Question about Toshiba e-Studio 350 Copier
Out of staples
My unit will not operate without staples. This shuts down our copy ability. Is there a way to continue copies until the box of staples arrives at our office?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,362 Answers
In the menu /control panel choose the single or double sided copies w no staples
Posted on Oct 03, 2008
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
Can not down load photos to the unit
Xbox 360 doesnt support the ability to copy media from pc/usb device to the internal hardrive.
Ps3: Go to pictures, select the pic to copy. Press triangle and select copy.
Jul 31, 2011 | Video Game Consoles & Games
I have a pitney bowes C180 that won't copy. The
the little wrench means it has shut down because it has exceeded the maintenance count, probably for the cleaner web in the fusing unit. Call service at 1 800 243 5556
Oct 30, 2009 | Pitney Bowes C180 Copier
His copy of Windows must be activated with Microsoft before you can > continue. You cannot log on until you activate Windows. Do you want to > activate Windows now? > To shut down the computer,...
I would guess that a complete rebuild was done on this system using the product key that came with the box. In order for this software to work properly, you must activate the key. This is done at the factory before the unit is shipped and when a complete rebuild is done, you must perform this step as well. Connect to the internet Microsoft website to do this. If you do not have an internet connection available, there is the option to perform the activation over the phone. Once this information is entered, the system will be fully functional. This must be done to verify and validate the OS installation. Dan
Jun 09, 2009 | Microsoft Windows Server 2003 Standard...
Copy feature doesn't make copies
  1. Turn on the HP All-in-One.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 3 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Then when that's done, try printing, or copying items. If its still not working, check the ink and change those out and this should fix it.
May 11, 2009 | HP PhotoSmart C4180 All-in-One Color...
KONICA MINOLTA C450 VXL Printer - When stapling multiple copies it staples all the copies together rather than each one separately as required. I use vista operating system.
There is an issue with the Konica Print Driver and the MS Print Driver. If Collate is turned on in both the drivers, you will get this problem.
The solution is to turn off Collate on one of the Drivers. Usually you will have an initial Print Dialog window that pops up when you can select your printer, how many copies and if to collate or not. De-select Collate. Then you should also see Preferences Tab. If you select that tab, select Collate and Staple, your print jobs should now Collate and Staple correctly.
Jul 23, 2008 | Office Equipment & Supplies
Paper jams when using staple option for more than 13 copies
There is someting I would like you do for me, I will tell you how to enter service mode and retrieve a jam code, give me that jam code, I will look it up and tell you what it refers to and what it could be.
1) Start service mode. (Press the '*' (additional functions)key, '2' and '8' at the same time, and the * key once again.)
Press the copier tab > then down the left side select jam
You will see Date, Time 1, Time 2, L, Code, P, CNTR and Size.
Write down the last 5 jam codes, eg. 0201 or 0112, OF12, 0014 whet ever the combination, if you can take down the date, two times, cntr and size, would be helpful also.
Do not go changing other settings in service mode as you can seriously affect your copier and you will end up calling a tech anyway.
Please get back to me with the codes.
May 28, 2008 | Canon IMAGERUNNER 6570 Copier
Toshiba e-Studio 350 Copier Logo
66 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
