Question about Kenwood KAC-7201 Car Audio Amplifier
Keeps blowing fuse when remote is turned on 800 watt kenwood kac-7201 nothing is burned on the inside everything looks in order no burned spots on circut board. what could be the problem worked fine one day and the next just blew fuses.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
If it is blowing fuses you probably have a blown transistor or shorted component inside the amp. a transistor can look just fine and still be bad.
Posted on Nov 02, 2010
Why does myKenwood 800watt amp KAC-7201 2 ch amp keep blowing fuses every time i turn on the key
There is probably a short inside of the amplifier. First guess would be output transistors although it could be several other things also.
Feb 27, 2015 | Car Audio & Video
I have two 12 inch 1200 watt kenwood excelons and i want to bridge them to the amp but i can barely turn it up with out blowing fuses
Please check the impedance of those subs. Are they 4 or 8 ohm speakers? Do they have dual voice coils? this app may not be capable of handling dual voice coil four ohms and you're trying to bring it down to a 2 ohm mono.
Dec 19, 2013 | Kenwood KAC-7201 Car Audio Amplifier
What is the value of a 800 watt kenwood amp KAC 7201
depending on condition of the amp for excellent condition it would be around 90 to 125 in good condition you looking at about 60 to 90 in poor condition you are looking at 30 to 60 and in bad condition under 30 .
Aug 02, 2010 | Kenwood KAC-7201 Car Audio Amplifier
Amp blows fuses
Are you using the correct fuse? if so,
more then likely, you don't have a good ground. Try grounding to something else that has more direct connection to your frame. If that doesnt work, try getting larger power cables.
I had the same problem with my 2500w xplodes all I had to do was get a thicker cable for the ground and battery connection. What was happening, was it was needing more power then the wire and fuse could handle, so it would blow the fuse, since the higher you have it, the more power it needs to feed the watts.
I would try grounding it directly to the frame on a good part of the frame before spending another $70 on new power cables though.
Mar 09, 2010 | Car Audio & Video
Car audio amplifer blowing fuses
why are you in stereo for subs? mono all the way.
Feb 21, 2010 | Kenwood KAC-7252 Car Audio Amplifier
When I hook up my kenwood kac-7201 the power light
leave power connections hooked up disconnect rca and speaker wires if they still blow more than likely problem with amp
Dec 31, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Connecting subwoofer to kac-7201 kenwood amp
from your sub connect one short piece of cable from + on one side to - on the other side using the same diameter cable as you are running to the sub from amp . this will leave you with + and - on opposite sides of speaker these will then run to the amp +to+ and - to- on the mono side of connetor which is one left + and one - right and the amp switched to bridged
Mar 22, 2009 | Kenwood KAC-7201 Car Audio Amplifier
KAC-7201 no sound from subs.amp is on.
It sounds like your amp is overheating.
Check to see if its location is well vented, in the past, I have had to install ports/ vents and sometimes fans, when an amp could not be relocated.
Good luck...
Feb 24, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Blowing fuse
Most of the time, when you connect it and it blows a fuse, one of the speakers are blown or you have too high of a power demand than the amp can put out.
Can you put more detail in to your question so I can answer it more appropriately? What kind of speaker, what kind of sub, the wattages, etc.
Feb 05, 2009 | Kenwood KAC-7201 Car Audio Amplifier
My 800 watt kenwood
Sounds like you shorted out the main power wire somewhere and killed the amp. Is the amp on the fuse intact or blown? Do you have 12 volts at the amp? check you connections and see if it helps.
Jun 03, 2008 | Kenwood KAC-7201 Car Audio Amplifier
Kenwood KAC-7201 Car Audio Amplifier Logo
209 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
