Question about Homelite Garden
Gas mix for Homelite backpacker 08017H - Homelite Garden
  • 297 Answers
50 to 1 mix is fine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 03, 2010
What is the gas to oil ratio for a Homelite backpack blower model # UT08111A
50:1
consider using stihl 50:1 oil as it is made to run in any 2 stroke engine at any ratio that way you only need one fuel tank correctly mixed for all 2 stroke operations
Jun 25, 2017 | Homelite Garden
Oil leaking from an older homelite weedeater
Oil leaking.? The only oil that would be in the machine would be the 2 stroke mixed in the fuel.. I dont understand where 'oil' would be leaking from. (more info please)
Also your question refers to an 'older homelite weedeater' yet its titled 'Problem with Stihl BR400 Backpack Leaf Blower' Which one is it.?
Mar 14, 2013 | Stihl BR400 Backpack Leaf Blower
Trouble shoot homelite backpaker 8580A
It might be your fuel cap vent needs replacement. FYI: Ethanol in gas should be no more then 10%. Small engines need 10% or less if possible. Ethanol also corrodes rubber and cylinder parts very quickly. In cars it's OK to use but not small engines like gardening, generators etc. Also, Ethanol is bad on mileage performance because it doesn't burn well. In my area, mostly Chevron, Shell, Mobile gas are more near the 10% mark. You can always go in the station or have them show you the chemical mix on there last fill up! The lower the ethanol % the better your gas mileage by maybe 10%.
Oct 17, 2012 | Homelite Gas Fuel Cap Blower Backpacker...
MY homelite BP-240 backpack blower will not run with out the assist of starting fluid. First I tried to start it with just pushing the gas primer bulb. after no success I just sprayed start fluid . It will...
dont spray starting fluid in there to start it has to have a gas oil mix for the piston to have lubrication it will scar or burn the piston and cylinder wall check the fuel lines to see if they need replaced and the fuel filter also the priming buld to for cracks etc.
May 18, 2011 | Homelite Consumer Products Backpack...
What ratio of gas mixture 2 cycle oil to a gallon gas
You mix that 50 - 1 or 2.8 ounces per gallon of gas...
heatman101
Sep 30, 2010 | Homelite Blower Frame Up04405 Up04405a...
Need to know gas mixture
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
If properly adjusted your blower will operate fine on 50:1 regardles of what the manual reads. HTH
Lou
Jan 29, 2010 | Homelite Consumer Products Backpack...
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Blower runs fine for 30 or 45 mins, then will not come up to speed.
there is a fuel filter in the fuel tank that some times gets cloged try that and fresh gas -oil mix
Nov 01, 2008 | Homelite Consumer Products Backpack...
Garden Logo
170 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Homelite Garden Expert? Answer questions, earn points and help others
