Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony kdl-40s4100 no red standby light.When power button pushed green power lamps lights but no picture ,screen,audio.All power is good 15 volt 12 volt 5 volt 3.3 volt 1.8 volt.Also all crystals oscillate. Thanks,Alex.
  • 3 more comments
  • alex977 Nov 02, 2010
    Yes it does.
    Alex
    I dont have one.
    I have printed the schematic.
    Alex.
    The -5 volts is pulled down or bad at u1101.I will track it down from here.
    Thanks for the schematic Alex.
    Yes, the -5 volt power supply was bad or pulled down at u1101 pin 2 or c1125 c1127.
    Thanks,Alex.
  • 4,889 Answers
Does it make a click sound when powered on?
Posted on Nov 02, 2010
  • 3 more comments
  • eagle338
    eagle338 Nov 02, 2010
    IN that case its not the power supply. Your problem is more likely to be the mainboard. Can you send the service manual across so that I can give you some pointers as to where to begin.
  • eagle338
    Ok. No problem. I found one in my collection. I will upload it and send it to you. And then I will tell you what else to check. Give me 5 min.
  • eagle338
    Here you go
    http://www.mediafire.com/?0150m0vktwzz0y...
    Let me know once you have downloaded it so that we can begin.
  • eagle338
    First up lets confirm that its not the power. Start by checking for the 6.5Vat the start of the circuit on the power board(page-25). Also look for 3,3 V at the location 3.3V_SB. Also look for 15V near C1150, 6.5V near C1151, 3.3V near 1149, 12V near 1152. Also look for faulty capacitors in the circuit after the junctions specified(blown, bulged or cracked caps). Check other circuits for continuity like 5V_ALPS etc., and verify if everything is as it should be. If it is then let me know and we will move on to the next one.
  • eagle338
    Sure thing. You are welcome. Thanks for using Fixya!
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
Sony tv screen has no picture
Watch the red light and or power light when this happens, if there is a specific number of blinks and then a pause that is a error code.
May 25, 2012 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
SONY KDL-40S4100 flashes 5 times
try to force on the tv un plug and use remote when tv iv completly off. and press display 5 vol+ then power and see if tv stays on and in service menu look for eror code .if tv stays on if it cutts off then one of lamp in screen is defective. its mean screen defective
Mar 01, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
KDL-40s4100 power light on, black screen
Main PCB is bad . I just got the information from a Sony authorize servicer price for the part only $504.87
Nov 27, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony KDL-40S4100 Bravia LCD will turn on for like 2 seconds with picture and green power led, and then goes to flashing red standby led twice for a bit. Then I hear a
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Mar 28, 2011 | Sony Televison & Video
KDF-50a12U Powers off then standby light blinks 3 times
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error.
There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error.
Thanks.
Oct 19, 2009 | Sony BRAVIA KDL-40V3000 Television
SONY BRAVIA KDL-40s4100 is not working right
Please check whether the connections are secured between the TV and the connected devices.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Try connecting the TV to a different wall outlet and check if that helps.
Please connect a different device to the TV and check whether the issue persists.
If the issue still persists service of the TV is determined.
Jun 18, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
No Picture on TV when Power is on
This seet should provide some diagnostic help. The standby light should be blinking a repeated count with a pause. Post that count here. Also, is there sound?
The above info will indicate the problem circuit which will then suggest the remedy.
Thanks,
Dan
Jan 19, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
DLP TV turning on and off automatically - Mitsubishi WD-52327
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
Sep 18, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
882 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
