Question about Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
Our Bosch SHE44 dishwasher runs through the regular wash cycle, but then holds at 1 minute and continues to run, never draining. The filter screens are clean. What can this be?
  • 90 Answers
SOURCE: help with dishwasher
What Brand is it?
Posted on Jan 05, 2008
aborcass
  • 2651 Answers
SOURCE: Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Posted on Mar 10, 2008
ginko
  • 19396 Answers
SOURCE: my bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Posted on Feb 07, 2009
  • 27 Answers
SOURCE: Bosch dishwasher whining
if you listen to the appliance and the noise is louder on the rhs and low down this is probably the main wash motor they sometimes do whine if you can live with the noise leave it alone if not you basically have to take the whole applianmce apart for access to the motor costly repair would take a trained pro about 90 mins to replace the motor
if the noise is coming from the front of the appliance more to the lhs and is intermittant ie when it first starts up and then about half way through its likely to be the drain pump relitively easy to replace and you dont have to take the appliance to bits just go at from the front
good luck
Posted on Mar 13, 2009
My 15 yr old Bosch d/w starts at 13 min & runs to 1, doesn't gets to CL. No water in or drain out.
IF IT ENDS UP WITH WATER SHOWING AT THE END OF EVERY WASH THEN THE DRAIN PUMP IS JAMMED OR FAILED THE DISHWASHER PROG WILL JUST KEEP LOOPING BACK TRYING TO DRAIN THE WATER.
Mar 04, 2017 | Bosch Dishwashers
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Washing cycle wont complete
I had the same problem. Called the repair man, who said it was a defective control board. He ordered a new one, replaced it and now the problem is fixed.
Dec 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Dishwasher continues to run beyond necessary time
most likely the microprocessor has failed
Good Luck!
Feb 20, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch SHU43C
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher
what is the model #?... there are 2 buttons when pushed together it will drain the water out..try the button to the left next to power scrub... and economy...hold the 2 buttons for 3 sec. you will hear you drain pump running.. if you don't hear any water draining out into your sink, you might have a clog d/w drain line.
May 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU5316
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
Apr 15, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher Logo
293 people viewed this question
Top Bosch Dishwashers Experts
shaun taylor
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
