Question about Franklin Freezer Chef FIM70 Commercial Ice Maker
Compressor not comiming on - Franklin Freezer Chef FIM70 Commercial Ice Maker
  • 10,421 Answers
You have died compressor and need to replace.
Posted on Dec 15, 2010
Compressor runs but wont cool
Make sure the compressor is running it should be vibrating and get warm after a few minutes. If it is indeed running the smaller tube to the compressor should be getting warm if not it could very well be the compressor has stopped pumping. If the fans are not running they could be controlled from the control board and will come on when the sensors on the evaporator get to a certain temperature. I does sound like the compressor is the problem.
Apr 04, 2014 | Samsung RFG297AAWP 28.5 Cu. Ft. French...
I have a Turbo Air TGF-49F freezer and it is not cooling. The compressor unit seems to work but when I turn the unit on all I hear is the compressor running continuously but nothing gets cold.
Difficult for you to check this I'm afraid, if the fan on the cooling unit is working unless you have an experienced 'ear' you will not hear the compressor running or worse still occasionally clicking.
Possible faults are
1. Compressor not running (the fan will run even if the compressor does not) electrical fault
2. Compressor seized (consult your service guy) also true for the rest of these
3. Compressor not pumping
4. Refrigerant leak
Not much hope for a cheap repair
Apr 14, 2011 | Turboair 49 cu. ft. Upright Freezer...
Reaons for hussman freezer compressors failuer Model No:NLD 2
Normally compressors fail due to overheating. But just like any machine that may run 24 housr a day 7 days a week, the compressor may just wear out. Overheating is caused primarily by stopped up condenser coils. The condenser coil is the radiator like object that sits close to the compressor and dissapates heat created by the compressor. Also if the fan behind the condenser coil fails because of an obstruction or fan motor burnout the heat will not be dissapated properly. The compressor has protection built in that should shut it off during an overheating situation, but it can't protect it over a period of time where the compressor keeps trying to start and shuts down due to overheating. If you look at the condenser coil in many cases you will find dust and or grease build up so dense that no air flows through the coil. This is simply neglect or not knowing that the coil needs to be cleaned periodically. Also, if you have a refrigerant (freon) leak, your compressor will overheat. The cold returning freon helps to keep the internal components of the compressor cool as well as keeping the oil inside the compressor churning up onto the internal components. If you have a leak, it is not sufficient to just add freon every once in a while. Leaks need to be fixed by finding the leak and welding the leak shut. No refrigeration system should require "gassing up" other than the initial charge of refrigerant. Overheating can also be caused by a lack of air flow through the condenser coils because there is no space around the machine for air to flow into and out of the compressor compartment. If you have recently replace a compressor and it goes bad again, it may be burnout residue from the previous compressor that clogs the lines after a burnout. I hope this answers your question.
Oct 12, 2010 | Freezers
My upright freezer has stopped working. compressor cuts in every now and then, but cuts straight out after running for about 5 seconds.
your compressor is busted due to low chARGE OF OIL in the compressor or meybe the internal overload of the compressor collaps you must replace your compressor with the same s/n num..and size...
Aug 11, 2010 | Freezers
Model ffu213caw1: my freezer stopped cooling recently.there is power to the uniti hear a small click down near the compressor like it is trying to start and then it stops.compressor is warm to the touch...
Compressor is bad the clicking noise is the Start Relay/Overload is kicking on and off. compressor is warm because it's trying to start but can't Frigidaire is known for bad compressors. I don't think the Start Relay/Overload is bad because the compressor gets warm.
May 20, 2010 | Frigidaire 21 cu. ft. / 595 liter Upright...
Compressor doesn't sound as if it is running...power light is on ...is there a reset button for compressor? I have a kenmore chest freezer model #16949
Good day,
Sorry, no reset but if the compressor is not running, it could be the thermostat as well. You will need a VOM meter to check to see if power is reaching the compressor.
If it is, it could be the compressor overload protector, the compressor start relay, which are both under a cover on the side of the compressor.
Jan 27, 2010 | Freezers
Freeezer with no compressor activity
If all fans are running, but not compressor You could try to install 3 N 1 start kit, thats might help 50/50. If it will start compressor - be ready for compressor to go out soon. might work for a year.
Dec 13, 2009 | Kenmore Freezers
The freezer works fine, but if you unplug it, it won't start back up, you have to let it sit unpluged for about 30 minutes to an hour before it will come back on. Its like it needs to cool off, it does get...
The high side and low side of the refrigerant system , have to equalize , before the compressor can start . If you unplug , then plug back in , the high side has a lot more pressure , therefore the compressor will not start and the overload will cut the compressor off . When overload cools slightly , compressor will try to start again . If pressures not equalized , overload will cut compressor off again . As this happens , the compressor will get hotter and hotter . Eventually , pressure will equalize and compressor will continue to run . Very bad on compressor and components .
Aug 06, 2009 | Freezers
Compressor overheating
If you've recently repositioned the unit it could be positioned in an enclosure to tight to allow air circulation or too close to a heating vent.
Also clean the coils with a broom to ensure proper ventilation. Or the thermostat is going or gone.
Jul 27, 2009 | Freezers
Franklin Freezer Chef FIM70 Commercial Ice Maker Logo
113 people viewed this question
Top Franklin Freezers Experts
Dennis Boxerman
AJMAL KHAN
Marvin
Marvin
Are you a Franklin Freezer Expert? Answer questions, earn points and help others
