plug on the power button circuit at top left side of the black LCD screen trim, remove 4 screws holding the top of black trim, lay speakers off it, and release trim clips, (4) at top and (2) at bottom with a flat screw driver, and lower the trim to unclip the LED circuit board at bottom left side on the trim. With trim removed, at top of LCD panel remove the (2) PC ribbon wire clips with thumb nail by lifting up on it to release the flat PC ribbon wire. Lay the tv back on a soft pillow with screen up, and look on the LCD panel front for and remove the (10) silver screws 1/2" long with an arrow mark beside them. Do not remove any gold colored screws or any without marks. The LCD panel screen can now be lifted off, lift the backlight plastic thin sheeting and thick sheet off to see the CCFL lamps. Plug the ac cord back into the power supply inverter circuit board and plug the power button plug wire back in its circuit board on the LCD black trim panel, and power the tv on while looking at the CCFL lamps. If the lamp is dim or burned out, take the (2) white plastic covers off the ends of the lamps with a flat screw driver and unclip the lamp to replace it, Check the lamp socket part # QSOCFA003WJZZ by putting a good lamp in it and if it lights up the sockets are good and the bad lamp was the problem. If all the CCFL lamps do not light up, unclip the top lamps and move them to differant sockets to the center and the center lamps to the top, if the lamps do not light up, then it is a bad power supply inverter circuit board the ac cord plugs into, part # RUNTKA448WJQZ , cost about $160.00 for new one or less if you buy a used one on www.ebay.com , replace it and the tv should work ok then.
Dec 06, 2010 | Sharp LC-32SB23U 32 in. LCD TV
I push my power switch and nothing happens. the
Jun 02, 2010 | Sharp LC-32SB23U 32 in. LCD TV
All the lights are flashing and it says to Reset power. I disconnect the power cord and reconnect. The system looks like it is resetting and then the same flashing lights appear and it again says to Reset...
Hi Joe,
Lets try 2 steps:
1st approach:
1. With the printer “ON” unplug the power cord form the printer.
2. With the printer now unplugged, press and hold “# and 6′ keys in the printer..
3. While still holding these keys down, plug the power cord back.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
2nd approach:
1. Unplug the power cord
2. Wait for 30 seconds.
3. Plug the power cable back in the printer and turn it on.
(repeat 3 times)
If none of these to approaches work, I’m afraid the failure is “fatal” as the main circuit board might be fried L
Regards,
Ed
Nov 25, 2009 | HP Officejet 6310 All-In-One InkJet...
Laptop LCD Screen won't come on and computer keeps rebooting
Try checking the inverter, if that is intermittent, it could short the system and cause the symptoms you are describing.
Apr 03, 2009 | Gateway 7330GZ Notebook
No Picture, No Sound While Watching
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | RCA L37WD250 37 in. LCD HDTV
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
LCD screen goes black repeatedly
Have you checked the light on your power supply? My monitor will go black and I noticed the light on my AC power supply was off. It was very hot so I unplugged it and let it cool down. When I plugged it back in my monitor worked fine until the power supply started to over heat again.
Oct 25, 2006 | Fuji FP-988D 19" Flat Panel LCD Monitor
Computers & Internet Logo
60 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
