Question about Kenmore Elite 45986 Front Load Washer
F20 Error Message
What does this error message mean and is there a quick fix? I'm not sure if the model number is correct, but it is a Kenmore Front Load Washer.
  • 5,911 Answers
"F20" is a water inlet problem. This indicates you have insufficient water supply for the washer. Whirlpool is the manufacturer of your washer and they recommend that you unplug the washer and check the following:
1. Check water faucets to ensure they are completely turned on.
2. Check the inlet hose screens where they connect to the washer. The screens can clog with sediment over time and require cleaning. This can be a problem if you live in an area with well water and/or hard water.
3. Ensure the inlet hoses are in good shape and are not kinked.
If you check all the common sense items first and the problem still persists, you need to check the water inlet valve. To access, you will need to remove the top panel of the washer by removing the three screws that hold it in place. Once the screws are removed, the panel slides back, then off. The water inlet valve is located in the left-rear of the washer just prior to the dispenser. Double the electrical connectors to make sure they are not corroded and double check the hoses that run from the inlet valve to ensure they are not kinked. A resistance check of the water inlet solenoids (with the connectors removed) should read about 800 ohms. If the solenoid readings are abnormal, replace the valve.
Please post back if you have questions or require further assistance. I hope you find this information helpful.
Posted on Jun 12, 2008
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
My washer stops &and F-20 appears on viewer. Whats wrong with my washer
water problem check screens in hoses and valves !! rrors F1, F11 and F20
  • Error F1 indicates a communication error between the computer and the washer. Unplug the washer for a minute and plug it back in, as this may correct the problem. Error F11 indicates a motor control error. It can be caused by improper voltage. Unplug the washer and check the connections. This may fix the problem. Error F20 indicates lack of water entering the machine. If there is no water in the washer, check that the water valves are turned on. If there is water in the washer, press "Stop" twice to drain the washer. Unplug the machine and check the hose connections.
Read more : http://www.ehow.com/info_12006668_error-messages-kenmore-he2-plus.html
Feb 21, 2015 | Kenmore HE2 Plus Front Load Washer
WHAT DOES ERROR MESSAGE 1E MEAN AND HOW DO WE FIX IT?
On LG's, a 1E error message usually means there is a problem with the water inlet valve. Check your shutoff valve under the sink, first, just to make sure someone didn't accidentally turn it off. If it's on, then it's most likely the water inlet valve located under the dishwasher.
Oct 18, 2014 | LG Dishwashers
Recently I have been getting an F20 error message. What does this mean?
F20 No water detected entering machine
Could be a couple things . Clogged inlet screens on the water valve, flow meter gone bad. Pressure tube has sediment in it.
Aug 31, 2010 | Kenmore Elite HE5t Washer
I am getting an F20 error message or SUD. I have
http://www.wikihow.com/Fix-a-Whirlpool-Duet-Washer-F-20-Problem
Jan 22, 2010 | Whirlpool GHW9300 Duet Washer
F20 error on Kenmore HE2 front load for no reason
under top cover does it have flow meter? ck connection and resistence with ohmmeter, ck pressure sw.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
F1 error message on kenmore gas range
The F1 usually means a problem with the touchpanel. It is also related to the F7 problem. I have developed a fix which may solve you problem. Please go to the following link for my fix.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my fix with over two thousand unhappy GE customers. Most report success. Please let me know if this works for you too. I am making a statistical study of this problem.
Regards,
Powerman
hutchipop@yahoo.com
Dec 05, 2008 | Kenmore Ovens
Kenmore HE2 Plus Error Code: F-20
You probably have this solved by now but for others who read this as I did.............
F-20 means
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Hope this helps everyone else as it did me, thanks
Oct 24, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
126 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
