Windows XP, Vista , or Windows 7 should be able to automatically detect and install it. Try using it
on another computer that has either Windows XP, Vista , or Windows 7 on
it. If it doesn't automatically detect and install it on that one then
the flashdrive is dead.
If you have an older operating system then go here to download the driver: http://www.sandisk.com/sandisk-support/driver-download-wizard
But if you have an older operating system then go here to download the driver: http://www.sandisk.com/sandisk-support/driver-download-wizard
If you have an older operating system then go here to download the driver: http://www3.pny.com/categories/usbflashdrives.aspx?category_id=12
Assumption1 Flashdrive is damaged,the normaloperating system. Solution If theflashdriveis detected(eg;detectedthe flashdrive indriveG),but itsays"insertthe diskintothedrive..." 1.DownloadsoftwareJetFlashOnlineRecovery(open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download). 2.Insert the flashdrive 3.OpenfileOnLineRecovery.exe-Selectthe volumeof thedevice-Repairthe drive&keepdataexisted-START.If it fails,selectRepairthe drive&erasealldata-START.
If theflashdrive isnot detected(not detectedas driveG),the abovesolutioncan not be used.
Assumption 2 Normalflashdrive, the operatingsytemis corrupt Solution Flashdrives do notrequiredrivers(plug and play).Becauseflashdrivesplug and play,it should be,when theflash driveinserteddetectsthe operating systemwithout installingdrivers.But,if theoperating system does notdetect,the possibility ofoperating systemscorupt.The causeis a viruscorruptyour operatingsystem.
Hi, For that problem, do this first check-up your bios setting. Power on your PC laptop, when screen popped up (press F2, delete etc. ) to get into standardbios Setup you see there if your hardisk drive detected or not detected. if not detected try to open your Laptop PC ( need power off. open cover at the back of your laptop ) check-up your hardisk drive for loose power cable, data cable hardisk Some burn , noise hardisk sound ) if detected, your operating system corrupted. you need to Reinstall your operating system like windows xp, windows 7 or linux base operating system. try that Solution first.
Just let me know if not yet working your laptop PC. Regard.
This is a rare X-Box related error that pops up when there was a system issue with an update. The easiest way to resolve this matter is with a flash USB drive; I'm hoping you have one.
Note The USB flash drive must use the FAT32 file system.
Plug your USB flash drive into a USB port on your computer.
ye you can, it mean you must downgrade your pc, use vista cd to install it, but you may lost your data at drive C: you must back up your drive c: data before install vista
To determine if your system is detecting the USB drive or not
Windows XP
Right click "My Computer" >> Properties >> Hardware Tab >> Device Manager
Windows Vista/7
Right click "Computer" >> Properties >> Device Manager
If your USB drive is not detected at all either the drive is bad or the usb port is bad, I would try another USB port to rule out the issue being a port
If you see a ? or ! then your operating system had trouble installing a driver for it uninstalling and reinstalling the driver should resolve the issue
Please comment if you need further assistance or clarification
Thanks
If
There seems to be a problem with the hard drive. I would suggest to attempt reinstalling windows or using the recovery discs that might have came with the computer and try to reinstall or restore the computer to the original state.
if the hard drive is not detected in windows setup, you most likely have a faulty drive.
In that case the hard drive might need to be replaced.
