Question about Sharp 13H-M60 TV
No sound. Sharp 13H-M60 TV lost sound. Never had a problem with it. I disconnected it from the cable source, and reconnected it. Still no sound.
  • Sharp Master
  • 520 Answers
If you have a cable box reset it by unplugging it from power for about 5 seconds. Hope that works.
Posted on Jun 13, 2008
I have a Pioneer VSX D412 S receiver with my Pioneer surround sound system The system SUDDENLY STOPPED RECEIVING SOUND SIGNAL FROM MY HD TV
  1. Turn the TV and receiver off and back on. This is called "power cycling" the devices.
  2. Check the menu settings to make certain the TV is still sending a sound signal out to the receiver.
  3. Disconnect the cable, blow both ends out, reconnect, and see if the cable was partially disconnected or has dust or lint interfering with the connections.
  4. Change the cable for another cable that you know to be working.
  5. Use a different source for the TV: DVD, Cable, different channel, etc.
  6. Connect the receiver to another TV.
Dec 16, 2015 | Pioneer Audio Players & Recorders
Sharp aquos 65- we have sound but no picture. What do I do?
There has been a power supply failure. The process of disconnecting then reconnecting the TV shocked the failing power supply back to life but ultimately it failed
Jan 29, 2013 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
My sharp has sound and no picture
Most likely the cable, disconnect from TV and whatever it is connected to, then reconnect.
Jan 14, 2013 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
We hooked up our LCD HD 19" TV up to our HD
Try to disconnect all the connection cables and reconnect again. If still don't receive any sound, your HDMI cable is faulty.
Nov 07, 2010 | Sharp LC19A35M 19 in TV
Sharp 25H-M60 landlord broke off the cable connector!
depends i have replaced these alot the part is cheap but you have to be careful when repairing this problem you can really mess the tuner up then it cost more starts any where from 40.00 to 80.00 dollars the parts cost pennys okay it's all labor have a good day tv man
May 14, 2009 | Sharp 25H-M60 TV
Blue screen, no video, but has sound
Did you hit the "input" or "video source" button by mistake on the remote or TV? That would change the input from the one the cable/video source uses. You're getting sound, so it's working......sounds as if the input was maybe changed. I'd hit the input/video source button a few times to go through all the available inputs and see if you get video back.
Dec 08, 2008 | Sharp LC-32SH20U 32 in. LCD HDTV
Universal Remote control code on Sharp 13H-M60
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 19, 2008 | Televison & Video
Not able to connect Sharp Model 25h-M60 to Laptop or DVD player
Use a VCR as a A/B switch. Run Cable signal into VCR. Run coax cable out of VCR into television. Connect DVD to VCR (line in) using RCA cables. To use DVD, set VCR channel to L1 or L2 or AUX, depending on VCR type. Set VCR to channel 3 or 4 to watch television. VCR must be powered up to watch DVD.
Apr 10, 2008 | Sharp 25H-M60 TV
Your remote should have come with a sheet of paper with all the codes on it for different TV's, VCR's, , etc.
Sep 03, 2007 | Sharp 13H-M60 TV
Televison & Video Logo
101 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
