Question about CTX Optoma EzPro 610H Multimedia Projector
Gives nice clear image for short time, then bounces between signal & no signal
My rear view mirror camera quit working I checked the fuse it's good the backup lights work.Help
Circuit/System Description
When the transmission is placed into REVERSE, a 12 volt signal is sent to the rearview camera image display module indicating that camera operation is requested. The rearview camera image display module then supplies ignition voltage and ground to the rear vision camera. The rear vision camera sends video information through the rearview camera image display module to the inside rearview mirror through a video signal + and a video signal - circuit. A grounded shielding also wraps the video signal circuits to reduce electronic interference which may degrade the video signal and cause a distorted or otherwise degraded image.
Rearview Camera Image Display Module (UVC)
In the instrument panel behind the driver side knee bolster to the right of the steering column
Do you know how to do electrical testing ?
Rear Vision Camera System Does Not Display
Ignition OFF, disconnect the harness connector at the rear view camera image display module.
Test for less than 1.0 ohm between the ground circuit terminal 3 and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance.
Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 2 and ground.
? If the test lamp does not illuminate, test the ignition circuit for a short to ground or an open/high resistance.
Ignition ON, park brake applied, vehicle in REVERSE, verify that a test lamp illuminates between the control circuit terminal 1 and ground.
? If the test lamp does not illuminate, test the control circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the BCM.
Ignition OFF, connect the harness connector at the rear view camera image display module. Disconnect the harness connector at the rearview camera.
Ignition OFF, test for less than 1.0 ohm between the ground circuit terminal B and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance. If the circuit tests normal, replace the rear view camera image display module.
Ignition ON, park brake applied, vehicle in REVERSE, test for 5.8-6.2 volts between the 6-volt reference circuit terminal A and ground.
? If less than the specified range, test the 6-volt reference circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the rear view camera image display module.
? If greater than the specified range, test the 6-volt reference circuit for a short to voltage. If the circuit tests normal, replace the rear view camera image display module.
Test for less then 1 ohm between the shield ground circuit terminal 10 at the rear vision camera display module harness connector and terminal D at the rear vision camera harness connector.
? If greater than the specified range, test the shield ground circuit for an open/high resistance.
Ignition ON, test for less than 1 volt between the signal circuit terminal 9 and ground.
? If greater than the specified range, test the signal circuit for a short to voltage.
Test for infinite resistance between the signal circuit terminal 9 and ground.
? If not the specified value, test the signal circuit for a short to ground.
Test for less then 1 ohm between the signal circuit terminal 9 at the rear vision camera display module harness connector and terminal C at the rear vision camera harness connector.
? If greater than the specified range, test the signal circuit for an open/high resistance.
Ignition OFF, disconnect the harness connector at the inside rearview mirror.
Ignition ON, test for less than 1 volt between the following signal circuits at the inside rearview mirror harness connector and ground:
• Video + signal circuit terminal 6
• Video - signal circuit terminal 7
Test for infinite resistance between the following signal circuits at the inside rearview mirror harness connector and ground:
? If greater than the specified value, test the signal circuit for a short to ground.
Test for less then 1 ohm between the following signal circuits:
• Signal circuit terminal 12 at the rearview camera image module and terminal 6 at the inside rearview mirror.
• Signal circuit terminal 11 at the rearview camera image module and terminal 7 at the inside rearview mirror.
If all circuits test normal, test or replace the rear vision camera.
Ignition ON, park brake applied, vehicle in REVERSE, verify a clear rear vision image is displayed on the radio.
? If a clear rear vision image is not displayed, test or replace the inside rearview mirror
Feb 21, 2016 | 2009 Hummer H3
Why does the rpm & speedometer needle bounce as soon you put in the key & haven't even turned the key
The electrical portion of the switch/tumbler portion of this system most likely has a short...
Aug 07, 2014 | 2000 Cadillac Catera
Speedometer bounces from current speed down to zero (where it sometimes sticks)
It won't be a cable, as it's impossible for a cable driven speedo to perform this way.
It's an electronic speedo.
Check and/or replace the speedo sensor in the gearbox housing.
Nov 12, 2012 | Hyundai Motor 2003 Elantra
I Have a GL2400 Allen & Heath Console. The other day we were working out doors at a Festival and all of a Sudden I stopped receing signal to the Console. I tried all chanels and got the same result. I...
I will ask a question: Did you remember to power ALL inteconnected equipment from the SAME and I do meanALL and SAME receptacle or power conditioner module? If you powered your stuff from several receptacles in a large venue, likely ground system bounce has caused damage. I don't know what you mean by "dont get any signal in."... explain that... There are tests to run to isolate the problem but if you got hit with ground bounce transients you could have major damage. That is a big board for an outside venue so you might describe what you had configured from mics, etc. to speakers. ALL professionals know to run power back from where their amps are to the mixer alongside the snake. I will give you points for carrying a spare... ALWAYS a good plan as electronics DO fail and of course at the worst time.
Aug 24, 2011 | Allen & Heath Allen Heath GL2400 32 Live...
Time setting
The clock will set itself at specific time set times, this is likely to be at 0200 0400 and 0600.
You will however be required to set the time zone, the switch is likely to be on the back.
INFO:
Atomic Time Synchronisation:
How does it work.
SHORT VERSION:
Radio set clocks and watches receive a 60-kilohertz, radio signal from the NIST the official timekeeper for the US and is located in Boulder, Colorado. Ft. Collins. they use atomic clocks and transmits this official time via high frequency short-wave and low frequency AM radio signals, satellite transmission, Internet, and via telephone.
REFERANCE LINKS:
OFFICAL TIME:
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
PHOTO OF ANTANA TRANSMITTERS:
http://tf.nist.gov/stations/wwvb.htm
Jan 19, 2010 | Sharper Image Wireless Caller ID with...
My 2003 Hyundai Santa Fe ABS light is staying on but the ABS is not engaged.
Here are all the possible problems which can turn on your ABS light.
C1101 Battery voltage over volt: 18V or more ○ ○ BR - 69
C1102 Battery voltage low volt: 9.5V or less ○ ○ BR - 69
C1200 FL wheel sensor: open or short to ground ○ ○ BR - 66
C1201 - Range/Performance: speed jump or damaged exciter ○ ○ BR - 67
C1202 - No signal: air-gap error or wrong excite ○ ○ BR - 68
C1203 FR wheel sensor: open or short to ground ○ ○ BR - 66
C1204 - Range/Performance: speed jump or damaged exciter ○ ○ BR - 67
C1205 - No signal excite: air-gap error or wrong excite ○ ○ BR - 68
C1206 RL wheel sensor: open or short to ground ○ ○ BR - 66
C1207 - Range/Performance: speed jump or damaged exciter ○ ○ BR - 67
C1208 - No signal excite: air-gap error or wrong excite ○ ○ BR - 68
C1209 RR wheel sensor: open or short to ground ○ ○ BR - 66
C1210 - Range/Performance: speed jump or damaged exciter ○ ○ BR - 67
C1211 No signal: air-gap error or wrong excite ○ ○ BR - 68
C1604 ECU hardware: ECU internal or valve failure ○ ○ BR - 70
C2112 Valve relay: valve relay or fuse failure ○ ○ BR - 70
C2402 Motor-Electrical: open or short to battery, motor relay, fuse or motor lock fail ○ ○ BR - 71
C1503 TCS switch failure δ ○
C1605 CAN Hardware failure δ ○ BR - 71
C1610 CAN Bus off failure δ ○ BR - 71
C1611 EMS Time-out failure δ ○ BR - 71
C1612 TCM Time-out failure δ ○ BR - 71
C1613 TCM Un-matching failure δ ○ BR - 71
C2227 Brake disc overheat δ ○
C1274 G-Sensor signal fail (only 4WD) ○ ○ BR - 72
C1275 G-Sensor open or short to ground (only 4WD) ○ ○ BR - 72
You'll need a scanner which is compatible with Hyundai's ABS system to retrieve any DTC's (Diagnostic Trouble Codes) stored in its computer. Any time the ABS light comes on, there's a DTC stored in its computer - that code will tell you where the problem exists. Then you can go from there.
Jun 03, 2009 | 2003 Hyundai Santa Fe
Gate way 210 projector
needs cleaning. and the signal needs to match the source (laptop). go into the menu to adjust.
Dec 05, 2008 | Gateway Projector 210 Multimedia Projector
THE VIDEO IMAGE ''FREEZES'' ON THE SCREEN AND SOUND STOPS
2 things the easy one is check for signal strenght (is this happening on over the air stations? or also on Video inputs) if it OTA only a signal amp will clear this issue not if you are still getting this on both OTA and Video inputs looks to be a main Board replacement?
Nov 25, 2008 | Insignia LCDTV26 26 in. Television
Image gets pixelated and a black screen flashes
yes its a cable box problem, find the channel you are having more problems with,press guide in the cable box remote and you will see how the box where the video is will still have the problem and the guide with channels info its going to be clean,
100% weak signal
hdtvman
Jun 22, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
CTX Optoma EzPro 610H Multimedia Projector Logo
20 people viewed this question
Top CTX Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a CTX Office Equipment and Supply Expert? Answer questions, earn points and help others
