Older Peavey PA Head XR600C. Problem with 400BH Board the B is like 0v unplug B and I have the voltages for the /- 16Volts. Plug in the B ( -52V) and nothing. Replaced all 4 6A2 diodes, caps test good, resistors test ok. 2 resisters fried, they were the 47 Ohm FP's. replaced those, tried new transformer. Disconnected the audio out board for isolation and the mixer section of the board. Need Help Thank you.
  • Steve Griffith Jun 12, 2008
    I have the service manual...these are FREE from Peavey. I feel I was ripped off by this outfit and I am filing a complaint with Peavey. All resistors were replaced
  • Steve Griffith Jun 13, 2008
    the two resistors that were fried R58 and R59, 47 Ohm Flame proofs. I replaced some of t he 2K 5W, replaced the .1 Ohm 10 Watt, (2) replaced all the .33 Ohm 10 watt, the 1K 5 watts, and the 5.6 Ohm 5 watt. When I plug in the red/red-yellow/red, it goes down to 0 volts. I have it plugged in to a 100 watt light bulb to save the fuse.
    the lamp glows brightly. Now, when I unplug that secondary from the 400BH, and just leave the 15 volt supply on (orange/or-wh, orange works fine.
    Replaced the Diodes CR16,17,18,19.eplaced the Two Zeners. all the 2K 5W resistors test good out of the circuit.
  • 1,512 Answers
If you need a circuit for the PA board... get it from here
I would start by checking with a multimeter for shorts in driver transistors Q2 and 12
The output stage may be suspect for a driver to have failed. I would disconnect(emmitter and collector) of each output transistor for leakage and shorts in all directions (swap meter leads +ve and -ve). You can often tell at a glance that there IS a short in the output stage, by checking collector emitter with everything still connected. You cannot, however tell if there is leakage that may kill any repair work that you are doing.
Good work on the lamp. I use one in line with the mains socket on my test bench. I use a 40 watt build though.Have seen some smoke with higher wattages. I also use a variac to soft start the unit and do some DC checks mostly for symmetry in output stages with about 40-70 v into the 240 volt mains socket.
Let me know if you find any shorted transpistanators :)
regards
robotek
Posted on Jun 13, 2008
  • Graeme Ross
    Graeme Ross Jun 13, 2008
    Oh, and here in case you need it here is a quick tutorial in checking transistors that may help you with fault finding the drive and output transistors
  • 4,234 Answers
I will look this up to confirm, but these units are famous for having a 2K 5W resistor open up. This should be a square ceramic resistor. I'm not at the shop at the moment, but I'll look it up when I get back and try to give you more details. These units are counter-intuitive.
Stay tuned...
Dan
Posted on Jun 12, 2008
  • ABRsvcs Jun 12, 2008
    Forgot to ask... Which resistors were fried? Do you have the circuit designations?
    Thanks,
    Dan
  • 13,433 Answers
Im just giveing you my honest opinion about this.
Replace the whole board.
    Genius:
  • 3,422 Answers
Please CLICK HERE to buy a service manual for your model.This service manual has all the schematics with detailed explanation which will help you fix this issue.Once you click on the link scroll down and select your model no. and click on BUY NOW to purchase the service manual.
Goodluck,
Please don't forget to rate or accept the solution
  • Priya darshan Jun 12, 2008
    Well that was the only sol. which i could give you from my side.The service manual should fix the problem.I believe you should give a complaint regarding this issue.
    Master:
  • 638 Answers
I WILL ASSIST U IN A MOVEMENT.
  • hemant somaiya
    hemant somaiya Jun 12, 2008
    THOUGH THE RESISTORS LOOKS GOOD. REPLACE ALL OF THEM. IT MOSTLY SOLVES THE PROBLEM.RATE THIS SOLUTION IF IT HELPS U TOWARDS SOLVING UR PROBLEM.
  • hemant somaiya
    U CAN ALSO THE CLEAN THE MINUTE CONNECTION ON THE BOARD WITH ISOPROPHYL THIS ALSO SOLVES THE PROBLEM.BEFORE CHANGING OR BUYING NEW BOARD.
    THIS MAY SAVE YOUR TIME AND MONEY BOTH. TRY THIS. RATE THIS FIXYA IF THIS HELPS YOU.
I have a Peavey XR-600 PA Head, I would like to know if and how can I connect a MX 200 Dual Reverb Effects Processor to the PA Head?
If it has a effects loop output and input on the p.a. head and a in and out on the reverb effects processor, then yes you can, just run the effects loop output signal into the input on your reverb processor, out of the output back into the input effects loop on the p.a. head, kinda like you would a effects pedal thru the effects loop of a guitar amplifier. hope this helps!
Dec 02, 2015 | Peavey Music
Ha3500 hartke sound goes off with a click after 5 seconds .what is causing the problem
Sounds like the loudspeaker relay switch is disconnecting the spkr.
i) Check heat sensor on heatsink has good connection to PA board. Dust on h'sink/fan usually needs vacuuming off!
ii) Check voltage on the amplifier output resistor R334 is at 0v (referenced to chassis) - if this voltage is raised,the amp stage is faulty.
Otherwise the fault lies in the speaker protection stage (IC301).
Sep 24, 2013 | Hartke Ha2500 250watt Bass Amplifier Head
I have two peavy xr 600b i want to daisy chain them so i can use one for the monitors how do i do that?
you will need 2 y patch cables 1/4in to make this happen, they need to be about 3 ft long, set one head on top of the other...then use a y patch cable and plug it into the main output on both heads, then plug it into the graphic input on the head you want to use for the mains....then take a y cable and plug it into the monitor output on both heads...then plug it into the graphic input of the other head, this one will run the monitors.
Apr 27, 2013 | Peavey Xr600b Mixer Amplifier "last One"...
How do i use the effects loop on peavey xr 600b?
plug the effects out into the input of your reverb/echo unit, plug the out put of the processor into an unused channel in the mixer, do NOT turn up the effects in that channel, to hear the effects in the main use the main level, to hear effects in the monitor use the monitor level. you must turn up the the effect send in the channel you want to hear the effects on and also the effects master.
Jan 23, 2013 | Peavey Xr600b Mixer Amplifier "last One"...
Peavey 150m power amplifier - no audio, hum
Bad caps probably..old unit, do you have a capacitor analyzer...if not you might find a Sencore LC102 to test caps with on ebay...
Jan 16, 2013 | Peavey Xr600b Mixer Amplifier "last One"...
Peavey 400B manual
go to Peavey website, select support, select owners manuals, click on archived owners manuals, select x for xr 400 b, select from the shown list.
Aug 11, 2012 | Peavey Xr600b Mixer Amplifier "last One"...
Peavey SP3 (older model) Can not get any sound thru horn.
They have a "soundgard" protection network that uses a polyfuse and an automotive lamp. Open the unit and check the circuitry. Both the polyfuse and he lamp may be blown. Do ohmmeter check of these, otherwise the horn is blown.
Aug 08, 2011 | Peavey New Peavey Sp3 15" 3 Way PA Speaker
I NEED A 1000S PEAVEY PA HEAD FOR PARTS
Barring an entire head being available, what specific parts do you require. Most are available from generic suppliers or from Peavey directly. Can you be a bit more specific about what you need?
Thanks,
Dan
Feb 24, 2009 | Peavey Audio Players & Recorders
Peavey 400BH
Thanks for the update. I'll need to look through my records for similar problems. Stay tuned...
Dan
Jun 13, 2008 | Audio Players & Recorders
1,090 people viewed this question
 Grubhead
Grubhead
