Question about Toshiba TLP 261 Multimedia Projector
Toshiba TLP 560
Please help, I have a discoloration pattern on my projected picture (red on black, etc). It's not only in corners, it's a semi-circular pattern almost all-over, very disturbing. I saw another piece of advice talking about the polarising filter possibly being tarnished because of over-heating. Replacing this one shoul fix the problem, it was said. I disassembleg my projector up to the point I have been wondering where the filter is, actually. I attached a picture. Are those indicated by the red arrows, or the panels indicated by the green arrows, or which?
Thank you!
http://i28.tinypic.com/2gvimgg.jpg
The Machine
  • 788 Answers
SOURCE: Toshiba TLP s30 projector identification part
This is what Tishiba indicates in the manual for your problem:
Lamp went out during use, or won’t come on
→ Returns to standby after about 2 minutes. If the projector fails to
operate normally after turning the power back on, either the lamp
needs replacing, or there is a problem with the projector.
• If a lamp burns out, replace it with a new one.
• Unplug the power cord, and contact your dealer.
Obviously you are at the contact your dealer part which isn't really a good situation since you are in Brazil. Researching parts will get back to you when I find something.
Posted on Mar 28, 2008
techman
  • 3130 Answers
SOURCE: Toshiba TLP 261
What do you mean by red filter? There is no red filter in this unit.
Posted on Apr 08, 2008
projdoc
  • 2237 Answers
SOURCE: Toshiba LCD model#TLP-T60M. Projects images but
reset the settings to factory default. then make sure that the input matches the signal and that the cables are working. if you still have a problem, and the entire screen (including the initial toshiba screen) is entirely green tinted, you may have a main board issue.
Posted on Nov 11, 2009
projdoc
  • 2237 Answers
SOURCE: White areas in the image are yellow and the black are blue-green
you have a few issues. first is the yellow in white. the light filter on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you may have to replace the whole optical engine. as for the flashing horizontal lines, the power supply isn't cooling down and the caps are drying out, causing fluctuations in voltage. so, replace the power supply.
  • 6 Answers
SOURCE: I have a Toshiba TLP 260 Multimedia Projector
If all the fans are running and you are sure, than it sounds like you have a bad main control board. Double check that all the fans are running. If so you will need to replace the main controller, this is the board that the fans are plugged into.
Thanks the Projector Guy
Posted on Apr 21, 2010
Reset the lamp timer TLP560
can anyone help me to reset my toshiba tlp 560 lamp
there must be a command or conbination of buttons to do this
best regards
Aug 04, 2014 | Toshiba TLP560 Projector Lamp 195Watt...
Toshiba theaterwide tv turns on and off on it's own and picture is messed up
I presume you unplugged set for a while and plugged it back to see if problem clears (allows set to reset).
If whatever picture you see looks 3d or colors skewed that is convergence problem.
Apr 20, 2012 | Toshiba TheaterWide 46HM84 46" Rear...
Hello. How do I invert the image on a Toshiba TLP-2000 EDU Projector. Many thanks, Paul
Go into the setup menu.
One of them is the picture or positioning menu.
There are normally 4 options,
front projection standard / inverted.
rea projection standard / inverted.
dont move the projector whilst on or bulb is warm as bulb is very fragile at that time.
Please dont forget to vote this answer was helpful
Many thanks
Feb 19, 2011 | Toshiba TLP-XD2000U Mobile Projector
Jvc 52 inch tv. the picture on the upper left corner drops and is discolored
Hi if your tv is a Dlp or Lcd it will be a problem with the light engine.Basically there's 3 chips green,blue,red that create the image and colors.When they start to go bad or melt you will get color discoloration on corners on the center.You will need to replace the optical block ,you can find it on www.discount-merchant.com www.shopjimmy.com or ebay .Have a blessed day!
Oct 01, 2009 | JVC Televison & Video
Toshiba with Colour fail , red colour
the filter lense of color red had discolored
Feb 04, 2009 | Toshiba TLP 260 Multimedia Projector
Black, Red and yellow triangle in upper right corner of the scrn.
YOU HAVE A CONVERGENCE PROBLEM IC'S WILL NEED TO BE REPLACED. THE FACT THAT THE LINES DID NOT MOVE WHEN YOU TRIED TO ADJUST THEM CONFIRMS IT.
Jan 19, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 40h80 picture problem
replace c449 and also the damper diode
Nov 19, 2007 | Toshiba 40H80 40" Rear Projection...
Toshiba 46HM84 DLP Black and white pattern..
contact your dealer for service flashfor this symptom.(light tunnel)
Aug 11, 2007 | Toshiba 46H84 46" Rear Projection...
Projection Problem with Toshiba TLP 261
If its only in the lower left corner sounds as somethings blocking the lamp from the lcd These sets dont use a degussing coil so we know its not a magnetic problem Check and see if something crawed inside the set and is blocking a bit of the lcd?? ar could be dirt or dust too??
Mar 28, 2006 | Toshiba TLP 261 Multimedia Projector
Toshiba TLP 261 Multimedia Projector Logo
67 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
