I have a rca sdtv and when you plug it in a small red light flashes along with a matching beat. The tv won't do anything else, can you hel?
  • sseider Jun 13, 2008
    24v414T
  • kytnkat Jul 26, 2008
    power light comes on. blinks. then goes solid...like it usually would if there was a picture. Then nothing happens, no response from any of the buttons (can't turn off or on with remote or buttons, can't change channels or inputs).Picture stays black, doesn't make the sound like it's turning on.
    RCA SDTV 27" Manufacturered in March 2006, Model# 27V414TYX3 - Serial# G113CC0AO Chassis# ATC010A
  • 5,138 Answers
What is your model number # 52W20 which chassis ITC222, year?
Posted on Jun 12, 2008
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
No video from dazzle to pc
Hi and welcome to Fixyah,
I have something that can help you with, please checked if this is the same settings.
If you follow any of the videos, it won’t work!
Step 1: Install the Pinnacle Dazzle Video Creator Platinum software and make sure it works with the Dazzle DVC 100.
Step 2: Buy 3 RCA type Y cables. One male end, 2 female ends.
Step 3: Plug the male ends of the RCA y-connectors to the Dazzle DVC 100.
Step 4: Plug the Yellow, Red and White RCA connectors from the XBox 360 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Step 5: Plug a second triple RCA connector into the other end of the color matched RCA Y Connectors.
Step 6: Plug the other end of the triple RCA connector into the TV.
Step 7: The tricky part no one ever mentions: On the XBox 360 video cable, there is a switch that switches from HDTV to TV. You must switch this to TV!
Let me know what happen.
Apr 09, 2010 | Pinnacle Dazzle DVD Recorder
How do i connect dazzle to tv to record ps3 gameplay
Welcome to Fixyah.
Step 1: Install the Pinnacle Dazzle Video Creator Platinum software and make sure it works with the Dazzle DVC 100. Sometimes this is easy, other times, this is a very difficult task.
Step 4: Plug the Yellow, Red and White RCA connectors from the PS3 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Regards,
Mar 20, 2010 | Pinnacle Dazzle DVD Recorder
Have a rca, sdtv, 32", screen stopped working.
Nope, you have a bad part inside.
It's fix or replace time.
Jan 06, 2010 | Televison & Video
I have a RCA 27" flat SDTV purchase in
Ur power inverter board is dead.
U need new one.
Aug 20, 2009 | RCA TruFlat 27F520T 27" TV
My RCA 32 ' SDTV TrueFlat doesn't come on
sounds like you have the parental lock on to lock the buttons on the tv and the remote look in your manual for the tv to see how to fix it and if you dont have it there should be one online
Aug 02, 2009 | RCA TruFlat 27F520T 27" TV
Tv broken?
Yes your set can be fixed ,it may have shorted your hori out put transistor and also caused FBT to blow. Flyback Transfomer cost 150.00 up, to 175.00
Jun 19, 2008 | Televison & Video
Are TV just shut off
The high voltage power of your tv is not working only the light indicator is working . you need this to bring to the shop to fix the power supply.
Apr 14, 2008 | Gateway FPD2275W LCD Monitor
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
Electro Med Services...
