No Volume to speakers
If I turn the volume all the way up I can hear sound from the computer itself but when I plug in the speakers I can't hear anything at all. Is there something I need to change or am I doing something wrong?
  • 1 more comment
  • sr20det2404 Jun 26, 2008
    i rebot my computer and now i have no sound from my speakers
  • jd4654 Nov 08, 2008
    I rebotted my computer and windows and now the speakers won't play anything I can tell the speakers are workin but can't figure out why it dont make sound
  • tonyaf Mar 31, 2009
    The light comes on on my computers speaker and i can hear the tone when i turn the volume up. But for some reason i cant hear the words form the online video that im trying to hear.
I rebooted my computer and reinstalled windows now my speakers dont work.How do I get them to work?
Posted on Jun 12, 2008
HOW TO VOLUME the speaker even if the volume is 100 already.why is it low?
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Volume problems on computers often happen for a variety of reasons.
Volume troubleshooting, however, is one of the easiest problems to troubleshoot because there are only a few things that usually cause the problems.
Usually the problem isn't even an error but just merely an adjustment that needs to be made.
Test your speakers.
This is the first thing you should check if you can't hear anything coming out of your computer. First try turning up the volume know and make sure you are in fact turning the volume knob and not a tone or balance knob.
Make sure the speakers are completely plugged in to the wall and the computer. Test with another set of speakers or headphones after you have done this.
Check the computer volume level.
On the taskbar is a volume icon, which usually looks like a small speaker.
Click on the icon and turn the volume up.
Make sure it has not been muted.
Double clicking on the icon will bring up a panel of several volume controls.
Try turning up the volume on each slider.
Go to Control Panel and choose "Sounds and Audio Devices."
Under the volume tab, click speaker volume and turn up the level if needed.
Turn up the application volume. Most programs that use sound have an additional volume control just for that program.
Find the volume control and turn it up.
Usually it is located in the lower right or left corner on the program, but you may have to search for it.
Troubleshoot the sound card.
Download the latest drivers from your sound card manufacturer's website.
Go to Control panel > System > Hardware > Device Manager. Click on "Sound, Video and Game Controllers."
Click on your sound card, select the driver tab and then click on "Update Driver."
Point to the file where you saved the latest drivers from the website.
After this, restart your computer.
The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a can of compressed air or fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
If this doesn't solve your problem, try reseating the sound card into your computer.
Hop this helps
Nov 11, 2012 | Lenovo Computers & Internet
Volume loss
Laptop or Desktop ?
Try swapping the speakers around to see if the problem is in the speaker itself.
Test your speakers.
Hope this helps
Nov 10, 2012 | Audio Players & Recorders
Speakers have no sound
Please check the below mentioned things :
Verify the AC power cord is plugged into the wall outlet. Turn the VOLUME knob on the right speaker until you hear a click sound. An LED will light next to the knob when the power is ON. Turn the VOLUME knob clockwise to raise the volume. Check volume level on the computer sound card or alternate audio source device, and set at mid-level. Check plug connections on the audio source. Make sure the signal cables are inserted firmly into the correct jacks. Make sure the 3.5mm stereo cable is connected and fully inserted into the "line-out," "audio-out," or the headphone jack of the audio source. Test the speakers on another audio device. Remove the 3.5mm stereo cable from the audio source device and connect it to "line-out," "audio-out," or the headphone jack of another audio source.
And if in in case u r unable to get it working ..
Replace the speakers ..
Jan 24, 2011 | Altec Lansing VS2120 Computer Speakers
It shows the speakers are on but no sound
If you have an extra headset around, plug it into the same place the speakers are plugged into, if it works, your speakers are bad (or check to make sure the power light is on on them and that their volume knob is turned up).
If you still do not get sound, click on your little volume/speaker icon by your clock, then click 'mixer' at the bottom of it (Windows 7 hopefully?). Make sure the different volume controls are turned up because sometimes one low one will affect the entire system.
(If Windows XP, right-click the speaker, then 'Open Volume Control'. Adjust until you hear sound.)
Dec 08, 2010 | HP JBL Platinum Computer Speakers
Sound plays on my system but i dont hear it at all.my windows
Let's start by checking
  1. Your speakers are plugged into the green connector on the computer
  2. Speakers have power, are turned on, and volume is up
  3. Check your "speaker" icon on your tray (lower right hand corner of desktop) - to make sure volume is up and not muted.
Sep 15, 2009 | Dell OptiPlex GX240 PC Desktop
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
Can't control sound
what you need to do is the audio you must plugged it in thegreen spot in the back of the pc
Aug 05, 2009 | Dell 5650 Computer Speakers
Low volume on external speakers, no volume on internal
I have all the audio drivers for that model. Please let me know what operating system you are using. These are large files, around 7mb for xp.
Mar 07, 2009 | MPC Computers ClientPro 414 All-In-One PC...
Problem with geting sound out of my external speakers.
adjust your sound or check the volume on the speakers itself, or try adjusting the sound on the computer, and check the sound card
Sep 02, 2008 | Audio Players & Recorders
Speakers have low sound
Look into your computer audio setup, usually a icon in the lower right. they have controls for volume, some have different areas such as oper sounds, outdorrs, etc. Maybe these are turned down or muted...Also plug a head set into the CD or DVD rom port in the front if yu have and see if the volume is good. Possible bad audio card. Also try different speakers. Small speakers sell for $20.00 or less.
Jul 08, 2008 | Logitech Z-5300E (970102-1403) Computer...
285 people viewed this question
 Grubhead
Grubhead
