Question about GE Refrigerators
My ge side by side refrig freezer gets on the auto defrost cycle in the freezer and then all the ice cubes in the ice maker freeze into a solid ball of ice. The ice maker does not work after that. Why does the defrost come on so long and so warm?
  • 4,070 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Posted on Nov 02, 2010
My kenmore elite refrig keeps leaking water from what appears to be condensation. It gets so bad that the ice maker door freezes shut and water actually drips on the floor. The freezer is set to 0 while...
The high level of condensation is due to constant opening of the fridge when the frost develops. It is required to defrost off the condensation and if this has an auto mode timer for defrost , then it is possible that it is not working.
The water must drain out to the drain tank but since it is formed out of the freezer the water flows out of the collection tray.
Sep 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
I have a monogram zis 42d side by side the freezer section works but in the defrost mode the unfrozen ice runs down the sides of freezer and into ice cube storage container, I have cleaned out the drain...
I have this same problem. Now, the freezer will not get cold enough, but still water runs down into the ice bin and just turns into a big solid block of ice. The water is dripping from the top of the freezer compartment. I have disconnected the water coming to the refrig to not allow it to make ice, but still happening. Please post if you have found a solution? Defroster issues?
Nov 09, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Ice maKer is not getting water but the water side works.
Your refrig water valve , has 2 coils on one valve . One is for the water dispensor , and one is for the ice maker . So even if you get water thru the dispensor , the other coil ( for the ice maker ) could be bad . The fill tube from inside the freezer to the ice maker , could be frozen solid , keeping the water from entering the ice maker . This frozen tube , would be caused be the water valve " seeping " , which means , it isn't closing completely , and drips freezing inside the tube . indicating a bad water valve . Pour about 2/3 cup of water into the ice maker . If it dumps , but doesn't refill with water , replace the water valve but also check this tube . If the ice maker does not dump the frozen cubes , replace the ice maker , but also check the coils under the refrig , for dust , lint , etc , needing to be cleaned off . The ice maker needs to be 5 degrees to operate , and dirty coils can keep the freezer at 6 degrees or above .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE GSS25KGSA.... the freezer is no longer freezing regardless of temperature setting. It gets cold but no freezing. There used to be more noise during cycles, but that has stopped also.
The fan that circulates air in the freezer compartment is frozen & not circulating air - resulting in a freezer compartment that is cool but not cold. The reason is that the “heater & bracket” that warms & defrosts the evaporator coil & the fan above it has died & w/no defrosting, the coil & the fan load up with frost & ice & stop working.
Temporary Solution:
1) Unplug the frig.
2) Take all the food & shelves out of the freezer. Put it ALL in one cardboard box; this will keep it from defrosting while you get the freezer working.
3) Take out the ice maker storage bin (the thing that's full of ice cubes) & dump the ice cubes. (if you leave them in the freezer, they will melt & refreeze & make a disaster).
4) There is a metal panel below the lights & it should have frost & ice built on it.
5) Get two (not one) hair driers, set them on high heat & melt all the frost & ice & keep on melting & defrosting for about 10 minutes.
4) Plug the frig back in.
5) The freezer fan should be turning.
6) Put the shelf & food back in & close the door.
7) Expect this problem to reoccur in one to four months...
Solution:
1) Get a “heater & bracket” GE part number WR51X10055, about $30 w/shipping on eBay. This is for a GSS25KGSA GE side by side (the last two letters WW, BB, & CC are colors). If you have a different GE side by side, the correct part number can easily be found at www.searspartsdirect.com. Nice drawings.
2) Unplug the frig.
3) Take all the food & shelves out of the freezer. Put it ALL in one cardboard box; this will keep it from defrosting while you get the freezer working.
4) Take out the ice maker storage bin (the thing that's full of ice cubes) & dump the ice cubes.
5) Take out the light cover. One Philips screw on top & two press-to-release plastic things on the bottom.
6) Unscrew the light bulbs.
7) Take out the metal panel below the lights. Four ¼” screws. It is held in by two tabs at the top, so swing the bottom out & pull it down. Be careful not to bend it.
8) Get two (not one) hair driers, set them on high hot & melt all the frost & ice on the evaporator coil. Do NOT touch it.
9) Remove the “Heater & Bracket” by unscrewing the two Phillips screws and then unplugging the red & blue wires.
10) Install the new “Heater & Bracket” by plugging in the red & blue wires & replacing the two screws. Be careful not to get it backwards when plugging the wires; only goes one way.
11) Put the back panel back in & secure it with the 4 ¼” screws.
12) Reinstall the lights & cover.
13) Plug the frig back in.
14) Put the shelves & food back in & close the door.
15) Expect this problem to reoccur every 3-4 years; great designs fail after the warranty is up, and keep the repairmen & parts people employed …
p.s. about once a year, you should vacuum all the accumulated dust off the condenser coils. They are hidden behind a metal cover at the bottom back of the refrig. If you don't, expect the dust eventually block all airflow & the compressor will burn up & you will be buying a new frig.
Generic GE Side by Side Refrigerators GSS25KGSA, GSS25KGSAWW, GSS25KGSABB, GSS25KGSACC.
Jul 08, 2009 | GE Refrigerators
Freezer
If the freezer is in defrost then the freezer fan should be off. Only on the electronic will the freezer fan come on in defrost but the freezer door has to be held open for 3 min before the fan comes on
Jun 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
111 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Brian Coughlan
