Question about Dell (6F858) Cooling Fan
Dimension 3000: P4@2.8GHz. NOISY - alway has been. Want to remove green shroud permanently, add quiet 80mm thermistor-controlled fan to CPU stock heatsink (without exciting a BIOS temp alarm), replace rear case fan with a quiet 92mm Nexus fan. Feasible? Need some direction on the details of compatibility and installation. -Paul
  • joecoolvette
    joecoolvette Nov 02, 2010
    Can do pm_tiscione. Would like the computer manufacturer name, and model number. Have to see if it's feasible, and perhaps can give detailed info in knowing the desktop computer you're referencing to.
    State in a Comment. (Believe upper right of your page is the Comment 'button') Will guide you with proper cleaning, applying fresh, new thermal paste, and recommendations for a Heatsink/Fan combo, if you wish also.
  • Paul Tiscione Nov 02, 2010
    Answering joecoolvette (is this the proper way to do it?): It's the Dell Dimension 3000, with the 478 mPGA socket. I keep it clean as a whistle, and lean and mean in terms of software maintenance. I've had it for 5 years, sole owner. I'm going to upgrade RAM to 2G (from 1G) as well. All this to have the unit last me until the Spring when I build myself a solid state memory, i5-760 SATA III USB 3.0 non-gaming unit. I'm trying to restrain myself from doing the build prematurely (before the new technology is fully seated) by resolving some suboptimum performance characteristics with the current unit that I've been tolerating for the last 5 years. Thanks for any help.
    -Paul
  • Dell Master
  • 2,072 Answers
As for the green shroud, I would not recommend removing it. The computer case is designed to correctly circulate the air through the system and safely out. As for replacing the fans you can replace them with anything you like, just make sure the new fans are the same dimensions they come in szies 40, 60, 80, 92, 120, 140 and a newer 200 mm form factor so you can just measure them if you don't know the correct size. Next look at where the fans plug in, if it is a three pin plug then they fan's are kept at optimal speeds via the motherboard and bios. So they are already controlled by heat sensors / thermostat so to speak. If they are 2 pin then they just run full speed usually. For the back fan just make sure it is the right size and pin out. You can hook a 3 pin fan to a 2 pin fan plug on the board it will just run full speed all the time. For the CPU fan buy a combo fan/ sink and just make sure the sink is the same as the existing one so it will fit on the motherboard. You could probably get rid of the green shroud if you went with a really high end fan / sink for the CPU but that's up to you. For the thermal paste it is easiest to put a small blob in the center of the CPU and then use a plastic card, such as a drivers license to spread it out to cover the entire CPU, thinly and evenly. Add small amounts if you need to to cover the entire surface. Try not to have a bunch oozing out the sides although it won't really hurt if it is.
Posted on Oct 16, 2011
How do I remove and replace a CPU cooling fan on my Dell Dimension 2400
Make sure u can open the casing well to expose the interior parts without causing any damage. Then by close look at the processor area , that is where the heat sink is located. Normally the dell dimension 2400 has a green channel shaped structure that acts as a passage for the air that enters in and out for cooling the heat sink. It has a locking parts that slides into the casing back by slight pressing to the back of the casing just behind the processor area, be so observant to notice the locking parts. then the fan is just fixed behind that green " channel like" and its fixed on the rear side of the casing, 25275582-o0cuhlgwrl13okm3u3q5444d-5-0.jpg
Nov 08, 2014 | Dell Dimension 2400 PC Desktop
Mt dimension 3000 gets very noisy when the weather
That's because it heats up more easily and faster, which usually makes the fans spin faster and results in being noisy. Have you ever cleaned out the interior of the computer? If not, or if it's been awhile since it's been done, then buy some canned air for dusting electronics, open the side of the computer case (while it's not powered ON), and blow out the fans and the heat sink. If you get alot of just clogging up the heat sink, then it will not dissipate heat correctly; which results in the fans running more often. It that doesn't help any, then I would try to figure out if one of the fans is making alot of noise because it's going bad. You can find replacement fans on ebay, or at local electronics\computer shops.
Apr 10, 2010 | Dell Dimension 3000 PC Desktop
My computer has always been extremely noisy.
has the cooling fans been cleaned lately?PC's shouldn't be noisy to the point you're asking for advise about it. Is it a grinding noise, a clicking noise..more info plz.
Don't Forget to rate the advice!!
http://www.aa1consulting.com
Jul 27, 2009 | Dell Dimension 3000 PC Desktop
How do I remove the fan shroud from a dell dimension 8300?
there are two clips one on the top and one at the bottom u have to press both the clips and open the shroud.
Jun 07, 2009 | Dell Dimension 8300 PC Desktop
Dell Dimension 3000 CPU Fan does not run
I agree with both of you. As long as you are not experiencing any heat event (shutting down and rebooting) just ignore the error message. If the fan is on and running at a fair speed, you shouldn't have and problems.
Now should you start to have heat problems, don't boot the computer until you have a larger CPU fan in place...and too you may be able to add an additional fan to the system for reassurance. the added noise is worth the security of not having a CPU meltdown.
Those large 120 are very quiet and move air, if you can find a place to hang it.
Good luck, hope this helps. please leave rating -thank you kindly
Apr 20, 2009 | Dell Dimension 3000 PC Desktop
Noisy fan
Usually the heat sensor on either the CPU or the mother board through the BIOS software ajusts the sped of the van. Are you talking about the CPU fan , The Main case fan or the power supply one?
Feb 28, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Replacing the fan or fans in a dell 4600 with the quietest fan I
First you need to tell us which fans are the loud ones you are talking about but normally it is the cpu fan. Any computer parts store should have various fans available for different chipsets.
This link will take you to a page to find a fan. You will probably have to get the model number off your current one to find an exact match
http://www.frozencpu.com/cat/l3/g36/c15/s700/list/p1/Fans-12_Volt_Fans-92mm_x_38mm_Fans-Page1.html
Jan 07, 2009 | Dell Dimension 4600 PC Desktop
My CPU is making lot of noise especially when I'm using programs like Adobe reader
The CPU wont make noise unless its frying. So its either your hard drives, cd drives, or your fans.
If its your fans i sugest buying newer "Cool Master" fans that are powerful but less noisy
Oct 20, 2008 | Mesh 80mm Aluminum Fan Filter Fan Kit
Noisy fan
We have a Dell Dimension 4700C too. We had it on a 3-year warranty and the only problem with it was that from that to time it would become abnormally noisy, too noisy in fact. Dell sent a repair guy twice, and they changed the heatsink/fan assembly unit both times, and the third time we did it ourselves (it's not that hard to do), but here's the thing, we noticed how DUSTY it was when it came out, we wondered how it even worked with all that dust. So, now our warranty has expired, and guess what, the computer started making that terrible racket again, so this time, we opened it, armed with the vacuum cleaner and a can of compressed air, gave the whole inside of the computer a good once over, removed the heatsink/fan assembly and cleaned it thorougly (you can't do this unless it is out), and it worked like a charm, can't even tell the computer is running. Hope this helps.
Nov 09, 2007 | Dell Mini Fan. Dimension (W x H x D) in....
Fan Noise on Dell Dimension 8100
All computer fans have a general design.  The name in front of "fan" really refers to the designation.  You'll see case fan, processor fan, CPU fan, cooling fan, etc.  In the case of CPU/Processor fan, some are sold with heatsinks (the metal block sitting on top of your CPU).
The first thing you want to do is make sure the fan is clean.  Chances are dust buildup is causing the excess noise.
If that's not the case and you're looking to replace the fan, then you first need to find out the size of the fan. General sizes(diameter X width in mm) are listed on this page:
http://www.svc.com/case-fans.html
Generally, you're looking for something that will match the size of what you're replacing & push enough air at a reasonable noise level to cool the heatsink/CPU.  You want to stay in the area of 30dBA max for noise.  You also want to see if it has a 3-pin or 4-pin connection.
For example, if you have an 80mm fan, I would suggest something like this:
http://www.svc.com/saf-b82-19.html
It's pretty quiet with good airflow.  Also, it has a 3-pin connection, but includes an adapter for a 4-pin connection.
Z
Oct 27, 2007 | Dell (6F858) Cooling Fan
Dell (6F858) Cooling Fan Logo
162 people viewed this question
Clive
Clive
Alun Cox
