Question about HP Computers & Internet
Wont Charge I have an HP Compaq 6510b, It wont charge with the a/c adapter only when I have it on the docking station. I have purchased two batteries and two a/c adapters and nothing works, can you help?
  • 24 Answers
Does the laptop power on and load the operating system when the AC adapter is connected without having a battery installed or having the laptop in the docking bay? If so, then the problem is either with the battery or the internal charging circuit. If the laptop is less than a year old, return it to HP for repair under warranty. If the laptop will not power up with the AC adapter, no (or dead) battery, and not docked, then the problem could be with the power connector on the left side of the laptop. If the power connector jack that the AC adapter plugs into is loose, then the jack will need to be resoldered or replaced. If you don't have experience disassembling laptops and soldering electronics, you should take it to a repair shop. If it is still under warranty, take it to HP. They have had problems with other laptops with loose power jacks causing them to offer repairs even after the warranty had expired. If the power jack is good but the laptop will not receive power from a known good AC adapter, then the most likely cause is a defective circuit on the motherboard. Hope this helps.
Posted on Jun 12, 2008
    Genius:
  • 2,028 Answers
Generally I would say power supply, but I'm leaning towards the power management chip on the motherboard. You can send it off and have it repaired or replace the board.
When pluged up it say plunged in not charging
It could be that the battery is at it's full charge. Do you have the correct power adapter plugged into the laptop? Is the battery older than 2.5 to 3 years? Deplete the battery by unplugging the power adapter and letting the laptop use up the battery and shutdown. Then plug the adapter back in and power up the laptop. Does it say charging now?
Mar 20, 2015 | HP Compaq 6510b PC Notebook
HP 6510 charge light blinks 7 times shuts down ,what causes this problem
Did you get the charger with it? Charge the battery first before you use it.
Oct 15, 2014 | HP Compaq 6510b PC Notebook
I have a HP/Compaq 6510b laptop computer and it will not turn on...I have the charger plugged in and the only thing happening is the green light periodically flashes...Is the battery bad?
IF the battery is bad the charge lndicator on the laptop will flash (But not periodically) it will be a constant on-off-on-off..... Best check would be to remove the battery completely and use the adapter/charger power supply only. If it still does not turn on then you either have a bad power jack connection or a more serious motherboard problem. Also is the green light flashing on the adapter/charger or is it the charge/battery indicator on the laptop?
Feb 17, 2011 | HP Original HP COMPAQ 6510b 6515b 6710b AC...
My dell 620 battery will not charge with the power supply, yet it charges in the docking station. The laptop will run fine with the power supply except that the battery will not charge till I place the...
sounds like the situation is with the AC adapter detection. try to restore your BIOS defaults and update BIOS if applicable. Test another AC adapter. If that fails, most likely, this is with the motherboard. You may either get a new board, or just continue to charge it using the docking station.
Dec 31, 2010 | Dell Latitude D620 Notebook
Wont charge my iphone
The adapter off the docking station can be faulty and so that must be checked for working voltage.
If there is voltage on the adapter then the socking station charging section can be faulty.
The failure of the regulator IC in the docking station cannot be ruled out. You will need to remove the docking station after making sure there is no voltage to the docking section to the phone.
Nov 19, 2010 | RCA RP5500I Docking Station
Hi, i have a hp nx7400, it wont start or charge battery. tried with different adapters and with a docking station. when i push on button it will blink 8 times without battery connected, with battery...
Remove the battery from the portable and disconnect the Ac adapter. Press and Hold down the power button for 15 seconds.
Reconnect the Ac adapter only and power on the system. If the system is doing the same . The motherboard on the computer has gone bad.
You can read more on the same on the link below
HP support forum
Thanks for using Fixya
Proton
Oct 04, 2010 | HP Compaq nx7400 Notebook
Docking station
Hi!
I would suggest that you by-pass any docking stations and connect it directly via usb charger as most ipods do. And also, try to update Itunes and your Ipod Nano software.
Thanks and good luck! =)
Jan 04, 2009 | Apple iPod nano
My Jensen ipod docking system wont charge my i touch
The older ipods charge using 12v, the newer ones (including the Touch 2nd gen) use 5v. So a lot of docks that will charge a nano will not charge a new Touch. If a dock says it will work with the iPhone then it will work with the newer iPod Touch (2nd gen).
If you have an old dock and want to charge a new Touch (sounds like the case here) then you can get an adapter. Scosche makes one just for this.
Dec 26, 2008 | Audiovox JENSEN IPOD DIGITAL DOCKING...
Docking station fror compaq Evo n610c
docking station for my old compaq armada did not "charge seperately" but did supply power to the pc through docking connector and not through the normal ac input, cant say if they have their own power transformers or not, till i go home and take my old docking station apart. Will the computer not power up when plugged in, it normally will run off ac power even when battery is dead or removed.
May 06, 2008 | Compaq Evo N610C Notebook
Computers & Internet Logo
268 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
