Question about Schwinn 430 Elliptical Trainer
What is the output of the ac adapter for the schwinn 430 elliptical???
It should be at the bottom of the machine in the front facing away from you if you are on it.
Posted on Nov 12, 2010
Replacement batteries for Schwinn Airdyne AD3?
It should just be 2 AA batteries. Remove the battery door on the back of the computer to expose the batteries. Remove and replace. Computer Graphite Airdyne Big Fan Schwinn 92823 SPORTSMITH net
May 16, 2014 | Schwinn 430 Elliptical Trainer
My Schwinn 430 elliptical makes a clunking noise when pedalling backwards but not forward. What is causing this?
I have a iron man cdt elliptical that was clunking . I found a shaft on the end of the crank was slipping in and out, inside the bearings. I shimmed it and retightened the retaining washer which prevented it from slipping . Smooth as silk now. It was very frustrating because all seemed tight at first.
Nov 10, 2012 | Schwinn 430 Elliptical Trainer
Need manual for schwinn personal trainer 405 tread mill
Hello Brend
Please download the assembly manual for Schwinn® 430 Elliptical from the link provided below :
http://download.dfxi.com/supportdocs/AM/Schwinn/SCH_430_AM_RevB_web.pdf
Please download the owners manual for Schwinn® 430 Elliptical from the link provided below :
http://download.dfxi.com/supportdocs/OM/Schwinn/SCH_430_OM_RevA_web.pdf
Oct 10, 2011 | Schwinn 430 Elliptical Trainer
The power cord for my schwinn 430 elliptical no longer stays plugged into the machine. I have to push it really had into the bike outlet so the machine turns on, but as soon as I take my hand off of it,...
Do you think the power cord is going bad? If so here is the parts list for the Schwinn 430 if you need to order a new AC adaptor. If you think the connection inside the machine is going bad you may want to find a servicer to look at it.
Apr 19, 2011 | Schwinn 430 Elliptical Trainer
During use, the speed goes to zero on the panel and then a couple minutes later, it shuts off....Schwinn 430 elliptical.
sounds like the sensor is loose or bad.I have the same schwinn 430 elliptical and my speed stayed at zero and after a couple minutes it would shut down.i called schwinn bowflex and they sent me a new sensor ($2.00)since my warranty expired and i installed it(not fun) and thats what fixed it. im back to working out.
Jul 10, 2010 | Schwinn 430 Elliptical Trainer
I have an Eliptical Trainer BY-430E. I keep getting Error 1 every time I turn it on to use it. Does anybody know how this can be repaired. Thanks in advance
Error 1 on a schwinn is a generic electrical error. Check your ac adapter and make sure you're getting the proper voltage off of it. Typically an error 1 warrants a replacement of either the ac adapter, the wire harness (wires that connect the power to the console) or the console itself. If the console has batteries, change those first, then check your adapter. If the problem persists, you're looking at a more in depth problem that will require taking the casing off the machine and individually testing each component of the machine. It's usually worth at that point to pay a tech to look at the machine for you.
Jun 28, 2010 | Schwinn 430 Elliptical Trainer
Where do you put a battery in a schwinn airdynne
To install new AA batteries just pop the battery door in the back of the computer
Apr 05, 2010 | Schwinn 430 Elliptical Trainer
Need to replace the drive belt on my Schwinn 430 Elliptical
http://download.dfxi.com/supportdocs/SM/Schwinn/SCH_430_431_450_SM_RevC_web.pdf
Follow this link for step by step instructions. Note you will need a crank puller which you can purchase at most bike shops. remove both covers then crank weldment(discs).
Jan 19, 2009 | Schwinn 430 Elliptical Trainer
Schwinn 430 Elliptical Trainer Logo
658 people viewed this question
Top Schwinn Exercise & Fitness Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
