Question about Samsung HLR5667W 56" Rear Projection HDTV
Have to re-set everytime to work
Had problem with not turning on, thought was lamp problem that was replace, but NO. still not right, almost something different every time like modes{dvd,etc} the HMI is ok others not or will get stuck and eventually shut off - OR always when tuning on {lamp/fan ok} no picture after warm up then shuts off. Can only unplug for few minutes and try again then no problem picture good and everything,unless you turn if off, then have to start all over. Other thing noticed when off the red LED's blink off about every 20 seconds which I never noticed before.Why is a $3000 tv about 2 years old such a problem??
  • MufflerMan Jan 18, 2009
    When you power on, color wheel spins up and lamp fires up, 30 seconds later everything shuts down. You unplug it for 10 seconds then plug it back in and works fine for thirty minutes. Picture freezes then shuts down. With HD antennae, if you pick a weak channel picture will pixulate and lock up..remote will not respond. Please Help. I need my tv fixed by the super bowl!!
  • 203 Answers
Cause it's the official tv of nascar and the nfl and most other really expensive advertising. As a servicer and an owner of the same set, I first would try to vacuum out all vent holes behind set. This has caused mine to shutdown several times. I don't completely understand you about modes, but make sure all audio/video cables are connected well and hdmi cable. Also, make sure that the door switch on the lamp cover is fully engaged. They had an intermittant problem with some of them not making good contact. Go over your power strips and/or extension cables real good and hope for the best. Good luck.
Posted on Jun 12, 2008
Hi, I have a Mitsubishi wd-57733 dlp tv that shuts down
Ballast is possible if repeated lamp failure but I have a solution I posted several times for this type of problem that works and is simple to try:
Apr 30, 2012 | Mitsubishi WD-57733 57" HDTV
How do you remove the lower tail lamp assembly to
i thought you replaced the bulbs from the inside, look on the inside for a plastic cover over the bulb recepticals, take off cover you should see the bulb sockets, twist 1/8 to a 1/4 turn counterclockwise,it should come right out,luck
Jan 31, 2010 | 2004 Kia Sorento
My SCEPTRE X37 is making a distortion noise when turned on the volume works but not with out a humming sound ?
Wondering how old the set is?
Is it still under warranty - if it is - take it in right away and get it fixed.
If not - my thoughts is that you are going to have a problem with the power supply soon. This usually is an indication that something 'not good' is happening to either your main power supply or the Florescent back lamps ballast power supply. My thoughts are bad Capacitors that are drying out. This happens on many of these types of LDC flat panels.
A/V Media Guy
Nov 23, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
I have samsung hl-p5085w and the bulb shuts off i turn the tv right back on and it works for like 40 mins and does it again any thoughts?
Hi,it sounds like your lamp is going bad,its symptoms are : will shut off and on,led indicators.The lamp on your set last 6000-8000 hrs 2--3 yrs and its made by Philips .Found it here: If you've replaced the lamp before it might be the board that powers it ,it's called the ballast.Good luck nad God bless you!
Nov 18, 2009 | Samsung HLP5085W 50" Rear Projection...
Lamp burn out 3 time in 16months
clean out your projector. if there is a lot of dust and/or no air flow, the lamp will overheat and die. it needs to cool. use canned air and blow out any and all dust from inside the projector. make sure the fans work. also, don't buy lamps from "bob's lamps". get it from a reputable benq dealer.
Nov 10, 2009 | BenQ W500 Projector
LMP-H150 reset hours on sony cineza VPL-HS2
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS2
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Jul 04, 2009 | Sony Cineza VPL HS2 Multimedia Projector
Sony kf-50XBR800 tv turns itself on and off
I just purchased a replacement lamp off ebay and the TV is working fine now. Color looks better too (which I guess I should have expected). Search for "REPLACEMENT LAMP SONY XL-2100U" on eBay and look for seller "niosales". I paid $129 out the door. Their are other auctions for this lamp you can check out. Make sure you look at lamps that include the entire lamp housing, not just the bulb.
Jan 24, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony grand wega started turning on and off continuously
codes consist of N blinks, a pause and N blinks again,valid error codes are 3, 4, 5, 6 & 9 blinks.
Jan 23, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
never fool with led or indicator lamps.... its telling you your power is dropping out somewhere ...most likely a regulator on the PS Board.
Sep 02, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLR5667W 56" Rear Projection HDTV Logo
142 people viewed this question
Jerry Greenberg
Jerry Greenberg
