Question about HP Officejet J5780 All-In-One InkJet Printer
Printing both side of the paper using HP Officejet J5780 All in One
Okay, I am going absolutely nuts trying to figure out how to use the duplex printing .... I choose the option ... load my paper ... it prints all the even pages and then when I go to re-load the paper ... where is the 'ok' button???? The printer just blinks saying "printing document" but it doesn't print, it doesn't move .... so what's the secret? How do you print the other side? What button to do I press to continue the print? Are ya understanding this?
Thank you kindly ... my e-mail is cczito@sbcglobal.net (how am I going to get an answer.
thank you, Christine
  • thebit Jun 13, 2008
    thank you.
Make sure that you have the duplexing option turned on in your printer configuration. The "OK" button is right below the window that shows the date and time. Have a look here:
http://h71016.www7.hp.com/html/interactive/j5780/model.html?jumpid=in_r2910_3d/PDI/j5780%7Cshowcase%7Cflash
Posted on Jun 12, 2008
I have a 18 mo old 8500 OJPro wireless that won't advance the paper, makes a clicking sound and gives a false paper jam error. I have seen a split white gear within a black clutch assembly on the left end...
Follow these steps in the order presented to resolve the paper jam. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c02073375.gif c01994705.gif Step two: Clear the jam from the rear of the product CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Turn the product around so that you can access the rear side. Figure 1: The rear side of the productc01617574.gif
  5. Push in the button on either side of the two-sided printing accessory (duplexer), and then remove the duplexer. Figure 2: Remove the duplexerc02051407.gif 1 - Press the buttons on the sides of the duplexer 2 - Pull the duplexer out of product
  6. Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them. Figure 3: Gently remove the jammed paperc02073376.gif CAUTION: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 4: Remove scraps of paperc02073377.gif
  7. If you do not see jammed paper in the rear access area, push the buttons on the latch on the rear of the duplexer, and then lower the cover. Figure 5: Open the duplexerc01617577.gif 1 - Latch on rear of the duplexer 2 - Duplexer cover
  8. Remove any jammed paper from inside the duplexer.
  9. Close the duplexer cover.
  10. Gently push the duplexer into the product until it snaps firmly into place. Do not press the buttons on the end of the accessory while you reattach it. Figure 6: Reattach the duplexerc01617578.gif
  11. Reconnect the power cord to the rear of the product.
  12. Plug the power cord back into the wall outlet.
  13. Press the Power button (c01602202.gif ) to turn on the product.
Step three: Print a self-test report Follow these steps to print a self-test report. Printing a self-test report verifies if the hardware functions correctly.
  1. Load unused, plain white paper in the input tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press the Setup button (c01726396.gif ).
  4. Press the Right Arrow (c01185072.jpg ) to select Print Report , and then press OK .
  5. Press the Right Arrow (c01185072.jpg ) to select Self-Test Report , and then press OK . The self-test report prints.
Oct 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HOW DO I OBTAIN DOUBLE SIDE PRINTS?
hello,
The HP Officejet 5610 all-in-one printer does not support double sided printing. There is no duplex option available for this unit. If you need to print on both sides you would have to print one side, remove the paper and reinsert it upside down and print the next page. If you are going to be printing large amounts in duplex then you would be better off to get a new unit, look for ones where the model number end in a D, this indicates d the duplex feature.
Buddy
Corporate Computer
May 14, 2010 | HP Officejet 5610 All-In-One InkJet...
HP Officejet J5780 now prints in mirror image. I
Go to printing preferences and change the mirror image option to off and then try printing again. Use this figure as a guide:
Sep 08, 2009 | HP Officejet Pro L7680 All-In-One Printer
It starts printing, then stops, the printer cartrige is jammed
Try emoving the duplex cartridge on the back (return printer to it's original configuration) and try printing. If the printer prints OK, then re-attach the duplexer checking for anything that could interfere with the print cartridge.
If the printer doesn't print, then I suspect something has fell into the printer and is creating enough resistance for the printer to detect and report. Turn the printer off, Remove all the cables from it. Try inverting the printer and gently shake it to see if anything falls out that could be jamming the printer cartridge.
Jun 02, 2009 | HP OfficeJet Pro K8600 Printer
HP all in one - J5780 is having paper jam every other piece of paper and when printing the paper is blank
The sensor detecting the movement of the paper may have failed. As it requires expert service and replacement of the sensor better to contact the Service person.
Mar 25, 2009 | HP Officejet J5780 All-In-One InkJet...
Printing duplex and legal size.
I don't have legal size paper to test this with so it's a theoretical point but it looks like the printer will not do duplex in anything other than:
  • A4
  • Letter
  • B5 (JIS)
  • Executive
You can always print in duplex manually which is always an option regardless of paper size.
Hope that helps.
Mar 02, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet J5780 All-In-One Won't print double sided with Vista
You can install an instance of the Deskjet 6500 series drivers using "Add Printer", local printer, (use the same port the J5780 is installed on). You can have this co-exist with the J5780 driver and you could name it J5780 Duplex if you wish.
Regards,
Bob Headrick, MIcrosoft MVP Printing/Imaging
Mar 02, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP Officejet J5780 All-in-one Injet prints a grey line down the right side of the page when copying using the automatic document feeder. It does not show up when printing; and it does not show up when...
lift the feed area and look at the small glass plate where the auto feed paper is actually scanned. That needs a good cleaning. Since the paper runs across it even a tiny little obstruction such as paper left from a paper jam or a dot of ink from that pen you used to unstick that last paper jam (maybe its just me??). That one dot turns into a line when the paper rolls across it. Clean well and the line will dissappear.
Feb 27, 2009 | HP Officejet J5780 All-In-One InkJet...
HP Officejet 7210 All-In-One printer two-sided printing
Had the same issue with an Officejet 7210.
Basically, what the printer is trying (not very well) to tell you is that it is not capable of handling the entire two sided printing project automatically - which for reasons that are completely obscure is the default setting for two sided print jobs - way to go HP!
To solve the problem, open up the printer's properties window (or preferences depending on your approach). On the printing shortcuts page, you should find a drop-down menu entitled Print on Both Sides. This drop down should read 'Automatic' (which indicates that the printer will print the first side, flip and reload the paper and print the other side without any intervention - yeah, riight). Simply change this setting to 'Manual' and the problem is solved!
Happy printing!
'Doc'
Nov 23, 2008 | HP Officejet 7210 All-In-One InkJet...
Duplex printing
This model "faked" duplex printing using the printing system and you reinserting the paper to print the second side. Go to hp.com and download the "plug and play scan/print driver package" that is appropriate for your operating system.
Feb 21, 2008 | HP LaserJet 3055 All-In-One Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
164 people viewed this question
Seeker5211
Seeker5211
