Question about Maytag Portable Air Conditioner M6P09S2A
Maytag 9,000 BTU Portable Air Conditioner, M6P09S2A
When I turn this unit on I can feel and hear the compressor and after a short time feel cold air. A short time later the compressor shuts off and blows warm air.
I removed all the sheet metal and vacuumed the coils then washed them down but could not find a valve to add a little bit of gas to give it a helping hand.
I also noticed the the 4 inch exhaust port is not moving any air when the unit is blowing cold or warm.
Any suggestions would be appreciated
Thanks
dave
  • Anonymous Sep 01, 2008
    The air conditioner appears to be working OK (settings on the remote control and A/C, and blower) except that it is only circulating the air in the room. Doesn't put out cool air, and hot air is not coming out of the back vent.
    One thing that also happens is a loud sound from the air conditioner -- three or four wailing sounds like a train whistle (in the key of B flat below middle C). Then silence for a short while, and the sounds repeat.
    I would appreciate any advice you can give to me -- perhaps a way that I can fix the problem myself.
2 Suggested Answers
SOURCE: Model M6P09S2A Maytag Portable Air Conditioner/Manual?
I have the M6P09S2A Portable unit that is leaking water everywhere. I have to place it in a large bin to keep it from draining on the floor. Any solutions?
Posted on Jul 20, 2011
Why is our a/c blowing room temp air when the setting is on cool?
It sounds like the compressor is not running. This could be due to a faulty thermostat, a bad start capacitor for the compressor, a bad compressor overload or simply a bad compressor. You would need a voltage meter to check all of these components.
Jun 20, 2014 | Maytag Portable Air Conditioner M6P09S2A
I have a window air conditioner, Maytag, the compressor keeps running and will not shut off. I have tried turning it off and on, but it still runs. I tried to turn it off by the button on the AC, but...
The compressor is controlled by a contactor (relay) the relay is stuck (contacts burned or if a solid state relay the "smoke has leaked out" :) it may require a control board change if it is a modern unit
Apr 13, 2011 | Maytag Portable Air Conditioner M6P09S2A
Unit triping braker when compressor turns on
the breaker is underrated the power that it takes to start the compressor is really big but only for a few seconds. That is called the inrush and the breaker should be rated for HVAC wich allows for this.
Mar 15, 2011 | Fedders 9,000 BTU Electronic Portable Air...
Power trip, now it doesn't turn on
Sounds like the compressor has gone bad...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 17, 2010 | Maytag Portable Air Conditioner M6P09S2A
Model # m6p09s2a portable maytag air conditoner unit...red light keeps blinking at the unit where power button is located....unit will not turn on. the light just keeps blinking
Greetings,
I have the same model air conditioner, and had the same symptoms. As you've probably discovered, Fedders is the company that actually built it, and went of business. No one is supporting it any more.
However, you may be in luck. I fixed the problem by simply tipping the unit almost all the way over on its back (leave a little gap) and letting the water drain out of the hose and the filter. After that, it started right up.
Hope that works for you. Stay cool. :)
Jun 16, 2010 | Maytag Portable Air Conditioner M6P09S2A
Jun 29, 2009 | Maytag NMPEB08F2A Air Conditioner
Window insert is missing
write down the model and serial#'s and call maytag and see if they have them most of the time you will have to order them online there should be a contact number for maytag on the unit or the paper work
May 25, 2009 | Maytag Portable Air Conditioner M6P09S2A
Need circuit board for Maytag portable a/c unit
As you asked requested,
Major appliance Parts
1-800-338-3790
8am-12 midnight
7 days a week
Quick ship if in stock.
Bless You,
Ngafm
Please rate me before you leave the site!
thank You
Jul 24, 2008 | Maytag Portable Air Conditioner M6P09S2A
9000btu Haier portable air conditioner HPAC99ER doesnt blow cold air. What do I need to do?
I own the Haier 9,000-BTU Portable Air Conditioner - White. This is the second day that my unit has blow out air that smells really bad. I went to check my unit to find that there was a leak of some sort of chemical that smells like what is blowing from my unit. What should I do?
Jun 06, 2008 | Haier Heating & Cooling
Heating & Cooling Logo
484 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
